MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. still without manufacturer warranty, here is a positive experience with the Eibach Pro Kit from the Kodiaq 2023. Mk3.FL 2.0 TSI 280ps AWD challenge, stiffness without lowering, succeed front Eibach F11-85-043-03-FA + Bilstein B6 DampTronic 23-254343 rear Eibach F11-79-013-01-RA + WRONG Bilstein B6 DampTronic 20-254353 (correct part code would be 20-267537) more info -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
  2. that feature came in final year Mk3.FL too -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5740237
  3. I'm not alone -> https://www.briskoda.net/forums/topic/478335-does-the-sportline-have-stiffer-suspension/?do=findComment&comment=5713073 perfect! 2.0 AWD -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160 2.0 FWD -> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/?do=findComment&comment=5625462
  4. just wait for climate changes before we started i checked two weeks forecast for Bergen, which were cloudy rainy 14-18c in reality just two days i didn't wear a shorts, temperatures in the cities were 18-30c, just in mountains lowest were seen 7c as alternative for Norway i can suggest Slovenia
  5. my picture is from MY23 Mk3.FL, another guess will be Mk3.FL PHEV
  6. @E30Mark cut can be made invisible, here is lost just bottom part of L trim damaged regular, +1.5% oversized, 225/55r17 on 7.5J alloy as spare i took 205/60r17, but currently it is mounted on same 7.5J alloy and it pushes up floor for ~20mm later will replace disc to 6.5J ?metal? with same tire
  7. Yesterday i finished fantastic 3615 km round trip across Sweden and Norway Thanks to the default speed limit 80 km/h, got numbers which i haven't ever seen before - top score on the display were 6.5 l/100km. Calculation for whole trip is 7.8 (36mpg) by filled 98/95 vs kms Keeping to the speed limit didn't save me from being stopped by an unmarked traffic police car, Škoda Superb wagon followed me about 15 kms - they didn't like the maneuver of overtaking a nearly stationary car as driving in the opposite direction Enyaq was still ~500 meters away, i overtook without using the accelerator pedal and returned to my line No fine just papers/trunk check and talking about driving safety (first hour in Norway) . . . . . .
  8. @xess Click on link in my signature and go to the last page, Eibach Pro kit for Kodiaq gives zero lowering on Superb Mk3.FL
  9. @djmartzian Is the content fixed? https://www.briskoda.net/forums/topic/513799-mib3-map-updates-2024/page/2/#elControls_5856739_menu
  10. depends on for what it required, if dashcam, then look also to one expensive alternative (haven't tested by self) https://www.aliexpress.com/item/1005004552011374.html strange, there isn't developed any third side device, which would connect to built in camera's wires in parallel
  11. i don't remember, try add 0 before number
  12. i have seen several reports about replace on Superb and Octavia to Kodiaq -> https://www.drive2.com/l/507863872187663589/
  13. Up/Down + - 10 Km/h Pull + 1 Km/h or ACC/CC On if it were Off side button Set - 1 Km/h or keeps current speed if it is now different as last set Mode button came and gone in between ~ 2018 - 2021 now ACC / simple CC modes can be changed on steering wheel https://www.briskoda.net/forums/topic/511031-standard-cruise-control-on-an-acc-equipped-superb/?do=findComment&comment=5737174
  14. exactly same on FL, and stalk Up for + 10 Km/h, Down for -10 Km/h, Forward turns ACC Off one important note, @Bap33 and me are talking about continental not UK steering wheel i have/had (2023FL/2016Mk3) version without mode button
  15. search for info by part code -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#comment-5854160 another suggestion how to improve sound insulation -> https://www.briskoda.net/forums/topic/481954-lowering-springs-install-on-a-280272-sportline-diy-and-results/#comment-5413309
