Mickmartin
Everything posted by Mickmartin
  1. Carista or ODB11 bother let you change this function.
  2. I've ran 18"x 8J ET38 on the fabia on 215/25/18 without issues, Also ran 17"x8j ET30 with no issues & lowered 40mm I'm now running 17"x7j alloys, 18's looked great but not practical.
  3. Yep will fit perefect, No issue's there.
  4. Leave it as is if its your old dears car, If it was yours I'd strongly advise a RTMG ecu & tcu remap.
  5. Timing chains on the TSI's don't have a specific lifespan or interval change. The car will soon let you know if it needs done either by an unignorably loud tapping from the engine or various error codes. The waterpump on the other hand I have no idea on this variant on engine.
  6. Easy option is to simply keep your old lights, Put them back and on for MOT day, Job done. Your other option is to split the lights like others have done in the past and swap the components.
  7. Send me a message mate, I should be able to source you the adapter cheaper.
  8. Hows the engine handle the heat and humidity there? Hotter parts of the world such as Asia and Australia the mechatronic rally suffered with the high humidity in early CAVE builds. Looking good.
  9. Car will still run if the water pump\magnetic clutch goes as the car goes into limp mode and cuts all boost, Shouldn't ever cut out, Just warning lights. Your revs drop to zero then fire back up as normal? No power issues or kangarooing when driving as I would immediately think it was fuel related as HPFP are common to go on these. Any vacuum related issues should in theory throw up a code pretty quickly but never rule that out. Do you have an ob2 adapter and any live software that would let you watch air/fuelling etc? How many many miles has it done out of interest as a failing/stretched timing chain could cause those symptoms.
  10. As Thomas said, It could be the water pump/supercharger engaging, I tend to hear this in cold weather before the cars heated up then disappears. have you noticed it disappears after driving a while? I posted a similar post about 3 years on here as it i could clearly hear it with driver window down ad particular in first gear when setting off. Possible to record the sound?
  11. Owned mine over 3 years and it snow hit 52k, I've been fortunate that the previous owner was supplied with anew engine at 14k and in my possession the car doesn't burn any oil, I service mine once a year and once a year only and that would consists of oil,plugs, oil filter and fuel filter and touch wood I've had very little issues with my estate/combi version. I've only ever used MANN filters and laterally move to NGK BKR7EIX plugs, My best advice would be to stick similar plugs as you may have read these can be a bit of lottery with plugs. I've ran a catch can for a little over a year now and whilst it does its job and catches oil, that's hasn't reflected in massive oil loss o particularly any loss as weird as it seems. You'll never find an easier car to service in your life! The revised oil jets are fairly cheap to source and buy yourself however its a bit of a nasty job changing them without the right tools and doesn't always guarantee the fix as the damage may have been done ie ruined piston rings. Happy driving.
  12. My best advice would be to head over to Mk2 Fabia Vrs facebook page if your on Facebook and want advice, This place is for people would argue about the colour of an orange. Shame really as I'd imagine other parts of this forum are useful.
  13. Nah no need to worry on Tsi's, Would be a very rare case if a timing chain snapped however stretching is as common as muck. I would be me more worried that nobody noticed the audible difference from the noise of the engine if the chain was stretched as particularly on these they tend to make a hell of a racket, the car runs like crap and in theory it should start to throw up P0016 codes Replace the tensioner at the same time as these engines still use an old tensioner that has been revised 3 times by VW since ours, Its prone to chucking it and having done the timing chain on these I can vouch for an £80 timing kits from TPS, Ive done the lot for just over £100 and it 3 took hours in total. £80 for timing kit £22 for timing tools And obviously make sure they check over the other components for damage ie sprockets
  14. What year an mileage? I may be interested in taking it off your hands if you go that route. As mentioned above a proper compression test should determine whether a borescope is required, Was it burning oil before it broke on you? That would be the first sign that is the piston rings failing or possibility of scoring on the cylinders. As Thomas mentioned the wiring to the coils and ignition connectors must be checked as the wiring is notorious on these for disintegrating, For the warning lights to disappear would indicate that its and intermittent electrical fault of some sort. I'd quickly run the engine and put pressure on each on the connections to the coils and the coils themselves to see if there's any difference in how the engine behaves and get and get that wiring checked asap.
