Tell
Everything posted by Tell
  1. It's called a CID. It's a technique used to eek out value. You can buy another off eBay when it stops working. Originally they were 16gb but then the map cartography grew so to get all of Europe you need a 32gb card. You use the published zones for the 16gb card. A Google of eBay mib2 standard navigation mapcards will throw them up. Dealers did or do sell them but cheaper off Ebay. You just pop a new card in for Skoda. The CID on it is interchangeable between VAG brands so it doesn't have to be a Skoda card. You can also clone the CID off an existing card onto "gold cards" which have re-writeable CIDs but your disk controller has to be on the motherboard for that... a lap top. Gold cards cost more than an eBay cards and you need special closing software, so not worth it. Alternatively retrofitters sell software to take off the firmware element by hacking it. Cost again... might as well buy a Vag card. Lastly mib2 toolbox again technical, hacks the firmware.... so just invest in a spare 32gb vag card of eBay with a well scored seller. I got three cards. The original 16gb Seat one. 32 gb Skoda and a gold card I cloned for the hell of it to learn the process. Others toy with the toolbox. Just buying a 32gb Vag card off Ebay saves hacking anything. It's the easiest and cheapest solution.
  2. Think I'll pass on that question... they use ODIS which is the Vag system so you find somebody to do it for you. It's like the early days of mib2 high where modifying the firmware was something that you had to pay someone to do. The impression I get now is the boxes are much better locked down. Previously mib2 highs they put on the bench and rattled through a sequence of passwords to get into them. There is no reason why entry to the boxes system isn't SLA protected as the rest of the firmware, maps and radio logos. Which has a high level of protection, they just didn't put that on the backend in mib2 highs why they got hacked by retrofitters and hobbyists. Then the mib2 poi import was found not to be locked down in any form by placing code after the import. That spored all of the toolboxes. If you see mib3 toolboxes then you will know they have cracked it. Otherwise it's paying someone to use the official systems. It could be they have found how to access the backend, if so they didn't provide very good security to stop retrofitters tinkering. This one BTW https://github.com/jilleb/mib3-toolbox Is a place marker without any code so I surmise no GitHub projects. The guy who I believe I located on Briskoda says he's retired now and the Google doesn't turn up anything now: https://www.google.com/search?q=mib3+toolbox+github&client=firefox-b-m&sca_esv=214c5f27b0d18acb&sxsrf=AHTn8zoB9LCNRpM-JZLTEsv_oMDPEpTm-g%3A1742939497500&ei=aSXjZ6KhHsilhbIPlK2qmQs&oq=mib3+toolbox+github&gs_lp=EhNtb2JpbGUtZ3dzLXdpei1zZXJwIhNtaWIzIHRvb2xib3ggZ2l0aHViMggQABiABBiiBDIIEAAYgAQYogQyBRAAGO8FMgUQABjvBTIFEAAY7wVIwU5QvA5YnkFwAngBkAEAmAGGAaABvAaqAQM1LjO4AQPIAQD4AQGYAgqgAtEIwgIKEAAYsAMY1gQYR8ICBhAAGBYYHsICCxAAGIAEGIYDGIoFwgIFECEYoAHCAgcQIRigARgKmAMAiAYBkAYIkgcDMy43oAfJJLIHAzEuN7gH_Qc&sclient=mobile-gws-wiz-serp So I reckon the hobbyists are out of it now.
  3. As it happens a Turkish guy is posting on Seatcupra like you. Seems the cars are sold prepped for navigation. You need to check with a retrofitter. Probably for legal reasons they don't come with the map enabled. In there case a retrofitter enabled it. They were irritated that the dealer had one on display with nav but sold without. Seems common. You need the navigation FeCs activated if that's the case.
  4. It's also done on part number so they can leave off the part number by accident. That was an old Vag thing with POI updates. This only works with VW and Skoda anyhow. Not Seat / Cupra. What was the car model, year etc to see whether anyone else has had success. Btw those usb c to a converters sometime cause issues. Some are not fully wired for data.
  5. Other than that it's formatting and unzipping, correct placement in the root... etc etc. Like the old mib2 highs on map update mess up the unzip, use 7 zip, not placed where it should be. Dah, de, dah. Use CleanMydrive if using a MAC....
  6. There is an infotainment system screen that tells you the release code of each component. We have had people in the past trying to update when they had releases above the file they were trying to install.
  7. Is the current radio release seriel number on the unit the same as or greater than the update file ?. It wouldn't do the update in that scenario.
