Everything posted by ords
- Increase in road tax
Hatchback not unlocking with key
When you just press it, it only unlocks the hatch and you need to use the handle to release the catch and lift the hatch. A long press and the hatch "pops" open. It took me a long time to find that feature.
- Broken infotainment system
Glow plug light on dash, restricted but only in second gear, no codes!
What engine?
Car jerking during heavy rain
Could be something simple like water getting into one of the connectors.
Part no. query
eBay have a selection
Dead battery, cant open passenger door to operate bonnet catch in order to jump start
I'm surprised, you only need to pull it out a little bit to clear the speaker.
I've tried it and it does work.
Hi From the UK, owner of a misbehaving Octavia MK3
You're looking for the "driving data" menu, then you can scroll through the various readings until you find "oil temp" If you don't have MFSW, then use the rocker switch on the end of the right stalk to find the "driving data" menu, then use the same switch to scroll.
Fuse for rear wiper - question from a beginner
Check there's power getting to the motor.
Tyre Pressure Warning - how do I switch it off?
Suggest you check all tyres for the correct pressures and then set the TPMS.
- Rough running at start up.
Which gearbox? 1.5 TSI Combi, SE-L
MCU = motor control unit, also known as a mechatronics unit in Skoda / VW forums. The MCU and the gearbox use two different oils.
What year is it?
Octavia 2L diesel vibration problem
It's electric steering.
Do you get the vibration when stationary and revving the engine to 2000-2100 rpm?
Water leak passenger side Octavia
Do you have a sunroof, they have been known to cause this type of problem?
Error Codes Lights Mulfunctioning
Are the individual items working?
Engine management light..
Didn't realise you're not in the UK
You should be worried, it will fail the MOT
Air Con Service?
My MY13 has never been touched either, works a treat.
- Octavia Estate coolant bag burst
Code P173600
Did you have reverse gear?
Help deciding on which mk3 estate
The smaller engined cars use the DQ200 7 speed DSG box which does not require servicing or oil changes. It's up to the owners if they want to change the oils at regular intervals. I haven't touched mine and its been fault free.
