Everything posted by TMB
AnnoyingPentium's 2006 Fabia 1.2 12v Ambiente-ish
The donor car is an unusual colour. Don't think I've seen one that colour in the wild. Has rear discs too.
Ryan, you're aff yer heid!
Fabia 1.4 2005 - Engine Won't start BBZ Engine 75kw 100hp
Yes, and there are no incandescent bulbs, all the warning lights are SMDs. Nothing to stop someone bunging a lump of Blu-Tak in there though.
Oh well, good luck with it.
The ECUs hardly ever fail on MK1 Fabias.
Running rough
Unfortunately I don't have a photo, but yeah, just follow it from the servo.
Running rough
In particular, check the plastic brake servo pipe for splitting at the end connectors and non-return valve. Example...
Would the BKY engine be the same?
Oh, I kind of see what you are saying, that you think the crank sensor might be reporting a slower speed than actual? I doubt that very much tbh.
Yeah but that's nothing to do with the crank sensor, all it does is measure the crankshaft rotation speed. Slow cranking is to do with starter motor/battery/bad connections.
That is bizarre. The crank sensor has nothing to do with cranking speed.
Forgive me father, for I have sinned... Hocus Pocus
Ah yes, a nice mouthful of 4 Star. Been there, done that
Has the old stale fuel been drained out and fresh put in?
Warning lights
Make sure you inspect them very carefully as the cracks can be vitually imperceptible. Give them a wee poke.
Warning lights
Not really. Check the big strip fuses on top of the battery as they are known for cracking. The jolt could have affected the ABS one.
Warning lights
Sounds like an abs sensor or the wiring to it. Had the same on mine with a duff offside sensor. Have you got a code reader?
Those bump stops always rot away. Both of mine were broken like yours when I first got my Fabia.
A weird problem with my front passenger lock
Yes, it's worth checking as they do like to break, although it's more often the drivers' side door which obviously gets the most use. You can see the broken yellow/green wire I had on mine......
Ah, ok 🙂
Passenger window carrier issue
I'm not sure. Done two of them and never had this problem. The only way you'll find out is to strip it down again, unfortunately. It's a pig of a job at the best of times.
Sounds like it's catching on something or there is too much resistance. Is the window sitting properly in the two clamps?
I don't know what spam unlock & spam lock means but it sounds like your passenger door microswitch is faulty. Could also be the wires inside the door bellows.
Slick 50 oil additive
Put a bottle into my Talbot Sunbeam 1.3 years ago. Didn't seem to do any harm but probably was a waste of time.
Competition clutch?
Apparently, they are awful for normal road driving.
Competition clutch?
Certainly sounds like it, unfortunately.
