linni
Everything posted by linni
  1. Strange, I had this setting in my Superb 2 already as I do have now in Kodiaq.
  2. RTFM There is a setting in infotainment which allows to switch the two - mirror adjustment on and off.
  3. Bluetooth module is under the front seat.
  4. https://en.bsr.se/tuning-kits/t/3639/skoda-kodiaq-20tdi-150hp-2017-2020-dfga https://www.diesel-performance.co.uk/tuning/car/skoda/kodiaq-from-2017-onwards/2-0-tdi-150ps110kw-1968-ccm-21/#go DTUK has better results on paper, but these are for extreme settings and people on internet are complaining that the car wont work flawlessly if settings tuned to maximum. BSR works better anyway, as it is a remap not a box. Sure there are plenty of other tuners out there.
  5. Dual mass flywheels are from satan. I have third flywheel, car has done 260 000 km. First went at 60 000 km. No symptoms, just the dealer changed it under warranty at regular maintenance. Second - what a symptoms! Started just like that.
  6. I suppose the flywheel was so loose that it touched the body of the gearbox, therefore the grinding noise. Mostly, when releasing the throttle or turning to left.
  7. Some had changed the gearbox pad. I had to change flywheel to get rid of the noise.
  8. I understand OP is getting internet through his mobile phone. If you have phone connected to car via USB cable, disconnect it first. DAB radio glitch, not only on VAG cars.
  9. I thought once that too until I found out my car can do things I never knew.
  10. Any bridges above the road? Or branches? Mine tends to brake sometimes on low pedestrian bridges.
  11. Not sure if it could be done with OBD11. I activated with VCDS: Select Control unit 09 (Central Electrics) Authorization: 31347 Adaptation *Leuchte16BLK SLB35BLK SL KC9 Lichtfunktion C16 Value: Tagfahrlicht (default: Not active) Dimmwert CD 16 Value: 127 (defaut: 0) * Leuchte17TFL RLK SRB3TFL R BLK SR KC3 Lichtfunktion C17 Value: Tagfahrlicht (default: Not active) Dimmwert CD 17 Value: 127 (defaut: 0)
  12. Yes cou could join the incar wlan, but it`s worthless unless you install SIM with data plan into SIM module. I have SIM installed, but I use hotspot only when I am driving with some non EU guests to keep their data expenses under control.
  13. WLAN provides data, if you have SIM card installed into card module in glovebox. Assuming it`s a Columbus unit. If no SIM card, it`s just wifi without network connection. Also you have to activate business phone interface in Telephone main menu in car besides installing the sim card. Password can be viewed / changed in menu - wlan - hotspot.
  14. Yes, there is. Try to change also settings. Equaliser to custom. Lows and highs up, mids toalmost zero, in a shape of letter V. I switched off all surrounds and whatever the options were. First months the sound was far worse than my Superb 2 Sound System. But it got better and better and now it`s way ahead of Superb`s sound.
  15. @Trojlee From fresh, they are pretty awful. After some time they become excellent. You have to get their diaphragm to work in.
  16. But you can have one: https://www.kufatec.com/en/skoda/kodiaq/complete-kit-active-sound-incl.-sound-booster-for-skoda-kodiaq-ns7-42370
  17. 503 here also, but no refresh button on home page. Only on Car condition page.
  18. There is no refresh button anymore. Swipe the screen down and it updates to the latest data. Should do it by default, but it usualy doesn`t.
  19. 231 000 km. I have booked flywheel change this Friday. Otherwise brilliant car. No problems whatsoever.
  20. yeah, seems to be my bad. Don`t shoot me please.
  21. I admit there is some confusion about the model line.
  22. Yes, but can you find there 200 PS petrol engine? No. Only the older 190 PS version.
  23. I had one of these boxes on my Superb 2. Pretty good ones. But as you can see, they don`t offer boxes for 2022 models either.
  24. Mine consumes about 1 liter oil between the services and has done it since the very beginning. Do not think it`s possible to remap VAG car produced after 2021. Mine has done here, but the last remap for 2 liter petrol Kodi is for 190 PS one. No 200 PS version. ECU blocked from external access. https://en.bsr.se/tuning-kits/t/4323/skoda-kodiaq-20tsi-190hp-dsg-2017-2021-dkza
