Tell
Everything posted by Tell
  1. No it's the manufacturing differences between 32gb fat32 SD cards so what was universally possible isn't now since the maps have grown to make the marginal differences kick in. With a Mac you do the Keka clean after its copied across which means you got the Mac overheads on the copy before the clean.
  2. This is where there was one case of a Seat person messing up their 32GB SD card so you never knew whether it was a cheap fake or they messed it up. Person A sold it to Person B on the SeatCupra board and it never worked but did before. That's why you never try to reformat them just delete what is on them and wait for it too work thru. Windows 10 and 11 default to cluster size that is way to large. There have been historic conversations on here about the manufacture of these cards. If you do, do a reformat you have to bring them back to a cluster size of 4096 in FAT32 and keep your fingers crossed.
  3. Yes there are rascals out there. I bought a Skoda one a few years back from a seller a German Skoda forum was using it was fine. That was the first year of them being available. It is possible for people to manufacture fake ones using Chinese SD cards with rewritable CID areas and put a VAG sticker on them.
  4. If you search under mib2 32gb you find them. Reckon mib1 never got to 32gb. So it's got to be searched under that for that size. It was a marketing thing when the all Europe map went large.
  5. They are all interchangeable between mib1 and mib2 as far as the CID is concerned. VW / Seat / Skoda cards can be used across brands and mib1 and mib2. Whatever the checksum / validation is used they all say OK fine when put in the unit.
  6. Since I'd said about map from other regions outside of the EU the text is here. I've got Ozzie people out of a hole here who did imports on European infotainment unit. This was T6 Transformer / Seat board joint working, the results of it. Only Seat need step 7. You can do the full works. It seemed that newer units needed steps 8 & 9 whilst I can get away with 1-7 in 2019 Arona. Sort of suck it and see. So I've loaded Israel, Oz and South American maps in it helping people in the past. You frig the maps to the units existing region firmware rather than frigging the firmware to the region: Got a car with a working installed map but outside of the region - need to get local map working ? (Mib2 Standard only) Example taking a car to Morocco. Exporting a US VW to France. Exporting a European car to Palestine. Emigrated with your mib2 car from Europe to Australia. The T6forum perfected some of this but joint working across the boards got it going for more modern units. Guy in Palestine sorted that out for latest VWs which were the problem. Arona standard Mib2 is happy with the original T6forum method with the workaround above. Advanced method with example with Israel as the map (text taken from a VW user): https://www.t6forum.com/threads/how...-in-non-eu-countries-e-g-morocco.10331/page-2 1. Download the required Region Map Update. (For example, "Non-European countries - Package 3") 2. Use a VW SD card, as VW SD Cards have a special [CID] card identification code, and normal SD cards cannot be used for browsing data. 3. Erase everything on the card, (Before making a backup of what's on it). 4. Copy and paste the maps folder after unzipping it (do it in Windows because the mac fails something when unzipping, or use a recommended program "see volkswagen page"). 5. Use a file explorer to open the 'maps' folder on the SD card. Depending on the map package you have, you will see several numbered folders. 6. Change the name of the corresponding folder of the Region number found inside the 'maps' folder on the SD card to '00'. For example; To use the MRM3 Region SD card to navigate in Morocco, etc., rename the folder '27' to '00'. 7. Copy the OVERALL.NDS file from the original (European) maps folder, which is in the “maps / EEC / EEC_WLD / OVERALL.NDS" path, and subscribe it to the card in the same path. 8. Copy the file OVERALL.NDS from the original maps folder (European), which is in the path “maps / 00 / nds / PRODUCT / E1 / OVERALL.NDS”, and subscribe it to the card in the path “maps / 00 / nds / PRODUCT / XX / OVERALL.NDS ”where XX is the code of the desired region (ME1 in the case of Morocco). 9. Copy the PRODUCT.NDS file from the original (European) maps folder, which is in the "maps / EEC / PRODUCT.NDS" path, and subscribe it to the card in the same path. 10. In the car, restart the Infotainment System by keeping the on / off button pressed for a few seconds, then insert the card and you're done. Basically 7. is the Exciter workaround 8 and 9 are the two additional steps that some VAG heads required to make it work on out of zone maps. Was fine for the Arona, step 1- 7 was sufficient and only presenting the target country in 00 directory not editing and leaving the rest as is. Suspect the wifi standard heads of Seat would need steps 8 and 9. Had maps of Morocco and Israel on a European Arona unit. The method with steps 8 and 9 was used on the VW car brought to France from North America and the car that was exported to Palestine from Europe. For the US car the country code is 01 so 00 content is renamed to 01.
  7. The interchange of cards is a useful thing to know. 👍 You can also make these units work outside the region using another region. Brits take their cars to Oz. Yanks bring Golf to the EU. Quite a few EU cars head to Palestine secondhand. We've perfected that with the Transporter board an people popping up with different cars. Documented elsewhere. Since the maps aren't locked down you can do tricks with them.
