Everything posted by wiilydog
06 TDI change DSG oil?
If it hasn't had its dsg oil changed at 160k then it needs doing as it needs changing every 40k
Remap for 1.9 PD 105BHP 2006
If you are after a good tuning box I highly rate synergy PD tuning box. They are made by a guy called Ron and are made in the UK - anyway the guy is really friendly and happy to answer any questions you may have before you buy. https://www.tuning-diesels.com/store/SYNERGY-4-PD-FOR-AUDI-SEAT-SKODA-VW-p143650062
Would a new caliper O seal sort the problem of piston not winding back?
If you have TRW calipers the pipes will fit as golf Mk5 shares a lot it's components with the Skoda Octavia with it being part of the same VAG
Is this what you are after https://www.ebay.co.uk/itm/123921054659
Xenon bulb recommendations
Yep reg tool is wrong as I put in my reg and is showing as D2 instead of D1s which I know is incorrect.
D1s will be the correct ones for pre-facelift Octavia and can't go wrong with osram bulbs https://www.autobulbsdirect.co.uk/d1s-osram-original-xenarc-standard-replacement-35w-4100k-xenon-hid-bulb.html Just stick to the big online authorised resellers and avoid e-bay as plenty of fakes around
Torque for caliper bolts?
If you brake reservoir is now completely empty then yes, air would of probably got into the abs system, but if it was a slow leak and you still got fluid in the reservoir then you might be fine. But good news is that if you have smaller rear discs then you don't need to faff around with the carrier bolts as they can be a pain to remove. If you brake reservoir is now completely empty then yes, air would of probably got into the abs system, but if it was a slow leak and you still got fluid in the reservoir then you might be fine. But good news is that if you have smaller rear discs then you don't need to faff around with the carrier bolts as they can be a pain to remove.
unless you have completely drained your brake reservoir dry I can't see air going getting into abs system, so just will need a normal bleed for when you replace your caliper. by the way did you manage to find out your exact rear brake disc size as some lower engine models have smaller discs than 260mm discs and you can get away without removing the carrier bolts to change the brake discs
You will probably have a spongy brake pedal but you don't need to touch any of the brake hoses to replace your brake discs
Weird pink headlight
As above you need to replace your bulbs as hid bulbs do go pink with age.
Carrier bolts are 90nm + 90 degrees, note they are stretch bolts so you should really get new ones each time they are removed. Caliper pin bolts are 35nm
Which socket to remove rear brake caliper mounting bracket?
M14 spline bit is the correct size for removing these carrier bolts https://www.ebay.co.uk/itm/US-PRO-1-2-DR-Spline-Bit-Socket-M14-X-55MM-3399/143043245459?epid=4026859259&hash=item214e0ab593:g:z3oAAOSwK1RcCow9
- Can I use either 256mm or 260mm brake discs?
Can't see there being any difference between estate and saloon brake set up, important bit is the diameter of the discs. If in doubt double check the part numbers against the manufacturer website.- Can I use either 256mm or 260mm brake discs?
I would fit 260mm ones if that is the original size. I fitted Ebc ones which are 260mm to mine which is a for a Pd140 2.0tdi- Replacing Front Springs
You can also double check the part numbers yourself on the Kilen website https://www.kilensprings.com/springs-catalouges/onlinecatalogue.asp- Replacing Front Springs
As long as you match it to the Kilen parts catalogue to your car you will be fine. I only fitted one front spring and it was a perfect match as I know you are suppose to replace them in pairs for best results but I didn't have an issues.- Replacing Front Springs
I've used Kilen springs before and they are same quality as original at fraction of the price and still rust free after 5 years.- 17mm / 22mm deep drive socket for strut top nut
best not to use an impact gun on the top nuts as the shock has delicate parts inside that can be easily damaged by an impact, only ok to use on old shock that you are planning to replace with new ones as doesn't matter if the old shock gets damaged a ring spanner and mole grips should be fine for the rear - Can I use either 256mm or 260mm brake discs?
