Everything posted by ords
- Cylinder 2 misfire
Diesel / oil leak in engine bay - safe to drive ?
You have a diesel or oil leak and a burning smell and the garage says it should be ok to drive????? Doesn't sound like good advice to me. Anything obvious like an oil patch on the floor or areas under the bonnet that are wet?
How can I change the air filter on my Mk3 Octavia 2017 1ltr?
This is for a 1.4l, but might be of help to you.
Air con not working
I'm doing well with the a/c on my 2013, never been touched.
- Car won’t always start
Spluttering engine on cold start
Is the engine really hotter than normal when opening the bonnet or just the gauge telling you it's overheating?
- Dsg back to manual
Auto scan.
Make sure the option to lock the doors is still enabled
130000 miles
Manual or auto?
Update navigation system
Yours is probably an Amundsen MIB1. As @Lee01 says no official updates are now available You could try this workaround. It worked for me. https://www.briskoda.net/forums/topic/511425-amundsen-mib1-maps-update/#findComment-5837058
window seals
- DPF alarm when towing
What engine & mileage?- Map Updates for Octavia 2015
If it's an MIB1, official map updates were discontinued a few years ago. You may find this thread useful.- Dag allemaal, or hello to all! :-)
So people can help you in the future, update your profile with engine and gearbox type- Can a battery fail this fast?
A four year warranty starting in Sept 2022 will run out in Sept this year.- 1.6TDI Musings How Reliable?
Mines only done 70K, so not had a hard life by any means. Had cam belt and pump done at 8 years old, doesn't use any oil between services, no oil leaks, DSG faultless. All major engine components original. 60 mpg average.- Mk3 oil pressure regulator issue
You've posted in the correct forum for MK3's- Mk3 oil pressure regulator issue
This IS the Mk3 Forum, not the MK4 forum.- Yellow epc and car won’t start
Unless there is a faulty injection system, in normal operation, can you flood an engine these days?- Rear jet washer
Any help? https://www.autodoc.co.uk/car-parts/washer-fluid-jet-10711/skoda/enyaq- Fuel pump and fuel pump control module
https://www.briskoda.net/forums/topic/507315-wont-start/#comment-5697194 The last comment may be of some use- MIB2 Map Data
I had that problem and just deleted a lot of the countries I would never visit.- Octavia revs
- Coolant Consumption - vRS 245 EA888
G12 evo. It superseded G13 - DPF alarm when towing
