MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. @breaddownunder check FECs list installed in your head unit (in one of sections under hidden menu, long press Menu button -> . . .) # Škoda MIB2 NavDB LifeTime fsc17 = "083000FF" # EU fsc18 = "083D00FF" # ROW if last numbers aren't FF, then there has been set max year
  2. +1 especially when we can enjoy one of the last VAG car with normal gear selector stalk, by which DSG Sport mode is under your hand, just by one push back
  3. previously i have reported about Mid3 compilation contains less relevant pictures, that weren't correct info - in later experiments, i got this how to, for logos which are changed: 1. them must be deleted from Menu -> Logos 2. reboot head unit by long press of power button 3. add new logo under Menu -> Logos
  4. @Tell i have add also Phonostar adreses to my maps updates daily checking script can you share release with Seat devices support? also, have you made research from which version they have changed aspect ratio from 3:4 to 1:1, for Mib2 devices it isn't optimal at all
  5. Control unit: B7 Start System Interface System description: VWKESSYMQB Software number: 3Q0959435Q Software version: 1400 Hardware number: 3Q0959435Q Hardware version: 037 Serial number: 061244xxxx ODX name: EV_KessyHellaMQBAB ODX version: 004055 Backup name: Start System Interface Long coding: 1F20000723
  6. PFA - Rough road package in Latvia also were extra, it's different story as Scout and from owners reports, it is annoying soft, when standard suspension is just lite bit too soft
  7. @brsk have you coded both? for me it's working also from door handles, key fob in pocket, outside of car
  8. check out also shifter from Kodiaq, have seen several reports about replace it on Superbs and Octavias
  9. this is an important argument tire i had to buy because had none and have to finish winter season on it, i chose one, which pass in width, 205/60r17 Dunlop Winter Sport 5, but mounted it on 7.5J alloy, just because had one left from previous car, as result, carpet is pushed up about 2cm and i thinking about replace disc to 6.5J
  10. if your's isn't 272/280ps version, you can simply replace tire and leave OEM 16"disc -> https://www.briskoda.net/forums/topic/520234-superb-mk3-spare-wheel/#comment-5817816
  11. @Beerhunter17 Mib3 if device has USB Type C Mib2 if maps are stored on SD Card in Glove box
  12. Navigation database: 23.2 (factory 2023.02) 23.9 (OTA ~2023.10~) 23.10 (OTA 2023.11.28) 23.11 (OTA 2024.01.0?~) 23.12 (OTA 2024.01.2?~) next will be offline updates in my ŠS
  13. @Dieselgate all season at least - at first case in far 2017. i mounted regular noname 205/65r16 summer tire, and i didn't had to use it. then, one year ago, i moved it from 2016. Mk3 220ps to 2023. Mk3.FL 280ps and when came this "waited" moment i noticed 16" rim is too small for 280ps even on the rear axle. had to bought new spare tire 205/60r17 Dunlop Winter Sport 5 1. branded, because will have to use it for several months, can't order anywhere 225/55r17 Michelin Alpin 6 in the midle of season 2. winter, because happened in December
  14. how do you think, do i had a plan to use spare wheel for several months long? i simple can't buy new winter tire in the midle of season, all dealers suggested wait autumn, and cross fingers, about same tire model will be available again just one case of use of OEM fitted 205/55r16 gave me conclusion it must be replaced by full diameter spare wheel and when there is none, i can't see any reason to chose these wrong OEM sized, when there is space for full diameter spare wheel
  15. have you clicked on link i posted above? this warning is formal, it is identical on OEM spare wheels 205/55r16 and 125/70r18 by huge width difference i can guess, one or both of them lie but yes, the only more or less safe position where mount OEMs is rear axle 125/70r18 as must 205/55r16 as recommendation currently i'm two months on 3x 225/55r17 and one 205/60r17 on rear axle will have to finish this winter that way, because can't order anywhere replacement for damaged Michelin Alpin 6
  16. @odd your question has been answered 100+ times -> https://www.briskoda.net/forums/topic/520234-superb-mk3-spare-wheel/#comment-5817816
  17. @Ed666 use search instead create 101. equal thread -> https://www.briskoda.net/forums/topic/520234-superb-mk3-spare-wheel/?do=findComment&comment=5817816
  18. please share info about "Outlet" mms and pictures from side before and after like example in third post, which are from my previous Mk3 2.0 TSI 220ps FWD now i searching 30 mm higher for current Mk3.FL 2.0 TSI 280ps AWD front axle will got a tested Q2 springs
  19. @globalste for front axle F11-85-043-02-FA will be ok for rear, chose one of these, and share us result 11-79-013-01-RA 11-85-016-10-HA 11-85-026-03-HA 11-85-011-01-HA
  20. @globalste third post, Eibach stiffness without lowering
  21. @mitchec new options came in infotainment asistents menu marked red choices don't work
  22. @Gizmo Stars - how useful for me ??? - i can't notice improvement or changes NOK - doesn't work or adds err
  23. Tested codings list, OBDEleven Gen 1. and Superbs Mk3/Mk3.FL -> https://www.briskoda.net/forums/topic/516414-vcds-options-on-superb-iiifl/
  24. similar conclusion, when compare 2016. Mib2 High Columbus Canton to 2023. Mib3 Amundsen Canton overall yes, but far from perfect - low mids now are richer, but the high frequencies are smeared, sounds like additional compression artefacts, even on FM stations, where highs are cut by broadcasting standard
