linni
Everything posted by linni
  1. Front vRS badge cannot be removed. At least my service guys told so when I bought my car. Rear boot door reflector with side reflectors can be replaced with tinted one, look at kopacek.com. There you can also buy front black badge.
  2. Contis wear out even when the car is not moving, Mine lasted for 17 000 kms, which is bit more than 10 000 miles. Best choice of course if the target is to take turns at max speeds. Pirelly is safe choice. Used Hankooks before, no complaints. Goodyear efficientgrip performance are good ones.
  3. @crni611 https://www.amazon.co.uk/Torque-Pro-Elm-327-Bluetooth/dp/B01AC7I7BO/ref=sr_1_16?crid=MM0J8GUJY02&keywords=obd2+dongle&qid=1695541079&sprefix=obd2+dongle%2Caps%2C143&sr=8-16 ELM 327 dongles work definitely with VAG DPF. NB! Works with Android only.
  4. If I remember correctly newer cars do not need high engine temperatures to start regen. They kind of inject the fuel directly into DPF to get the regen temperature up sooner. But first buy some cheap OBD dongle and download VAG DPF app to phone. Gives you a pretty clear picture what is going on with DPF.
  5. Front fog lights have a purpose only and only then, when they are as close to the ground as possible. The idea to give the beam under the fog front rather than through it. The position Kodiaq`s fog lights are located is absolutely useless.
  6. Some wise guy once said that fog lights are good to explore objects you are just going to hit. They create massive light spot just in front of the car. Your eye pupils will shrink due to this and to see whats further in front of you becomes pretty limited.
  7. What is necessary? Porche owners need only a rev counter. But some need more. I would like to have Audi`s virtual cockpit (12 inches), where you can have small speedo and tacho on sides and large map in the middle. And of course fuel and temperature cauges should also be physical (virtually, ofcourse) not some LED stripes. And radio information at the same time. And phonebook. If you commute only from A to B, maybe you do not need all this. But I commute also to C, D, E etc etc. Doing 85 000 kms annually. Annoying and also not very safe to scroll through the menus when driving.
  8. Drivers door handle snatched from an upper fixing. What it is, just an handle? But no. It comes with a whole door upholstery 674 euros! I am not mad at the bill, but I am mad at the guys talking about everything about the green / eco. And having our tax money to create b...ht.
  9. Simon, seems you are right now, but. I could update maps online before and SIM card really had only the functions for hotspot. Now, they have completely changed it. Probably too many people would download 32 GB maps over the esim at Skoda`s cost. Only explanation.
  10. Only 10 inch virtual cockpit (probably 10,2, to be precise). Not enough for 21st century.
  11. Just checked the portal for updates for my previous Superb with MIB 2 and it says, no updates available. As it is VIN based, then probably you have some special deal there down under.
  12. No. I have 2 sets of 18" winter wheels(studded and non studded), no issues whatsoever. "Trinity" and "Braga", both 7,0Jx18" ET43.
  13. I have MIB 2,5 unit, you have MIB 3. Could make a difference.
  14. Last times I have updated maps online directly on the headunit. 23 - 27 Gb each one usually. Still my SIM card data usage stays around 100 Mb a month.
  15. I have very strong doubts about that. Activating Skoda Connect services does not require customer - provided SIM.
  16. No, SIM is only for creating hotspot area. All the other communication goes through e - SIM. Some delusional mechanic maybe?
  17. @a666andy https://www.kufatec.com/en/skoda/kodiaq/rear-view-camera-retrofit-for-skoda-kodiaq-ns7-41940 This is one option. Says for the MIB2, but worth contacting them. WV has two OEM cameras - High and Low. High has extra module that creates these colored lines. Pretty sure they fit only High version to Kodiaq.
  18. AFAIK they stopped map updates for MIB 2,0 for the rest of the world, except Western Europe, somewhere in 2018 - 2019. If you really need one, search other forums, there is a solution modifying one from the BMW maps. But as you are talking about Kodiaq, it has MIB 2,5 and maps are available.
  19. I activated the "eyelashes" always on with VCDS and this turned the rear lights constantly on, when car is running. Seems that cheaper japs has no Auto option for lights, as there are tons of Corollas and Civics, driving around in the night with only DRL-s. No rear lights of course. Pretty dangerous.
  20. Front camera can be connected straight to the fuse box with piggyback connection. Use search, there are several topics on this.
  21. I ordered it as an option. Pretty good thing, if you live in the desert somewhere in Africa. Anywhere else it tends to fail. Too much halogen guys get dazzled. Too many truck drivers in hilly conditions also.
  22. On my previous Superb the SS button just died.
  23. There is no sound from speakers. Just the soundaktor. You can code it with OBD11. Default value is 100%, you can turn it down to 0% or some other level. Not sure about 200% though
