D.FYLAKTOS
  1. Yes but: 3 different scanning tools (laptop, portable VCDS and OBD11) in 2 garage-shops never manage to find two crucial things: a wrong valve gap plus a non good spark plug compustion.
  2. Suddenly in city (traffic) my Felicia started to have much more fuel consumptipn than all the other years. Especially from starting point till the temperature comes up to the propel lever i felt that something was going wrong. Smell (fumes) and sort of white smoke much more time than it should be. TC-6 is a board computer, among others shows the instant fuell consumption no matter if it's idle or top speed. You can see mine here: Maf-Lamda-temperature temperature sensor are new, throttle is clean,battery is good, valves and spark plugs are ok. I "raise" my Felicia with synthetic oil so maybe she don't like the semisynthetic that i was using for 2 years. 😋
  3. For sure nothing is now as it was when i bought it but yesterday i done another test. The car was on the parking P10, turn the car on wait 15 sec, engage 1st gear and let it roll alone, the car start moving rolling to P7, P5, P3 (i don't touched the pedal) and when i reached the exit i let it steady to idle in purpose The needle was on 1100 rpm, i waited and when it dropped to 850 the timer on my cellphone shown 3:44 minutes, isn't that too much? Service, maintenance, repairs etc have been with a lot of attention and VAG code parts, no sloppy work. Any upgrades were till 2018, suddenly my car needs a lot of time to get warm (thus the little smoke on the first traffic light) and that means fuel consumption. The TC-6 shown 2,6 litres per hour when the car started and after 3,44 minutes shown 0,9 which is one click before the 0,8 litre per hour (that's the number when the car is warm and the idle is 850 rpm).
  4. The needle rise up at 1100 rpm as it should be but the problem is that it takes too much time to lower at 850 rpm which is the proper limit. You will say just wait 20 sec and then start driving the car, yes but: I have made 3 times a test, the car was on a parking 5 floors below earth and the temperature of course was not as 12 'C as is outside the road but one clich higher. I started the car, waited 15 sec and engage the 1th gear, the car started to roll (the rpm were about 1100) and without touching the pedal started rolling to the exit, it moved 4 floors then exited (thanfully no traffic) and still rolled byhimself without me touching the pedal !!! I reached the end of the block, i accelerate gently to 2nth gear and when i stopped in the traffic light i noticed smoke coming from the exhaust wich means the fumes were still cold. When the traffic light turn to green i started, 2nth gear and as i reached the end of a small uphill then in the next traffic light the idle was 850 rpm. Something is going on and i don't know what, it takes too much time from the 1100 rpm to drop down to 850 rpm.
  5. This is a photo from a relative video (Should You Warm Up Your Car Before Driving? ) and i want to ask: those very important moments (from the time that the key turns on till the time that the temperature reaches the proper point) the synthetic oil is better than the semi-synthetic for our Felicia? Nice and easy driving, no sudden acceleration etc so with which oil our Old car will has less problems as engine wear, increased fuel consumption, etc?
  6. Yes as an old 2 stroke rider i agree plus that was an "ace" for them when they racing against 4 stroke bikes because those in downshift a small bounche on the rear wheel. In my TC-6 with 3-4-5th gear on when i release the acceleration pedal and let the car roll i see 00 on the lcd.
  7. The term in Greek for such exaggerations "for show off" in every sector was for over a century (and some times still is) the "Gyfties" which means "Gypsie thing". I spoke for old cars with 4 gears and carburator. I have seen it numerus times when i was kid and even today some drivers with 50cc motorcycles use it. From 3rd gear turn to N let the motorcycle roll to a downhill or a boulevard and one click before the traffic light they press and engage again the 3rd gear.
  8. At 1:16 says about a 24 year old car, a Toyota Celica. I press the clutch and when it cranks i let him, they have told me that this reduces the load at the ignition time.
  9. Ricer car is the term in english (slang). At the 70's-80's i remember that the taxi drivers at the downhill or in the highway they put the Neutral for few seconds and the car was rolling with his own speed, that was a trick of that era for gas economy.