  8. You need to check the infotainment unit model to see whether it was built with satnav. No satnav and you won't get it. Even if it has you may well find it can't be activated without a dealership. Some files and modules about turning US into EU or vice versa. Leaked files reported here. I get the impression that little head way has been made but if they have its on other forums. It's all locked down with encryption as it never was in mib2.
  9. For what it's worth I think there are mib3 units sold without navigation outside of "Europe" they seem to have turned up on Seat boards. They are a bit like the old mib2s that never had navigation built in called media units from memory, if it's one of them you are stuck. As per the question above... the next question these guys then ask is for a firmware update 🫣. The old SSPs that covered mib2 units covered them, suspect if there is an SSP in mib3 you'd see them.
  10. Reckon it will always be like that. A built in wind up of mib3 after they closed the door of importing your own. You could work on the basis that if it's in the phonostar app it should be in the logos. Have Android TV app loaded. If they don't provide that radio service as an Internet service then it's highly unlikely I reckon to be in the logo database. VAG ride on the back of their work for Internet radio provision using their logo management... well that's what I reckon.
  11. You could work on the basis that the mib2high icons are the same. They can be extracted and looked at via SQLITE as I recall. The mibsolution people load those back into their own apps for mib2. That's one way of checking whether your radio station logo is there. What MartiniB suggested in one conversation. Either way it isn't an update but a complete refresh. A replacement. I've looked at them when conversations come up about missing logos. Afraid mib3 is the pits for this, mib2 you could back fill the missing stations yourself.
  12. Tell replied to RodDuggan's topic in Skoda Karoq
    I only code things that are not obvious. Stop / start I revert back when it serviced. Mind you I did mess up the maps, being a Seat mib2 high they don't have life long Mapcare like Skodas. Learning curve then. Nobody really knew then. It appears mib3 firmware is more complex so user modification isn't a good idea... I reckon. Map updates are fine but adjusting the firmware is more problematic. Connect services if available in the country take care of firmware updates and you can always go back to the dealer if it fails. Outside of Europe where connect services don't exist DIY on firmware updates can be problematic.
  13. Tell replied to RodDuggan's topic in Skoda Karoq
    Fingers 🤞
  14. Tell replied to RodDuggan's topic in Skoda Karoq
    For what it's worth on 5 & 6 I did posted all the navigation PDFs on this post if its a question of interpretation. https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib3-satnav-offline.472408/ Given you'd got the firmware in I assumed you'd probably mastered unzip the navigation file correctly. You use 7 zip ideally to unzip. You have to get the files in the route. As far as looking for the original file you could probably pick any file before or at that date in the Vag group. Mib mapcare works by allowing you to install upto and before so if it's that. Before your original map would be fine if you can find a mib3 map before that period. Also on that other thread we were told how to read the mm.yy which might come in use when looking for files if you need to go backwards before going forward. You do this looking on a separate file copy so as to not corrupt the good copy.
  15. Tell replied to RodDuggan's topic in Skoda Karoq
    As well as that it may need the Vag mothership being told the firmware was swapped continents why AA etc has vanished. In other wards the FeCs have been wiped. So yes the firmware used is important. On MartiniB main thread people have come along trying to get European cars with Mib3 working in Africa. Old chestnut with mib2. Mib2 high no maps. Mib2 standard you could adjust the map file to work. Can't do that with mib3, SLA locked. It seems there are package modules that can change Europe into America but one to do that for Africa hadn't been found. This will be all closed information and files leaked out from Vag. Wrong firmware on the unit may render the FeCs... enablement switches off. There is a mib enthusiast group that lurks on a message board might be able to help. Probably those files are coming from them posted up on Mibsolution but without the documentation. As is the way that website operates. They are lifted off the Vag dealer systems but the notes don't get published with them.
  16. Tell replied to RodDuggan's topic in Skoda Karoq
    Well the firmware files are only suppose to be used by dealers with the release notes they get on their intranet system. Probably some instruction not followed. You might need vag systems. Over to an expert.
  17. Tell replied to RodDuggan's topic in Skoda Karoq
    Also photographing the FeCs before and after would show you what changed.
  18. Tell replied to RodDuggan's topic in Skoda Karoq
    Probably the navigation FeCs. Generally you'd have been better not to have updated the firmware then the only question would have been getting the navigation map in. It's the firmware update. You might be better off posting on a firmware thread. There is the normal stuff about loading in the maps etc. Not sure whether a firmware update deletes the maps. If it's some package from somewhere you might have ended up with the European FeCs rather than the RoW Navigation FeCs thus why I say you need a firmware expert on Mib3.
