Everything posted by ords
Alarm
That puts all the security systems in place.
what do you like and dislike about your Octavia?
Looking at my V5C, it's 102g/km and 77kW, also DSG. Seems the higher output engine is cleaner.
I pay £20.00. Am I being cheated?☹️
- Driving modes
Regular service intervals 1.6 TDI 77kw
You can visually check the belt and it may appear ok, but you can't do the same for the tensioner as far as I know. That can fail. If Skoda in your country recommend changes at the figures you quoted then you've got nothing to worry about.
Skoda UK recommend the cambelt is changed every 5 years along with the water pump.
Totally Confused Over Correct Oil
Read this thread. The 1.0L engine is mentioned in one of the replies.
Octavia tapping sound from engine
It would have been helpful if you'd mentioned this in your original post.
Interesting advice on cambelt change
My faith in you is restored😁
Water sloshing noise from behind dashboard
OP says he hears the noise when starting and stopping the engine. Car won't be moving so any water not draining away would not be sloshing around. Going by his comment about air bubbling in the header tank would suggest it still needs bleeding.
Help with dab signal
This thread was started a few days ago.
SatNav help
I thought the locked position was just to stop the card from being overwritten. I'm going to try mine in both positions.
HELP needed panoramic sunroof leaking
- SatNav help
That's why I asked the OP to send a pic of the part no and software version- Mystery object
- Question about the radio
It's possible you have a Bolero unit going by the device part number. See this thread.- Question about the radio
Send any requests for updates here.- Question about the radio
You only need a genuine Skoda card for the satnav if you have it. Any card will do for playing music and updates. How many sd card slots does the unit in the glovebox have?- Infotainment (?) system 2014 Octavia
Scroll to about the 12th post for instructions on the postcode- Infotainment (?) system 2014 Octavia
It's not the easiest of systems to navigate your way around (excuse the pun) but you can just enter a postcode. There are threads on here with details on how to put in a postcode.- Skoda Octavia Mk 3 will not start
There are a few threads about the bonnet release. It's flexible enough to be pulled out sideways to clear the speaker and then pulled to open the bonnet.- Question about the radio
Hopefully someone will be able to answer your question now.- Fuel consumption
You could always carry a heavy duty generator😀- Question about the radio
We'll need to know what unit you have. Best thing is to take a picture of the screen showing the software version.- access when battery is flat ?
My garage is just wide enough for me to get in and out of the drivers door with the n/s almost touching the wall. If the emergency lock was on the passenger door I would have no access to the car. Why is the design bad for left hand drive cars? - SatNav help
