How are your EFB batteries holding up?
My late 2015 (MY16) Octavia had the battery (AGM) and alternator replaced under warranty in mid 2016, the EFB fitted then currently tests as 89% health at 82% charge (DIN) with internal res. of 4.61 milliohms. Due to frequent short trips, I use external charging when SS stops operating consistently - usually around 2-monthly during winter.
Original battery probably another covid victim - likely completely discharged during layup and just left like that, resulting in serious hard sulphation.
Low remote battery at 2.97 V ?
Welcome to the forum. Fob uses a single 2025 or 2032, 3 Volt button cell. The 2032 has a larger mAHr capacity and is a little deeper in cross-section than the 2025. Older fobs used the 2025 - but it was often possible to squeeze a 2032 in.
Clutch won't disengage (but then it does)
@jonathan.tong Did you find the cause of the problem ?
From memory, anything below 8 mOhms is ok.
38% health while SOC at >95% is pretty low and tends to suggest your battery is suffering from hard sulphation - which will probably not be fully reversible. Internal res looks OK. A recovery charge programme may help, but approaching winter could well finish it off.
Clunky Gear Changes
If your Company has one, get the fleet manager to pressure the stealer - surely in their interest to ensure no further damage to transmission.
Clunky Gear Changes
Very unlikely there is anything you would be able to do yourself, best advice would be to get a DSG specialist to check it. Do you know if this is a DQ200 (dry clutch) unit ? Correction regarding a specialist - at 20 months old, this should still be under warranty, shouldn't it?
Clunky Gear Changes
Is this a DSG Gearbox ?
Skoda Fabia 1.4 oil problem
I don't understand your comment in your first post - 'oil pooling under rocker cover' do you mean the oil was not draining back to the engine sump from the top of the engine ?
I really don't like the sound of 'overheating warning and smoke from under hood' ! How many miles since last top up had it done to use more than 2 litres ?
- 2019 Headlight and windscreen washer faults
Radio cutting out new starter motor
I'd suggest having the battery properly tested first.
My Car
Welcome to the forum. SWMBO has a MY18 Fabia similar to you - but with the 1.0TSI 110 engine and in silver.
- Which all-season tyres are you running on your Octavia?
Assuming the wire connector is female, the best idea would be to replace the connector - being careful not to shorten the wire too much if slack to loom is limited.
Check the battery voltage while engine is being cranked - likely that voltage is dropping too low during engine crank.
Chime after locking and unlocking car
The sign-off message is probably 'Check Safelock' - which is serves as a reminder to the driver not to lock in any passengers who remain in the vehicle.
- 2016 Mk3 Octavia vRS 2.0: windows fog up badly after 20+ minutes of driving, no leaks found
Check oil level warning - level seems fine
Where exactly is the oil level on the dip stick (if fitted) when checked correctly?
I see that you have a TPMS warning up as well.
Welcome to the forum. Are you sure the indication you are seeing is low oil level - or could it be low oil pressure ?
- Škoda Approved Used – should outstanding scheduled maintenance have been completed before sale?