  19. Probably need to update your satnavs maps 😉. Mib1, mib2 high and mib3 are Here Maps. Mib2 standard to circa 2018 or something (on the other thread) were Here Maps. After TomTom cartography. Not sure why they changed. All Here Map ones can be changed to Inrix via coding or file changes. TomTom can't. TomTom and HereMaps use more strict validation in a cartography sense. Google Maps is free and easy. If they can get a survey up a road even though it is a farm track and not a public road it goes in. Issue the routine algorithm takes you up those roads. If they take user input on those roads and also use the car as a probe then they say, past validation, it's a road. They become a devil of a job to get these farm track short cut roads removed. I've given up and won't supply any cartography to Google Maps after they fail to remove farm track roads. Unsurfaced mud roads. One here, jump to one side, here comes another Google Map user taking the farm track to the country hotel. Openstreet is really a general purpose cartography controlled by academics in the main. Ordnance Survey planning maps in the UK, Crown Copyright are the statutory planning control maps. It is those that are the gold standard in the UK used by survey companies to submit their planning applications for their clients. The house number system and house names, street name is found on that, regulated by local authorities. Postcode directory and house numbers by the Post Office. Openstreet have an arrangement to use these maps to provide information for crowd sourcing Openstreet from them. Copyright arrangements by the companies and authorities to use each other's. Electoral ward, local authorities etc is all cross referenced into the postcodes. Because Openstreet is free it is used by companies to overlay their information. Google maps a charge may be appropriate. Here Maps you also see. Cartography subroutine libraries they use on websites. Amazon use Heremaps on their tracker map. Point mapping is also used by delivery companies where the front entrance door becomes the address. You see DHL won't let parcels out of their hands until at the geo point. Sorry they say as they walk closer and the device says they are there. That's built up from their own databases. I believe that is also sold on to the cartography companies as validation files. The mobile phone tracks also become the probes used for validation of traffic movements.
  20. Afraid I'm not into connected cars for navigation or traffic reports. Feels like amateur radio. The maps created are not created by cartography companies but Google itself. Waze has fantasy roads on it without validation, ditto Google maps putting in farm tracks. Speed camera reports are only reports. All CB radio type of stuff on Waze. Missing is validation. Now traffic reports are dogged by the closure of 3g. Sounds fun. For software updates and inbuilt navigation problematic slow connections isn't really an issue but real time use it will be. Least we now know from the above why eSim and dongle use as alternative to TMC are problematic. The post 2020 cars with mib3 and above won't have TMC, whilst in the UK and France etc coding solutions are available to get the traffic reports still up on your built in maps (mib1 and 2, Skoda and Seat) till that plug is pulled. Inrix does for me with the solutions posted on the other thread. It's the database that Traffic Authorities use in the UK to record known road conditions.
  21. Suspect you are in the slow lane of end of life care (EOL as its called in the NHS). That's the worry with connected cars as to how long the support lasts for. You got the dongle bit but never the less elements of connected car. Question is whether other users find the same.
  22. Well it's one of these two based on a Google of what's fitted: Mib3 (Superb Mk3.FL and similar) Content Downloadable 2023.12.20 2023.12.20 162 MB 2024.05.17 2024.11.07 https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.50.zip 1,13 GB 2025.01.14 2025.02.20 https://www.phonostar.de/download/vw/MQB3_OI_NonGP_JND_Europe_v1.31.56.zip 166 MB Pass on what NonGP means... we need @MartiniB I'd try the bigger file, see whether that works then move onto the smaller one. You can read the radio release you currently have of your infotainment system, so what you want is something with a higher release. No good going below that. That's the other steer. Generally these update files lock onto your unit so if it's not relevant, it won't work. So no damage. Final answer as they say... look at your current version release off the screen and compare. As an aside I did read this post https://www.briskoda.net/forums/topic/522574-update-to-version-1969/ And a followup post links to the flashing usb adaptor sold by Amazon. It's those ones that flicker people like on the map update to know something is happening.
  23. Can take a year or so if digitised to arrive. Herewego app shows current live data so you can always cross check. You can always join the Mapcreator programme.
  24. Well that's the advantage to Vag they have sold out responsibility to those that look after the Internet of things. Not us, they provide the service type of thing.
  25. You don't have to pay anything. MartiniB top post should be the current which tallies with what you have downloaded from what you said. Formatting, getting it in the route directory unzipped and suitable. Yes should install after a period. The only issues are technical issues if usb a to c adaptors are used. Formatting and generally messing it up. It can take a couple of hours or a couple of days... you check the information screen to see whether it's been updated to the map release mm.yy as MartiniB posted. That changes and you know it's done.
