pab567
FREEDOMTech
Everything posted by pab567
  1. NAND in your unit is overloaded. Indeed reloading software may help, if not then NAND must be reformatted but this require special SW and HW tools.
  2. Need part number and current CW version
  3. Unfortunately, none of your wished is met with SW update - you must have the unit replaced. Pls contact me on PM if you are interested. As a reminder: - 5Q0035819 and 5Q0035820 units support MirrorLink only - 5Q0035819x and 5Q0035820x units do NOT support any of MirrorLink, Android Auto, Apple carPlay - none of mentioned above units supports Voice Control neither Rear View Camera All mentioned baove features are supported by 5Q0035840x, 565035840, 5Q0035842x and 565035842 units. x - letter A, B or C
  4. There is an update available (to 0138) but... is there anything wrong with 0135 that you want to update?
  5. I may MIB STD2 PQ unit from facelifted yeti, if you are interested pls contact me on PM.
  6. Then try another SD card. make sure it is formatted under FAT32
  7. @warlock87 contact me on PM. All others check you PMs
  8. You don't need to update the firmware, especially if everything works OK. Firmware updates are not published officially, they are available only for Skoda dealers.
  9. 1. OEM units are covered with components protection technology, then need to be matched with the car by Skoda dealer or someone having so called ODIS ONLINE account for Skoda. Pls note to enable new features, not supported originally, e.g. SmartLink, new unit must be hacked. 2. OEM units - yes, for aftermarket units you hae to check with supplier.
  10. Officially this is not possible. Unofficial way is to install the hacked unit however it refers to Bolero and Amundsen systems only - at least I know nobody who can hack Swing. If you are interested in retrofitting Boelro or Amundsen pls contact me on PM.
  11. I believe not but unfortunately I cannot help you.
  12. @sickzoid you have firmware download link on PM. For maps download use Volkswagen Map Updates make sure to unlock the file directly to SD root. @Pantersencheck your PM for download link
  13. This is NOT a MIB unit. I have no frimware for it 😞
  14. @Madsus you have download link on PM
  15. It is compatible otherwise the update process would not start at all. As I wrote you in PM - either problem with SD card or unit itself (EMMC).
  16. So it looks your unit had a SW patch for both CP and activations. Such units should NOT be upgraded. Now the unit must be patched again...
  17. What does it mean "mono"? Do you have sound only on one side or both?