  8. & on the 32gb card it doesn't have to be Skoda, can be Seat or VW. All the head units of VAG mib2 recognise any brand of VAG card whilst mib1 will also work with a mib2 VAG CID. We have had that where some one buys an old car with mib1 and used a mib2 card in it loaded with mib1 maps. Somethings don't change like the CID check between mib1 and mib2. Seat don't have Mapcare so other things need to be done to work around that other than that, all map card rules apply.
  9. I can pass it onto to Seat folk if you like although I do tell them to buy a 32gb VAG card if they want all of Europe on one card.
  10. That's the third post which gives you this Ignore the top stuff on VIN and the Skoda website. That run 6 months late. Use MartiniBs links in original top post. I also offer the VW Discovery Media PDF attached which is the official VW guidance. All the same file. Attached. That was written prior to the 16gb region decision. Zones for the original card or buy a VAG map card from an e seller if you want the all Europe map. Note Mac instructions if using a Mac. Don't reformat the card just delete what is on it. Reformatting has led to people killing the card. 4096 is the size if you do and mess that up. Fat32 is the only one that works with this hardware for the mapcard. People get too clever and dig holes for them selves by reformatting the card. You are suppose to use Keka and CleanMyDrive if using a Mac. PC the one mentioned (7zip) but you can use the built in one for W10 / W11. Right click on the file, its under file something or other... you will see it, drag and drop out to a directory then drag and drop to the SD card, faster that way. Simple. Discover_Media_MIB_Gen.2_June_2020_EN(1).pdf
  11. Correct that's why you have to buy the 32gb vag brand card if you need all of Europe, a zoned map for the 16gb card. Skoda gave about three years warning on that, when it happened was about two years ago. I wouldn't dream of driving long distances in a Seat Arona but others have the cheaper unit in bigger cars that they would drive the length of Europe. If you are buying a big car you might as well have bought one with a mib2 high in the past. That was not always offered when VAG started to sell their vehicles in packages without options on the infotainment system. The Kodiaq Seat equivalent was only sold in the UK with the standard mib2 high, this thread. Whilst the system does, it's not polished like the mib2 high. Skoda Columbus. Now mib3 is all SSD based although like the mib2 high but has its issues. We are on working legacy systems now that at least work unlike mib3 with it's (many) foibles 😅.
  12. 32gb card comes in when you have the need to drive across all zones of Europe. Tootling about in those zones is fine. I do come across people that need the 32gb card since their planned journey doesnt fit in with the zones. As I said yesterday all VAG cards are interchangeable and you can even use them in a mib1 unit if you have the original mib1 maps for that. The CID on the cards which is the security lock works across all VAG units mib1 and mib2 standard units. On esellers you have to make a choice on the user scores they publish etc.
  13. Ok to answer the last bit... now I've read it correctly 🙄. You'd put the unit into developer mode so you can access the SWDL. You get that via unlocking 5f with VCDS or Obdeleven. I keep mine unlocked since I did it. Press the menu button till you see the second menu with SWDL on it. If it's not in developer mode you dont get to see the second menu with SWDL on it. You do a manual install of the maps select all attributes. You have to keep the door open or open and close it every 15 minutes to keep the unit powered up in during the update. SWDL will show you all the map attributes being updated so any failure in those will be seen. At the end you see a status report of the updates by attributes. Before you start it shows what it can update. You can downgrade maps this way. I've resisted the USB v SD speeds test talked about but how you would do it. Might test it one of these days or leave it to next year. If that's all looking good by each attribute eggnog etc then its all good and it will be the firmware generating the error rather than a failure in actually doing the update. I always use SWDL since I like to see it going thru. You can play about with updating specific parts. A good test is Iceland since it updates in no time being a small country 😉.
  14. Probably isn't passing the SLA1 integrity test. Reckon I used the VW download on my Seat and probably used 7zip force of habit. Wouldn't pass that test if something got introduced after it was signed by peaking at the txt files, saving and not cancelling. It's Mac that add the rubbish where cleanmydrive must be used to rip it out. A corrupt SD card or USB could cause problems.
  15. You definitely need to be on the other thread 0915 is an old Mib2 Standard map code of 2015 so yes wrong thread. Ive answered questions incorrectly here, correct answer but wrong thread 🤔. That time again. If you need all of Europe on one card you by a 32gb VAG card, Skoda, Seat or VW interchangeable, copy download across. The maps have grown over the years. If you are not travelling across the zones shown on the link then they will fit on your existing card but either way you need the files from the other link.