  10. 16V sticker on an old 8 valve car, turbo sticker or turbo sound devices on the tail pipe, GTi stickers, plastic discs as rear brake disks etc.
  11. You mean the Crank sensor? This one is a "Do not touch" sensor, you must not remove it without a serous reason or overtighten it. One guy try to use it as an Antitheef measure and that cause him huge problems.
  12. @KenONeill : The type of engine oil plays till that time a crucial part or no?
  13. BMW older models had it in their dashboard. Vacuum gauges in three colours (green-yellow-red) and white needle were very famous back in the carburetor days. Very easy to read.
  14. This does not coming after a minute, it takes longer. The type of engine oil plays till that time a crucial part or no? When the motor starts while you standing and few rev ups with gentle pedal pushings won't help a bit?
  15. No matter the weather you just turn the key and the next second you put the gear on? There isn't a difference between an old design motor like ours with a new one on this sector?
  16. I don't mean in snow or ice conditions with temperatures below zero for example as -20 C but on a typical cold day in the morning as you are about to leave the parking lot to go work, how much time you let the engine idling? 15 sec, 30 sec, 1 minute? More? https://knowhow.napaonline.com/benefits-of-warming-up-your-car-how-long-is-too-long/ https://www.nrcan.gc.ca/energy/efficiency/communities-infrastructure/transportation/idling/4463 On that short period what is best for our Old technology engine, a Synthetic or a Semi synthetic oil?
  17. No problem with puddles? The braking distance isn't different? Driving on wet weather does not feel the steering wheel more ''light'' ?
  18. An older video and another one compared with a Scan gauge.
  19. A Vacuum gauge on the driver's column wont help?
  20. The article is not mine, i have the link at the end of it. 😉
  21. Why is the actual capacity of automotive fuel tanks bigger than nominal capacity? “It seems like the fuel tank is filled up more than the rated capacity!!!” “It’s never been like that!!!” Driver may have all experienced something like these. Especially when filling up the car, drivers sometimes doubt if the right amount of fuel is filled for these reasons. So it does when the amount of fuel remained and filled exceeds the capacity of a fuel tank officially indicated by automakers. However if the difference is merely 5~10 liters, this is natural. It’s because it was originally designed to be larger than the nominal capacity of a fuel tank specified in the user’s guide. Therefore if the phenomenon above happens, do not panic and check the actual difference from the nominal capacity. 1. Nominal capacity of a fuel tank (nominal capacity) ① “Nominal capacity” is designed for passenger cars to drive *about 600 km at the speed of 80~100 km/hr on the motorways. Nominal capacity varies depending on car models and an engine displacement because it is designed considering fuel efficiency and the weight of car body. * About 600 km driving if it is converted into a distance on the assumption that a driver can drive 5~6 hours a day at the speed of 100 km without physical fatigue (on a basis of fueling once a day). ② It was designed with spare capacity to allow a driver to drive to the next highway service area* (the average distance between service areas is about 50~60 km) and it is about 10% of the capacity of a fuel tank. 2. Why is the actual capacity larger than the nominal capacity? If the nominal capacity of a fuel tank is 65ℓ, the actual capacity is about 75ℓ. It’s because automobile manufacturers made the fuel tank by securing spare capacity corresponding to 10~15% of the nominal capacity1. The reason is as follows: ① It is intended to prevent VOC from being leaked in the event of volume expansion caused by an air temperature rise. If the fuel tank is filled up, the fuel is likely to overflow as the internal temperature rises to push up internal pressure. ② It is also intended to secure room for expansion to prevent the leakage of fuel when the car is parked on a slant after its fuel tank is filled up. This room is called “spare capacity for expansion.” (Note) ¹ Maintain the reference amount of fueling LPG vehicles’ fuel tanks (85%) LPG expands if its temperature in liquid state is raised. Therefore in case of filling the container with LPG, it is regulated to have the container’s temperature maintained below 40℃ to keep liquid LPG from exceeding 85% of container content (90% in case of a storage tank). http://www.s-oil7.net/eng/knowledge/expert/view.jsp?seq=79
  22. You are right, the TC-6 is the solution but as an aftermarket is very expensive.
