Everything posted by ords
Mk. 111 1.6 Automatic Regen Query.
The OP has now said it doesn't literally go into sports mode. I was just going by what he originally posted.
I don't know what engine you have, but my 1.6 does not change modes. I would not consider that to be normal and I've not seen any other posts about this.
Octavia Scout 2016 - Flip the direction of gearchanges
Are you running it in sports mode? Your box is different from mine, but mine only holds the gears if in sports mode. In D or ECO it's very quick to change up.
7 speed DSG
I used to use eco mode, but now use normal, get the slight benefit of engine braking. Do not shift to neutral as s/s is always used.
Flat battery lock out problem
If you're careful you can pull out the handle to clear the speaker.
Octavia Mk3 vrs TDI - started after 4th try
vrs TDI is mentioned in the thread title
What’s this button?
What happens when you press it?
Rain sensor confusion.
I see. Thought it was a standard fitting in all countries.
Maps Update - Amundsen MIB2 - Format SD car?
If you're worried about formatting the card, just delete the contents, that's what I do.
Mine has I believe just the humidity sensor and under wiper options I only have the auto rear wipe option. The OP should at least have this option.
1.4 TSI DSG - suspecting worn clutch pack?
Have you tried the different drive modes? How does it react when reverse is selected?
Replace third brakelight
Suggest you post this in the Fabia section as your profile says you have a Fabia.
Fans running alot
If it's a diesel, then this thread is for you.
Multiple issues - common cause?
On the last page a charge cooler is mentioned.
Can't find the 'how to' guide on wing mirrors
- Dashboard damaged or fixable?! Help
Have to ask, why were you covering the sign? Not obliged to answer🤐- Multiple issues - common cause?
What engine?- Multiple issues - common cause?
What engine? Manual or auto?- Rain sensor confusion.
Mine only has basic functions, If memory serves me right, the person who fitted my replacement windscreen told me it is a humidity sensor- Battery symbol on infotainment system
Picture?- Octavia mk3 1.5TSI 2019
Manual or auto?- VCDS faults
Is the ventilation system working as it should? Try this as well. https://www.youtube.com/watch?v=MRa6c9UfyEs- Weird Issues with 2019 2.0 SE TSI Auto
Can you get it scanned for fault codes, although I'd have expected the 2 garages to have done that?- Where to find Amperage value for each fuse?
This is also from the link you provided. Colour coding of fuses Fuse colour Maximum amperage light brown 5 dark brown 7.5 red 10 blue 15 yellow/blue 20 white 25 green/pink 30 orange/green 40 red 50- SOS error and Fault Code 1048578 - No Basic Setting
Your profile says Fabia mk1 - Dashboard damaged or fixable?! Help
