AGFalco
Everything posted by AGFalco
  1. From memory and looking at the Autodoc pictures I can't tell if you do or don't need them. This is what they look like: - https://www.skoda-parts.com/spare-part/1s08109879b9-adapter-skoda-42103.html Thanks. AG Falco. PS. same colour as our Citigo, nice.
  2. Photos, how to guide and list of parts I used in this post : - Thanks. AG Falco
  3. Facelift version? Rust around the fuel filler cap especially inside the wheel arch. Any Skoda service History? Thanks. AG Falco
  4. Anywhere near N Dorset? Thanks. AG Falco
  5. They are clipped on to the battery top. One either side. Look here: - https://www.upownersclub.co.uk/threads/battery-upgrade-part-1.17776/?post_id=187994#post-187994 Go to the top and look at the third photo down and the description below it. Numbers 10 & 11. HTH. Thanks. AG Falco
  6. AGFalco replied to a post in a topic in Škoda Kamiq
    Mine is an October 2023 car. Maybe just early enough, lucky me. Thanks. AG Falco
  7. AGFalco replied to a post in a topic in Škoda Kamiq
    It can be programmed out, for the car to then remember the last state it was in. I used OBDeleven to do this. Thanks. AG Falco
  8. AGFalco replied to a post in a topic in Škoda Kamiq
    On one of mine I have set the car so that it remembers if the lane assist was off last time the car was running. So when you start the car again it is still off. I can still turn it back on if needed. ( Never ) 😃 Thanks. AG Falco
  9. I ment opposite rear side light bulb. Some times they are on the same fuse. Thanks. AG Falco
  10. Not for one bulb, I would think. Does the other side DRL bulb work? If so, swap them from side to side. Does the opposite side REAR bulb work? Thanks. AG Falco.
  11. Was the Battery coded to the car? Thanks. AG Falco
  12. Which headlight unit have you got? I presume the 1 x H4 unit. Are you sure it is a W5W bulb as I thought that was for the parking/side light bulb? HTH. Thanks. AG Falco
  13. Speed sensor broken? Poor Battery? Can you scan the car? Thanks. AG Falco
  14. Does the tyre pressure sticker plate list the tyre sizes. Skoda KAMIQ: KW:70>110 Vin:NW Year:19 - Caliper: PCD:5x100 GVW:1750 Max Speed:195 Kerb Weight: NutBoltThreadType:M14x1.5 NutBoltHex:17 BoltLength:27 NutBoltTorque:120 Tyre Load Speed Norm Press Laden Press Rim Size Offset Cent Bore RunFlat Extra Load Track Max RimWidth F: 205/65R16 95 H 6 x 16 38 57.1 8 R: 205/65R16 95 H 6 x 16 38 57.1 8 HTH. Thanks. AG Falco
  15. Try one first and see if you need a tool. I have done the spark plugs on my Fabia III TSI three times and on my Citigo twice. Never needed a tool, never had a problem. Thanks. AG Falco
  16. So Daughter has been complaining of- A hot left hand / face during the summer and cold during the winter, so I came up with this: - Works well. Thanks. AG Falco
  17. Get them to order from TPS. https://tps.trade/ Thanks. AG Falco
  18. Clean the window thoroughly first. I have used a little french chalk / talcum powder, which worked well on the rubber bits. Thanks. AG Falco
  19. You can look at both flaps to see if they are in the correct place. One above the passengers toes should be flat closed, when not in recycle mode. One is under the bonnet scuttle panel also on the passenger side. This should be open when not in recycle mode. I operated the recycle button and watched the flaps to check they were ending up in the correct place before I fully refitted everything. When in recycle mode, the footwell one should be open, and the under bonnet flap closed. HTH Thanks. AG Falco
  20. When did the second owner buy the car? 2023? Any service history/ invoices? Thanks. AG Falco
  21. Have you checked the MOT history? Thanks. AG Falco
  22. Had the car 10 Years from new and the car is now at 97500 miles. 10th Service and Seventh MOT done last year ( 2025 ) with nothing to report. 11th Service and Eighth Mot done last week (2026 ) with nothing to report. Still only had one MOT advisory in its life. Car is still on original brakes all round, original clutch, & battery. Apart from normal servicing it has wanted: - Lower front suspension arm rear bushes. ( the MOT advisory ) Passenger front electric window fuse! A look at / fix the AC recirculation flap motor housing. Lower front grill, that was both chewed by a rodent and head butted by a pheasant. Inner wing O-S-F plastic cover for access to headlight bulb that went AWOL. 3 AC re gas refills. Tyres, which do about 30K miles on the front. Some headlight bulbs. H7 Osram Nightbreaker's. Wipers front and rear. Engine consumes no oil between services and can still do above 60MPG on a good tank. Still like and plan to keep the car. Thanks. AG Falco
  23. Turn the steering wheel full lock, so that the TRE is outside the wheel arch. Use a long spanner and gently tap the other end with a mallet. HTH. Thanks. AG Falco
  24. Part was made in Spain! HTH. Thanks. AG Falco
  25. Did mine today. First clue for me was the 'Clack, Clack, Clack' when going from recycle to fresh. The two screws on mine were both a 15 Torx and 5.5mm AF head in one. Would agree with @cliveb on removing the wire connectors on the glove box. I have OBDeleven so I can/have reset the Air bag light. And also cut the cable tie so that the motor assembly can be pulled down to undo the wire connector. I then pulled the assembly out. It looks like the same problem as @lewiswal47 and others have had. The Black cog has moved and opened the motor housing case apart. Also note that the red gear has gone past the stop point. My solution was to regrease, reassemble and then Cable Tie the housing back together. It is in the bottom right in the photo above where it pops apart. So made sure the cable tie was around the housing at this place. Now reassembled and all working with no 'Clack, Clacking' any more. Thanks. AG Falco
