Warrior193
Joined
Last visited
Currently
Viewing Topic: Issues with Mk 4 1.5 TSI
Expansion tank contains silica? Skoda Fabia 2018
Welcome to the forum. Usually the OEM EV is marked 'Mit Silicat' if they were fitted with the Silicate bag (or later) plastic dispenser. It's possible that EV is not original. If the bag is present, it can usually be seen if a light is shined through the EV wall, especially the double-walled type - the plastic dispenser should be visible by removing the cap and looking at the bottom - I'm not aware of any issues relating to the plastic dispenser type though. To be certain, why not just replace the EV for a new one when you change the coolant to G12evo?
- Buying a skoda 1.8 tsi elegance 2013. Does this engine sound ok?
Changing spark plugs - silicone paste
Extremely unlikely that the VAG product has any 'magic ingredient' in it, just buy a reputable silicone grease.
Welcome to the forum. Is this private or dealer sale? What is recorded mileage, does this match MOT history? I don't hear anything particularly unusual with that recording, possibly a little 'tappety' is there any record of excess engine oil use? Strongly suggest getting an independent vehicle inspection though.
Coolant loss - 2016 2.0tdi 190ps
Extra radiators will likely be for oil or aftercooler.
Changing Tyre Sizes on Fabia Estate 1.4 petrol VRS 2013
Welcome to the forum. Provided you do not mix tyre sizes, ABS won't be affected - but a change in tyre rolling circumference will affect the speedometer reading to some extent - check a tyre site like 'Will they fit' and enter old and new tyre data. Manufacturers are usually mandated to set speedo to read high - so up to a 5% tyre circumference increase might actually make the speed reading more accurate.
Hi From Brisol (UK)
Welcome to the forum. I thought the Superb was actually biggest in class for rear space.
Noisy car ...
Could well be a loose baffle in one of the exhaust boxes.
- HELP! Hot brake AFTER changing caliper and flexi-hoses
Fabia Fault Codes (Just purchased car)
@joeninho Have you had any resolution to this issue?
2015 VRS TDI - Coolant loss from expansion tank
Great work, but could you explain what you mean by engine 'canting'?
- Unintended vehicle movement causing collision
Skoda approved purchase, but only had one key. Full refund?
@riby Did the dealer provide a second key FOC?
Insurance renewal
Most of the proposals I've seen do ask if cover has been declined by others. I've only been declined once, that was for a vehicle that had been a previous constructive write-off with only cosmetic damage. Probably best to declare it.
2017 Octavia VRS Oil Consumption
Welcome to the forum. Strongly suggest you 'pull the stick' more often until you get a sense of how much it's using - the TSI (EA888) engines, early ones particularly, can have a bit of a thirst for oil. A litre in 2K miles might be a bit high.
- Error code advice please
Oil consumption ?
As E13 says above, engine is much better served if driven-off very soon after start - and driven reasonably gently until up to temperature. Coolant and oil will get up to operating temperature faster if this is done, bore-washing and wear will also be reduced.
Oil consumption ?
I consider it unrealistic to expect zero lube oil consumption in any engine, no matter what materials and tolerances are used. I suspect an analysis taken of oil from an engine reportedly using absolutely zero oil would reveal that the fluid drained was in fact not 100% lubricating oil.
Oil consumption ?
I'd consider 1 litre of lube oil consumed in more than 11K miles a very reasonable usage rate. Is this a diesel hybrid? How much did you get 'stung' for the oil - consider buying the correct grade from a reputable online seller, in 5 or more litre quantities for topping-up between oil changes.
Side lights
Side (or 'marker') lights aren't intended to 'light up' anything - they are a visual reference for oncoming traffic and pedestrians.
Faulty Infotainment System
System information is displayed on the screen in 'settings' I think.
- Clutch pedal
Side lights
I believe those are LEDs, I think very unlikely to be as simple as 'changing a bulb'
