Everything posted by AGFalco
Brakes pulling? VERY expensive repair
I have a 2016 1.2 TSI Fabia at 95K miles and I am on original brake all round. Have you got the brake figures from the MOT test? Is one brake sticking on or is it not working? ( which one? ) Is the ABS light on? Have they checked / replaced the flexi brake hose? Thanks. AG Falco
- Newby question- can i put steel rims on my Octavia
Smart link Retrofit
Ask @pab567 Thanks. AG Falco
P0441 Next Steps
Look here : - Thanks. AG Falco
Heated door adjustment control for Fabia MK3NJ ('19)
My Peugeot was like that as well. Thanks. AG Falco
Å koda Fabia mk3 spare wheel size help
Yes. Yes. Just PM me. Thanks. AG Falco
Not with mine. They work independently. Thanks. AG Falco
That is how it works. Do the heated mirrors work? Thanks. AG Falco
Yes, as a temporary spare it would be good. Thanks. AG Falco
Best Windscreen Wipers for Fabia
Bosch wipers for me as well. Thanks. AG Falco
Superb 4 2.0 tsi 265 hp - battery issues?
When charging you would expect closer to 15 volts. Do you connect the charger to both battery terminals? Do you lock the car when not using it? Thanks. AG Falco
N-S-F electric window fault
Hi All, So my N-S-F electric window has stopped working. I can hear a click from the electric motor when I use either drivers or passengers window switch. I have removed the inner door trim. With the electric motor removed but still electrically connected I still hear just the click when I use any window button. With the electric motor removed from the door the window can be pushed up and down easily and it sounds all good. So I am now assuming that the electric motor is at fault. Should you be able to turn the white plastic gear in the centre of the black rubber seal? Is there a way of testing the motor, perhaps by applying 12 volts to it. There are 6 electrical connections on the connector block, three large flat and three small pin shaped. Any idea which ones to use? Thanks in advance. AG Falco
Actuator problem - told only solution is replacement of entire turbo charger
BMW presently make cars in 31 factories, in 15 country's ( including the UK ) on 5 continents, With the largest manufacturing factory being Dingolfing in China. Thanks. AG Falco
Actuators are like muscles, use them or loose them. Thanks. AG Falco
Skoda Citigo 1l
Try fuse 39 - Control lever under the steering wheel, front and rear window wash. Thanks AG Falco
- Access to erwin Skoda
Stranded from an ASS event (Fabia MK3 2016, DSG, 110 TSI)
My 2016 1.2 TSI MT5 came with an EFB battery, which is still in the car at 94K miles. I also wouldn't expect to see an AGM battery in a 2016 Fabia. Because the battery SOC varies a lot on a car with Stop Start they don't show the SOC % any more. Have you seen this post : - Thanks. AG Falco
- 6V0 035 869H
WARNING! Bosch oil filters for 1.2 tsi EA111 CBZA/CBZB engines
Which engine have you got? That filter look more like an F 026 407 143 / P7143, that fits a 1.2 TSI CJZC EA211 engine with a cambelt to me? https://www.opieoils.co.uk/p-117736-bosch-oil-filter-f026407143-p-7143-fits-audi-seat-skoda-vw.aspx?variantid=212189 Thanks. AG Falco
fuel efficiency on my 2015 fabia
Are you driving up all those hills? 😄 Only got 55 MPG / 5.1 L per 100km from my last tank. 2016 5 DR Hatch 90PS 1.2 TSI 5MT 94K miles, Winter Tyres. E5. But my regular journey is 12 miles / 19 Km in the country. Oil can take most of this journey to warm up fully. Bedankt. AG Falco
- Fitting rear wheel arch liners - my experience
Citgo brakes "sticking"?
For the last 100 metres of the journey I will gently apply the handbrake, when it is wet. Also I have found that going forward first works better, after parking. So if you park on a drive or in a parking bay, always back in. Thanks. AG Falco