  16. Sure you are on the correct thread with this feels like the mib2 standard (Amundsen) with a map card. This thread is for the Columbus (mib2 high) - no map card get read into the SSD memory of the unit. You will need the standard map file not these for that and pick a zoned release to fit the 16gb or buy a 32gb Vag card for all off Europe. That's this thread:
  17. 10gb of that 64gb goes to the Juke box. You got the firmware itself and then a little bit of space they keep to move around in over the maps, juke box, firmware. Run time space assuming it's in there... probably not so little. Depends a lot on how rigid the space is, probably pretty rigid. I'm sure there is a detailed memory map somewhere of the SSD. Probably the firmware isn't in that nor user POIs. Still about 20GB unaccounted.
  18. 310 is the latest one yes. If it says that during the download it is what it is. The Amundsen side is currently offering six month old maps why I said don't trust the Skoda website. It could be that the Skoda mib2 high maps never got the six month delay which the mib2 standards maps got. MartiniB always posts up the latest maps well ahead of the brands wrapping the links into their web pages. All the same file across the brand by release so those in the know just take the link published on boards and don't bother with the brands website.
  19. It will be fine. The first boot with new maps takes longer since it does some FeC stuff. Always seems to be the case. You have to re-select your favourite built in Pois like petrol stations and garages etc. Mib2 high units you don't have to.
  20. Sure Skoda aren't playing their six month delay trick. Re-heated old bread. It should show release 310 once loaded up if 197 the June 2022 release when they gave the release before 🤣.
  21. Yep some downloads have them on, others don't. The idea being that the checksum is published differently from the file so the user runs their finger across the md5 file and says yes this file I got on here tallies after working out the md5 of the file. You can generate the md5 yourself and compare. 7zip has a capability of doing that as I recall in a module you off to install or the utility mentioned here. MD5 & SHA Checksum Utility. I use ether. https://infosecscout.com/generate-md5-file-checksum/ So that's the md5 file v the one computed. Just a simple check but given it comes from VAG it's going to be right. Non believers don't believe the VW, Skoda and Seat release for the same period are identical. We tell people they are.... The technical check for non believers is to run them through the sla1 check but then they wouldn't know what that is so continue to believe they can't all be the same file 😂. The firmware is different but the same source code slightly adjusted. Some people manage to get Skoda infotainment firmware on Seats which causes some constellation with those people that play with mib firmware telling people they got the wrong code in the car, but for map files, pois, radio stations etc all interchangeable for mib2. Errant Seat Cupra moderator here.
  22. Pretty fast. That will be a comparison for next year since I've got this one loaded up. I could downgrade using the SWDL menu then upgrade back or wait. Think I'll wait than mess about. I've already got that card above and give that a whirl in June. But if any one wants to try that feel free. In terms of units mine is a mib2 high fitted in 2016 not anything newer. Takes about 40 minutes using SWDL in one go on a regular Class 10 of the old design DanElec SDHC Proline 200x Fat32 - think that has a read speed of 30MBps. The SanDisk mentioned read speed is quoted as 170 MBps (SanDisk Extreme PRO 64GB SDXC Memory Card up to 170MB/s, UHS-1, Class 10, U3, V30, Black). USB2 is said to be 60 MBps from my previous Googling. Think the timings between SWDL backend menu and the normal way of doing it are similar. On paper the SanDisk one would be faster than USB if the components aren't holding it up. If I get the urge to test before, I might do. Like to keep one old map on a card and the new one. Feels like I need two cards 🤣.
  23. On the speed comparison USB2 runs at 60MBps and Class 10 SD cards 10MBps. So one needs a better spec card above Class 10 to out perform USB2 assuming the chipset in the unit can manage it. The SanDisk Extreme PRO 64GB SDXC Memory Card up to 170MB/s, UHS-1, Class 10, U3, V30 manages a 170MB/s which is better 60. Would suggest one of these is better than USB would ever be in the unit. I'll stick with my card I got ready 😉. Probably some limiting factor of the unit which will never get to these speeds like the bus speed of the unit. A lot of early hardware was limited to 100MB/s. Quess it's hovering around there. The other variable.
  24. Probably what we'll all be using next year or USB sticks. What we dont really know is how much spare user memory there is in these units above 32gb for maps. I'm sure the technical programming enthusiasts know who are into firmware. Memory allocation table within the unit. The spare memory is used for the Jukebox / some but how much more can the maps go beyond 32gb once loaded. Maps + Juke box = ?. VAG might have to start releasing zoned areas if there is a cap that doesn't let them go much further in the life of Mib2 high updates.
  25. Suspect the Mac dross that CleanMyDrive removes was the critical difference if yours was a PC and Freelunch was Mac. All things being equal the dross that CleanMyDrive removes pushed it over. Macs add extra Mac stuff that can mount up so I'm told which can be quite sizeable. You can't see it on a Mac. Bit caught out if so.
