Everything posted by pab567
Columbus Infotainment System
Drop me your shipping details on PM, I will send you one
2010 Superb 2 Rear Parking Sensors Part Numbers
VIN?
PCB ON STEERING
Is there an update to Infotainment System (5Q0035842A / H24) newer than 0241?
Sent via PM
2010 vibrating steering wheel
Infotainment failed
Looks like mainboard faulty, pls remove and send picture of a label from upper case.
Amundsen MIB2 Firmware Update
My comment was for @toXXin
Yes however you must have Developer Mode enabled first. Unfortunately, from your error description I beleive EMMC in your unit is faulty.
Replacing my Columbus with a Pioneer head unit.
Check with your Pioneer seller if AVH-Z9200DAB works properly with Sound System. If it is not supported then you either: - remove Blaupunkt amplifier from the system and install proper crossevers (3-way crossovers for front and 2-way crossovers for rear) - replace Pioneer unit with another type that supports Sound System, either aftermarket or Skoda MIB STD2 PQ (must be patched first) - return to Columbus and replace Bluetooth module with some that supports HFP (Hands Free Profile), A2DP (Advanced Audio Distribution Profile) and AVRCP (Audio Video Remote Control Profile).
If you are fimilar with QNX and software reerse engineering then I believe you can do it.
Going from SOp3 frimware (03xx) to SOP4 (04xx) is not a piece of cake. First you have to flash th eunit with patched swdownload and then flash with 04xx firmware with especially modified metainfo2.txt.
Octavia radio swing update
find someone with vcds, make adaptation channels map and send me.
This seems to me lik eincorrect adaptations - do you have VCDS? Or at least OBD Eleven?
- Infotainment Upgrades
So now you have Amundsen MIB1, with DAB, with USB 5Q0035726B (support for Android Auto, no support for Apple CarPlay) and fortunately you don;t have CANTON sond system. You can install one of four different glove box units: - MIB2 Bolero - MIB2 Amundsen - MIB2 Columbus - MIB2.5 Columbus You also need to replace display unit: - for MIB2 Bolero you can use either 6.5" model number 5E0919605H or 8" model number 5E0919605N - for MIB2 Amundsen and MIB2 Columbus you can use listed above display as well as 6.5" model number 5E0919605J, 8" model number 5E0919606, 8" model number 5E0919605M - for MIB2.5 Columbus the only display unit that works is 5E0919606D The price range is from 250 GBP (Bolero + 6.5" screen) up to 750 GBP (Columbus MIB2.5 with 9.2" screen). If you would like to have also support fot Apple CarPlay or better phone charging (current up to 1.5A comparing to 0.5A) then USB must be replaced as well (25 GBP). Shipping not included (approx 20 GBP). Upon arrival you have to pay local import taxes (mostly VAT). The question is what is your budget and which of listed below features are "must have": 1. Video playback from DVD, USB, SD 2. CD playback 3. OEM navigation 4. displaying OEM maps na Virtual Cluster (Active Info Display).
Your ca already has the right parts so in this case I believe this is the issue of rims and/or tyres.
It's a well known issue. Many people had it, including me (MY12 Superb 3.6). If this happens at the speed of approximately 75-90 mph, and you check the rims and tyres, then this is usually caused by sub-frame. The solution is to replace sub-frame with part number 1K0 199 313 AL. Let me know your VIN so I can check what is the part number of your current sub-frame, I beleive it is either 1K0 199 313 AQ (all engines but CDVA) or 1K0 199 313 AQ (CDVA engine). It might require also to change both left and right console (1K0 199 295 E and 1K0 199 296 J), wishbones (1K0 407 151 AC and 1K0 407 152 AC) and bolts (4x N 105 607 02 - M10x 70mm, 4x N 106 403 01 - M12x 100mm).
I need Bolero Update :-)
Nope, 0369 is the latest firmware for your unit.
Faulty Rear Parking Sensors
Find someone with VCDS, VCP, ODIS or OBD Eleven to check for the errors, this is the ONLY reliable way to have it checked.
Bolero to amundsen conversion
YOu have same unit as I had in my Fabia MY15 - 5Q0035820. You can have it repalced with Bolero 5Q0035842x / 565035842 or Amundsen 5Q0035874x / 565035874. The screen does NOT have to be replaced, just the reader. I can deliver such unit in Plug&Play version, if you are interested pls contact me on PM.
Columbus Sales & Repair.
Unforztunately, since couple of year there are no more maps for your unit available as support for these units has been abandoned after 5 years since manufacturing of them was stopped. If you plan to use this car for next couple of years I recommend retrofitiing with MIB STD2 PQ unit.
VIN?
MIB 2.5 Retrofit minor issues
1. too old firmware in ECU, cluster and / or gateway. Might be not possible to get this info even after SW upgrade - depending if the latest firmwary for these modules support it. 2. Mafe adaptation channels map from VCDS and send via PM (pl suse English version of VCDS).
The car won't start. There is no power in the cluster.
I beleive cluster itself is faulty...
