linni
Everything posted by linni
  1. Does not matter. There are two warnings - first one is "check the oil level". Usually still about 4 liters of oil in engine block. Second one is "oil level low" or similar. This is something that needs to be addressed to asap. P.S. I use VW longlife 0W 30.
  2. Pre facelift didn`t have this option at all. Facelift has, AFAIK.
  3. Cars for Nordic markets are usually equipped with ceramic heating elements, helps to warm up the engine very quickly.
  4. @hamid_v Got finally the long codings, modules A5 and 17. There must be coding for front camera in module A5, but I did not see it. And of course be careful with coding, the long coding consist bits which may be not suitable for your car. Anyway, found an ancient instruction in my computer, maybe this would help: Enable traffic sign detection when Lane Keeping Assistant is installed STG 5F Adaptation Car_Function_list_BAP_gen2 Traffic_sign_recognition_0x21 Set to active Car_function_adaptions_gen2-menu Menu_display_road_sign_identification Set to active STG A5 encoding Byte 16, bit 4 Stg 17 encoding Byte 5, bit 2.
  5. @hamid_v Sorry, takes a bit longer, too much work.
  6. @hamid_v Not familiar with Car Scanner. I did not enable these features on my car as I ordered them as options. You need specific camera, not all of them can be coded first. And not sure that 2021 car can be coded at all. Factory cut the access to OBD around that time.
  7. Buy cheap ELM-327 OBDII Car Auto Diagnostic Scanner, download VAG DPF app and you will know everything about your car's regens.
  8. If you have a AGM battery, then the normal voltage sould be 12,8 V. And max charging voltage 14,7 V. But the car also has Battery Mangement Sysyem, whivch manages the whole process, so the charging voltage can be anything, depending on lots of things.
  9. This has different part codes. Check by the codes from my previous post. https://www.autodoc.de/autoteile/oem/g065175a2?search=OEN+G065175A2
  10. Just checked. In previous years the dealer used oil with code G 060175A2, but last time they used G 065175A2. So I guess both are good.
  11. Bosch A638S. Full set, 650 / 530 cm blades, straight swap from the box with according adapters.
  12. Yeah, will do next time. Curious myself.
  13. 2019 Kodiaq has Haldex 5.
  14. As I use only official dealer services, so unfortunately I don't have any pics.
  15. Official service plan does not contain cleaning at all. But so far 100 000 km has been ok for me, although we have 4 - 5 months snow here.
  16. Important is also to get the Haldex filter cleaned. It really gets dirty and therefore looses the efficience. I have had it done in every 100 000 km.
  17. I believe the Rear Traffic Assist (not maybe by this name, but you know what I mean) uses the same radar. So try to activate also this. Cannot thank enough this aid to avoid Schumachers in the parking lots.
  18. Just a question. I never updated the firmware myself, only the the local dealer. And never noticed any changes on my infotainment. Are there any at all? Or they are just "improvement" updates?
  19. It can mean the camera's sensor is failing. But there could be other reasons as well.
  20. There is an AAWireless app for Android, it keeps your device updated.
  21. Not doable. Passat has bigger screen and different firmware.
  22. Heated windcreen Electric tailgate / Virtual pedal Auto-Hold Absolutely essential for me. In addition: traffic jam assist (needs Lane Assistant) Rear Traffic Alert rain sensor Android Auto Progressive Steering Better sound system etc
  23. I did, but I am an old stubborn son of a bitch. Would like to test everything by myself.
  24. It does have a "staging" option, but it is not functional. Tried only with OBD11. Some day will try VCDS as well.