  16. the same story with extended comments -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5854160
  17. you aren't alone whose conclusion is, all other modes are too soft browse following threads: -> https://www.briskoda.net/forums/topic/478335-does-the-sportline-have-stiffer-suspension/?do=findComment&comment=5850315 -> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/
  18. by compare content? the method how VW forming file name doesn't allow guess it before release 😞
  19. caught new OI_P119_EU_202425_Offline_Update.zip on Škoda's server, BUT content is exactly same as year old P95
  20. -> next 2025 cross compatible on: Skoda Columbus (Mib2H), Seat Navi Plus (Mib2H), VW Discover Pro (Mib2H), Audi MMI Navigation Plus (Mib2H) months ago tested by @Tell size has been hugely decreased if compare to previous, looks like some cleanup in the Mib1 folders, just one example out of many folders - # ECE 14.1 GB Version: V03.959.821.AP 370 ECE 2024/2025 DevVersion: P370_N60S5MIBH3_EU_NT_Q3.23 Mega.nz(copy from Audi portal) https://mega.nz/file/D7gRnTQS#bs1ghZILdz3-DOJ2Vafc9aePn_l9SDbRTJ8jyPslBO4 Files inside: 2023.10.05 Downloadable: 2023.10.13 VW portal: https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P370_N60S5MIBH3_EU.7z VW portal: https://navigation-maps.volkswagen.com/vw-maps/P370_N60S5MIBH3_EU.7z Files inside: 2023.10.06 Downloadable: 2024.05.24 Published: 2024.06.?? Škoda portal: https://infotainment-cdn.skoda-auto.com/base/maps/HIGH2__P370_EU_202425.zip # Rest of World 2024 14.4 Gb Version: V03.959.821.BA 0333 ROW 2024/2025 DevVersion: P373_N60S5MIBH3_ROW_NT_Q3.23 VW portal: https://vw-maps-cdn.lighthouselabs.eu/vw-maps/P373_N60S5MIBH3_ROW.7z VW portal: https://navigation-maps.volkswagen.com/vw-maps/P373_N60S5MIBH3_ROW.7z Files inside: 2023.11.20 Downloadable: 2024.05.24 Published: 2024.--.-- Škoda portal: https://infotainment-cdn.skoda-auto.com/base/maps/HIGH2_P373_ROW_202425.zip ======= coverage ======= # EU Albania*, Andorra, Austria, Belarus*, Belgium, Bosnia and Herzegovina*, Bulgaria*, Croatia, Cyprus*, Czech Republic, Denmark, Estonia*, Finland, France, Germany, Gibraltar, Great Britain, Greece, Hungary, Iceland, Ireland, Italy, Kosovo*, Latvia*, Liechtenstein, Lithuania*, Luxembourg, Malta, Moldova*, Monaco, Montenegro*, Netherlands, Northern Macedonia*, Norway, Poland, Portugal, Romania*, Russia*, San Marino, Serbia*, Slovakia, Slovenia*, Spain, Sweden, Switzerland, Turkey*, Ukraine*, Vatican City * partially # ROW Argentina*, Australia, Bahrain, Botswana*, Brazil*, Brunei*, Chile*, Indonesia*, Israel, Jordan, Kuwait, Lesotho*, Malaysia, Mexico*, Mozambique*, Namibia*, New Zealand, Oman, Philippines*, Qatar, Reunion*, Saudi Arabia, Singapore, South Africa, Swaziland*, Thailand*, Turkey*, United Arab Emirates * partially ======= instruction ======= 1. download 7z/zip archive from direct link 2. extract content to SD Card or USB 3. insert memory device into slot of Columbus 4. start of update usually is offered automatically, manually can be found under Navi-> Settings !!! note for MAC users -> https://www.briskoda.net/forums/topic/452002-direct-download-links-for-ece-20182019-maps/page/2/?tab=comments#comment-5095042 couple of potential questions are answered in previous posts: Columbus Maps 2024 Columbus Maps 2023/2024 Columbus Maps 2023 Columbus Maps 2022/2023 Columbus Maps 2022 Columbus Maps 2021/2022 Columbus Maps 2021 Columbus Maps 2020/2021 Columbus Maps 2020 monthly POI's collection files downloading from X-o-m-k-a's blog
  21. add to @JR RS collection of useful links -> https://www.briskoda.net/forums/topic/478335-does-the-sportline-have-stiffer-suspension/ -> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/