  15. I ran denso for almost a year at a gap of 0.4mm as the plugs implied on the box the gap should not be adjusted and they did run fine for probably 8 months or so then the misfires started back so moved to NGK BKR7(2667) and haven’t really looked back, no misfires, no rough idle and most likely by pure luck Ive never had an coil issues. Went stage 2 in December 2019 and was recommended by RTMG that I gap the NGK’s to 0.8mm as I was running more power so I immediately done so and all was good, never had any issues whatsoever apart from clutch slip in 2nd gear when red lined in “s mode”, that is solved by changing gear a bit earlier and rarely cause me issues. I had a friend running stage 2 by Ecotune on his forged 1.4 tfsi running 280 bhp, early teething problems seen him returning back to Ecotune to get the map adjusted a couple of time but they did sort eventually, credit to them. Again I can only go on my experience with plugs on these cars and from what knowledge I’ve learned online from other users and I wouldn’t discredit Denso however personally it would be NGK for me as I’m running R8 coils with the BKR7’s these days without a hitch, I never gapped these new plugs as left them at 0.6mm with the new coils and they have been absolutely fine.
  16. Welcome, Hola! What a lucky man to be from Chile, such a beautiful country. Car looks and some nice mods planned. Keep up updated as I'd love to see what the car scene in chile is like!
  17. "Tools" socket set/spark plug socket/21mm ring spanner to remove top mount spring compressors and obviously a jack. Fairly straight forward process and plenty of video's tutorials online if needed and you do need to take any wheel hubs off, Simply use 2nd jack to raise and lower the drive shaft to squeeze the shock and spring past & pick up some top mounts, no point in going to that effort stripping it down and not replacing the top mounts for a few quid each.
  18. Hard to see due to pic resolution but you'll notice the gap behind the badge.
  19. Yeah mate as said above, seen Andrew’s and helped another boy remove his grill to fit one. Can’t mind if the post was on here or on Facebook group with pics of the gap as a user thought they had fitted it wrong. Looks the part it’s just not for me and I’m sure Andrew could post up some pics.
  20. Note to add.....The milotec grill is a horrible fitment and leaves you with a gap behind the badge.
  21. Head bolts - (outside to inside) Initial 30Nm all bolts then +90 deg then +90 deg then +90 deg Conrod Bolts - 30nm + 90 deg Unsure about rocker cover, WIll check when I'm home.
  22. Only a week before did I decided to get off my arse and do Scotland's Nc500, 500 miles in a turbo/supercharged fabia combi on scenic long roads by myself? Hell yeah! Sorry for the picture overload, I've kept the pictures as low quality as possible to try not kill your browsers. Lets have it! Loaded up the fabia will fuel and essentials and headed off, My first 3 hours would be spent just getting to the start at Inverness. Reached Inverness In no time and proceeded up the east coast of Scotland while visiting a few places on the way before reaching my accommodation( Bower Wig Wams) in Wick Dunrobin Castle, Golspie Second day seen me travel the whole breadth of the North of Scotland form east to west, I've seen most of Scotland before but this place will stick in my memories forever and I seen my first puffin! As you travel from east to west the beaches and views only get better. Dunnet Bay, Thurso. 2 miles of pure white and aqua blue water.....Best beach in Britain in my opinion. As you make your way across the north coast through the Bay of Tongue and towards Durness the beaches continue to be as spectacular however the landscape get a bit more rugged. Ardvreck castle from above Decided to camp up on Balnakiel Beach for the night, Had the whole beach to myself...... To my surprise I woke up to the sun splitting the sky and some visitors.......Yep its 7am and the cows are crossing the beach to reach a fresh water stream, Apparently a daily occurrence Leaving Durness Your pretty much in the most north westerly point in the UK, Visited a few places before heading south down the west coast and entering Wester Ross(Game of thrones fans will grin). Smoo Cave The landscape changes dramatically on the west coast, Huge rolling mountains start to appear as I headed south towards Ullapool,Gairloch and Applecross. After staying in Ullapool for the night I was off sharp in the morning for another spectacular drive south west, Passing the Kylesku bridge and hotel for some well needed grub! From here I continued south through Wester Ross at which point he NC500 heads to Applecross then Back to Inverness, I went off track and headed home via Skye, Fort WIlliam and Glencoe When reaching Applecross you encourter the "Bealach Na Ba" mountain pass, Regarded as one of if not the best roads in Britain with views of the Isle of Skye to the West and The mountain pass on the other. Deciding I could probably be home for midnight I cut my last day short and blasted the 6 hour journey home passing "Eilean donan castle" and the might " Buchaille Etive Mor" mountain in Glencoe. So nearly 3 tanks of fuel and 960 miles later I made it home, Car was awesome, Weather was awesome and the scenery was even better! Would highly recommend anyone to head up north and just do it, The road conditions are perfect and if you get the weather......I don't think may places in the world could top it. I'll hopefully have a drone vid posted up soon. Thanks for reading.
