Everything posted by djmartzian
Component protection for the infotainment display?
Hello, Read the below thread for more details: https://www.briskoda.net/forums/topic/516103-volume-keeps-turning-up/?&do=findComment&comment=5948038 Good luck
- Blind spot assist retrofit
Volume keeps turning up??
Hello @mmt , Congratulations for your work. Can you share with the community more details about the source of the new display? 1.Is it brand new, OEM, provided by Skoda as a spare part? 2.Is it from an old car, from a junkyard? 3. Please share a link/URL from that site. Thank you
Radio Database update is possible?
Hello @WaveyDavey , Just use a VW part no instead, e.g. 5H0035816 . The below link is the result of the archive that must be used for upgrade: https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.56.zip Cheers
Dynamic turn signal mirror light
Hello @Lukas_2611 , What product did you use to seal the cables? Something similar to: Liquid Insulating Tape Repair Rubber https://a.aliexpress.com/_Eut4iWW Thank you
Mirror Dip Function
Resurrecting this thread with fresh information: https://www.drive2.ru/l/699703637345063567/
Hello @East_Yorkshire_Retrofits , I might need some advised from someone with real expertise on this kind of retrofit. I managed to route the cables through the mirror lamps, but I'm afraid I can't find verified information related to harness connection, especially to T2b pins? 1. Which is "+" signal and which one is "-" ground? Do you have any pictures with the pin numbers? 2. Is the harness connection the same for right and left mirror lamps? Really appreciate your support. Br, D.
Tested and working coding Octavia mk4
@cristianvelicu , Often, after 09-CU coding you need to perform a bus rest. This means you lock the car and take the key far away so that the CAN bus network enters a rest state and at the end the communication resets. Good luck!
Where to throw things in my pockets when I sit?
@vRS 170TDi Cork , Can you share a link with the arm-rest spacer/shelf?Thx
@East_Yorkshire_Retrofits , Thx for the reply! But, it might be easy to add new terminal in a spare fuse location only for RHD vehicles, since the fuse box is located behind the glovebox. For LHD, you don't have access to purple security bold because this is located behind the dash panel, so you don't have enough space to pull the fuse box at least a little bit to work on it, like it was with previous MQB model. I'm not planning to remove the full dash just for this, that's the reason I've asked @Giannis20 to find out his solution. For this retrofit, I'm going to connect the modules via a piggy-back, quick and easy fix. Cheers
Hello @Giannis20 , Can I bother with another question related to this retrofit? How did you connect the power source for the modules/radars? Have you used a piggy-back cable to connect on an existing fuse OR have you tried to insert a new connector for a spare fuse in the Fuse holder C underneath the dash? Thank you
Hello @luccio96 , Apologies but I don't have v1.31.40 anymore. Probably I did a clean-up and deleted the old versions since the update is working fine on Skoda Mk4. I only kept the latest 2 or 3 versions just for backwards compatibility if something goes wrong on an update. Cheers, D
Hello @luccio96 , You can upgrade to latest version: https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.56.zip Good Luck!
Octavia MK4 2022, tail lights and park sensor problems
Hello Guys, TPI2075576x is the TPI no that I found on other related forums, but I'm afraid I don't have any extra details. Can someone with access to ErWin check and post here the full description? Thank you
Retrofit optional extras
Hello @Bennie, With regards to retrofits that you are looking for, please find below related information/tutorials: 1. Blind Spot DYI https://www.seatcupra.net/forums/threads/blind-spot-detection.473190/post-5060818 https://www.briskoda.net/forums/topic/528134-blind-spot-assist-retrofit/ https://www.drive2.ru/l/687276407172112599/ 2. Passenger auto dim exterior mirror DYI https://www.drive2.ru/l/673894526028373793/ Please keep us posted with your progress! Good Luck!
Dashcam - suitable fuse socket?
Hello @beneix, Have you inserted the missing wire in the Fuse Panel OR have you used a piggy-back fuse wire? Thank you
Radio station logos
Hello @Giannis20, You can download the Updated DB with latest Radio Station Logos from the link below: https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.56.zip "Official" MoP: https://www.phonostar.de/download/vw/37W_Stationlogos_CustomerUpdate.pdf Good Luck!
Start and stop disable permanently
Hello @Perb_bug, Can you give us more details? 1. What engine type is running on this car? 2. Can this option work on E-TEC variants too? 3. What production year is this car? Cheers.
SOS Error: Emergency Call Workshop!
Hello @noskillm, You can also try to remove dedicated fuses: 30s responsible for MIB/Infotainment and 19s for OCU/SOS module, for ~20mins. The full restart procedure in the link below: https://forum.obdeleven.com/post/104531/thread Good Luck
How to find exact spec....
OR, @pingpongpete1, you can pay and ask for a digital Car Data document from: https://www.ebay.co.uk/itm/226517872578?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=nGO17j9xSwi&sssrc=2047675&ssuid=b7yi6osrr9a&widget_ver=artemis&media=COPY PS: I don't know this seller, I only used his service, so bear in mind that I'm not indented to do any sort of advertising. Cheers
Flat battery yesterday
Hello @wantaskoda, Can you please ask the dealer for details about the software updates they performed on you car and which module has been upgraded? I'm encountering the same issue on cold morning on first start after the car has been sitting for more that 3-4 days during the Winter period. Thank you. All the best, DN
