Everything posted by pab567
Amundsen MIB2 Firmware Update
You have MIB1 unit. It's possible to convert it to EU but it's NOT possible to use CarPlay as it does NOT support it at all - if you want CarPlay you MUST replace your glove box unit with one of MIB2 series. If you are interested pls contact me in PM. All others check your PMs.
- Is it possible to upgrade the infotainment screen?
Faulty Odometer Readout
99% LCD is broken, disassemble and clean, if doesn't help buy second hand instrument cluster and replace LCD only. If you share VIN then I can check instrument cluster part number
Possible but: New unit must be assigned online to your car (component protection removal) by Skoda dealer or someone with ODIS ONLINE account for Skoda. SmartLink will stop working after few hours (up to 8) and can NOT be officially activated. The only possibility is to have the new unit patched. Unfortunately I don't know anyone neither the way to have it patched. It's possible to patch Bolero or Amundsen unit but this requires more parts to be replaced (display unit, infotainment reader, harness to connect both units and, if you want to use CarPlay, then also USB, port).
- Want to purchase Carplay head unit, what is best to buy?
Amundsen MIB STD2 infotainment system with Android in Superb II
SO your microphone goes directly to BT module, you will need to re-wire it to MIB STD2 PQ unit. I usually do it by making two joints in BT connector (pins 8-12 and 9-11) which redirects microphone signal via audio out cable (so you don't need to make new wires between BT module and MIB STD2 PQ unit).
here is no such firmware as Yeti production was closed with MY17 which had SW 03xx. @SalvaS good job, now find two adaptation channels with words "Google" and "Apple" and enable them (the ones without "wireless" only).
Skoda Swing Firmware Update - MU 8755
Sent in PM. @MERO772005 unfortunately I don't have it :(
Firmware 6276 source
Sent in PM
There is no difference in the way SW update is made between DVD and CD but as many old lasers have issues with reading burned DVD I definiteley recommend to use CD-R. Use lowest available burning speed.
Microphone is easy, it depends on your harness as they were two ways it was connected (either directly to BT module or directly to radio and then from radio to BT module). If you can make a picture of QUadLOck plug that goes into your radio, from the cable side, focused on green 12-pin connector. I don't find any incompatibility based on VIN.
- Superb infotainment faults
Old Bluetooth module must be removed and microphone must be connected directly to MIB SYD2 PQ unit Yes, you will see in screen the car and sensors changing color with proximity. Yes, steering wheel adapter will work properly. USB adapter that you have now must be removed and replaced with the one that works with MIB STD2 PQ series. Pls share your VIN so I can check details of your car configuration.
I have no clue what accessoried you mean... for sure you will need QuadLock adapter, USB port and if you don't have then microphone as well
Yes, you caninstall MIB STD2 PQ unit in your car, I made several retrofits in Fabia Mk2 :)
Download link sent in PM
MEN2_EU_SKGPx_P0080L MU8755
Good luck... I don't know any solution for Swing with this firmware
I bet you have the problem with HDD. You can try to get another HDD, have it replaced and then restart firmware upgrade. It's IDE (PATA) HDD/SSD, 2.5" size.
Infotainment Model Numbers
Check the buttons, especially right side...
You need to burn it as an image, not just placing the file on CD. 700MB CD-R is enough
Indeed, this is Amunden MIB2, without DAB/DAB+, MY17. Yes, you can replace the display unit with 5E0919605N, everything will work as expected, including APP button.
You have Bolero MIB2, with DAB/DAB+, MY17. I sent you link to SW upgrade in PM. Unfortunately, activation of SmartLink in this unit can't be done from SD, it requires unit to be opened and soldered. If you are interested pls contact me in PM.
@jimbocos I have just sent you link to download RNS510-5238A-josi-VIM-Testmode-60-35-5 Pls send the part number and SW version or picture of a label as @jimbocos did.
