D.FYLAKTOS
  1. Porsche 993 turbo (1993-1998) had a key with a small light on it,far more bright than Felicia's one.
  2. I wonder if a technician in a upholstery-shop can make a modifications to our factory head rests and make them with more inclination like this: I have sat in 2 buckets seats (actually chairs) and i realise that there was a big gap between the back of my head and the head rest Almost 4-5 fingers and i found this very dangerous, yes i know this gap is for helmet (racing) but if an every day driver uses it with standard seat belts then the bouncing back would be fatal.
  3. Fiat Cinquecento if i remember correct had 27% back then. 2019: Zero (0) stars for an electric Chinese car Jac ES-1
  4. So we must replace them with another material? metal perhaps? If so what about friction-lubrication issues with the rail?
  5. Update: Last night i checked the expansion tank, YES there are still some detritus inside (look like glitters but not so ''shiny"), look like this https://www.briskoda.net/forums/uploads/monthly_2025_01/G.jpg.cdc538aa212b57de31ef57585041fbcb.jpg and i saw that the antifreeze level was ''one click'' lower and i added about 200ml distilled water. I saw no leaks and i think the culprit is the VIKA expansion tank (bolts) since the cap is better quality.
  6. Sorry @nta16 but i can not help @Joja2k because i have ECU in my Felicia and no knoledge about the distributor. 🥺
  7. A ''torture'' road test including a moment of crash test. Surprisingly, not many videos have survived from the crash tests of the Favorit's successor, the popular Felicia. This is actually the only video capturing the durability tests and several more tests with the first airbags, which, however, were only available in very few Felicias on our market. Most of them were exported.
  8. But why in only in a specific part of the rail? That plastic guide in beige colour?
  9. In my pc i have this article in German language,if i remember correctly the Feliia took 67% in the crash test (with the standards of that era) when other cars had less, a French one had scored 32%. I will search for it when i get home and i will post tomorrow.
  10. For me it's the rattle noise when the driver's window is 3 fingers down,in all the other positions is Ok but while driving in City the noise is continuous and makes me crazy.
  11. Tha plastic tube can not be replaced by something aftermarket (non car application) but more robust? A random examples: https://citimarine.gr/image/cache/catalog/EVAL/94141a-550x550w.png https://www.growit.gr/wp-content/uploads/13mm-flexible-tube.jpg https://aeroponic.gr/media/catalog/product/cache.jpg
  12. As for the record: Universal seat rails for bases with diameter 345mm / 405mm 99 euro here without the fitting work from the mechanic. Any modifications means the customer will hear ''No'' till ''i can do it with extra charge".
  13. I have seen many US videos of modifying the frame, here in GR we call that procedure as "tailoring" but there is no guarantee that it will work properly because you rely on the technicians experience, if something goes wrong the ''fixing'' it's expensive and it will take time. Sometimes the technicians take that uncertainty as an excuse for extra charge: ''Hm i don't know if it will works, let's see, i will try, i will see what i can do, it will take time since i am busy" etc. Back in the good-old days there were aftermarket armrests for the Felicia seats, i bought and installed one, the only drawback was while putting the Reverse in City traffic in a hurry (parking) so i remove it. Good for the National Highway though.
  14. These are seats from an Octavia model which fit in a Felicia? Their base frame will fit in Felicia's chassis holes?
  15. Cost 1200 euro or 1.057 GBP, i presume for 4 seats (300 euro per unit) huh?
  16. I don't like the gap between the head rest and the head. I don't have any,it's difficult for me to read books in english plus i haven't the time. I can read small articles and forum posts,if i see a lot of blah-blah and abbreviations or slang language i leave it without paying further attention.
  17. It's Julian Edgar,an author of many books about car modifications. https://www.thriftbooks.com/a/julian-edgar/922186/ I have modified my air-filter box inspired from his work, you should see the rest of the video,very interesting. The Felicia seat is not good for long trips and Sport driving so about 20 years ago i removed gently a piece of factory foam from the lower part of the centre panel making my back ''tucked in'' a bit more, i added a layer on the head rest so in emergency braking my head will stopped sooner (reducing the gap) and last year i added a set of pad in the seat cushion so my knees are not in a so ''slippery'' situation as before, never regret for those e modifications.
  18. The @Thefeliciahacker has done a rebuild in his engine,it's 1.3 but he has done an extensive job and can provide you with many infos.
  19. I have aftermarket, work perfect. The kt fits with no modifications. A piece of thick nylon can do the job, use strong double-side adhesive tape, check the drain holes to be full open. Here was the old (driver's side) Diagram
