Everything posted by pab567
Amundsen MIB2 Firmware Update
This is the most recent firmware I have. @Oli I can't send you PM, drop me mail to [removed]
1. format SD (best max 32GB) under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
PM
Part number and current SW version? I don;t have change logs
- Škoda Octavia 3 MIB1 MSTD_EU_SK_P3420
@Hightower200 MIB2 units don't support OTA update. @Oli pls post model number and current SW version of your unit. All check your PMs.
This is because logos DB has been updated as well, just re-save stations and logos will appear again
No - at least I don;t know anou any newer than 0480.
First you have to install MIB STD2 Toolbox, then use it to patch swdownload, then flash with 0480, then install MIB SDT2 Toolbox again and finally use MIB STD2 Toolbox to enable whatever you need.
Check now
All check your PMs
Possible from SD but only for units with OEM navigation. Fo non-navigation ones it has to be dismantled, open and soldered.
PM :)
Yes, it's required for each of them.
Bolero => you will NOT be able to activate SmartLink without opening and soldering glove box unit.
@nekas I sent you download link in PM. What is part number of your unit? If you have Bolero (version without OEM sat nav) you will NOT be able to activate SmartLink without opening and soldering glove box unit.
OEM head unit update
I sent you PM
2015 superb head unit dead
What is the unit? Pls post the picture
MIB2 retrofit on an MY2015 L&K
So now you have Bolero MIB1, with Bluetooth, without DAB, without MOST, without RVC support, part number 5E0035819A, with Media In port and, as you mentioned, fortunately you don't have CANTON sound system. You can install one of four different OEM glove box units: - MIB2 Bolero - MIB2 Amundsen - MIB2 Columbus - MIB2.5 Columbus You also need to replace display unit: - for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N - for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M - for MIB2.5 Columbus the only display unit that works is 5E0919606D Media In interface must be replaced with USB port, either with or without CarPlay support. The question is what is your budget and which of listed below features are "must have": - Video playback from DVD, USB, SD - CD playback - OEM navigation - displaying OEM maps in Virtual Cluster (Active Info Display). All units support SmartLink (Android Auto, Apple CarPlay, MirrorLink), rear view camera, voice command. features that differ them: - MIB2 Bolero - no OEM navigation, no CD/DVD drive, no video playback from SD/USB - MIB2 Amundsen - OEM navigation, no CD/DVD drive, no video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, no support for displaying OEM maps in Active Info Display (Virtual Cluster) - MIB2.5 Columbus - OEM navigation, CD/DVD drive, video playback from SD/USB, support for displaying OEM maps in Active Info Display (Virtual Cluster)
All check your PMs. Pls keep in mind that IF your unit has SW patch applied then upgrading firmware will have it killed - your unit will be locked with Component Protection and activations might be lost as well. Let me remind you upgrade procedure: 1. format SD (best max 32GB) under FAT32 2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder) 3. insert SD card into the slot 4. enter Service Menu (long press MENU button)
I sent you download link on PM however I hardly believe this could help you.
Newbie question. Replace radio for Carplay support What do I need
Pls share VIN and part number of the unit you bought.
COLLUMBUS AUDIO SYSTEM. Resetting
Probably it will requires firmware reflash. Pls post the picture of label fro upper housing and, if possible, a link to some video showing the behavior.
I need Bolero Update :-)
PM
