Everything posted by pab567
Blues radio wiring and disassembly
Su you have Blues radio, without DAB, without Bluetooth, part number 6V0 035 872, with AUX port 5Q0 035 724 and USB port 5Q0 035 726 B. The cheapest unit for you shoudl be SWING part number 6V0 035 871. You will also need a microphone part number 3Q0 035 711 B and harness to connect it to SWING. Upon installatiopn, component protection must be removed either by Skoda delaer or someone who has ODIS ONLINE account for Skoda and unit must be parametrized (coding and adaptations) to match your car's equipment.
If Bluettoth is all you need then unit for you is Swing, if you would also like to have SmartLink then indeed you need Bolero or Amundsen which includes display unit and glove box unit so is more complicated but still possible - several users have already done it. If you share VIN then I can provide more details.
Being in your shoes I would rather think about some OEM unit. What are th efeatures you are looking for?
I need Bolero Update :-)
Not possible for your unit 😞
Amundsen MIB2 Firmware Update
All check your PMs
2018 Rapid Spaceback fuse ratings
Me too... just move it from 11 to 12
Question about replacing multimedia
Pls share picture of your multimedia unit or at least VIN of your car.
Mib 2 high and 2.5 high SW update
PM
Reverse camera
Assuming your car is Fabia Mk3 then how adapter dedicated for Renault can work with it?
PM
Jittery audio when using Google Maps
Unfortunately I have no firmware for MIB3 units 😞
@Bramb you already have the latest version. What are you missing in your unit?
PM
The question is if you have unit with built-in OEM sat nav (Amundsen) or without (Bolero) - this can be done in both but in Bolero it requires unit to be open, soldered and some files modified in EMMC.
It will not work for you as you have unit without navigation (Bolero).
PM
PM
Apple CarPlay is staticky
PM
Error: workshop! Only leave vehicle in position P
THis is just indication, you need to connect diagnostics tool (VCDS, VCP< OBD Eleven, ODIS, VC Tool) and read error codes
resent in a new message
@dhandley you already have the latest available firmware installed @Starca pls check your PM
part number and SW version of your current unit?
Well, this is not AMundsen MIB2, this is Columbus MIB1, with DAB, PLs share your VIN on PM so I can check what are your options.
PM
