Tell
Everything posted by Tell
  1. Yes it's what you said last time this came up. DL double layered DVD. If that's the case you need a special DVD writer that does double layered DVDs and a double layered DVD to go in. My old Panasonic combined DVD / hard disc TV recorder does this.... was a way of packing more onto a DVD by using dual layer with the laser cutting two surfaces from one direction going below the top layer. I wrote a few, re-writable DVDs. More expensive. Was a passing technical curiosity like those high audio CDs. If it isn't the media then it's going to be the navigation FeCs but I thought Skoda had always been lifetime navigation FeCs as now. Perhaps they were not and set at a lower limit so whilst it's a joint mib1 / 2 high map release its limited by the navigation FeCs that Skoda decided you could only update for 5 years after the death of mib1 updates. This one is all before my time on mib. Probably / Certainly the European enthusiasts on mib know the answer if MartiniB doesn't. Chillout one of the programmers was working with mib1 units before mib2 I reckon. Taking them apart and tinkering with them for years.
  2. But then reading around people have done it via SD. No Mac involved ?. I posted the VW pdf periodically. That's on these threads. That gives the hard and fast method. Away at the minute so can't did those out. Using a Mac us tricky, CleanMyDrive after. On a PC 7zip. The integrity of the unzipped file is checked so any odd characters in it will slam on the brakes.
  3. That's a Mib1 Columbus. Whilst the download is suppose to cover mib1 and mib2 Columbus it isn't clear to me how you get them in a mib1. Via DVD I think. There has been a conversation before and DVD was mentioned. Think I went off on the two layer discs. Normal writer does one but some do two.... cue the mib1 Columbus experts. MartiniB might know. Mib1 High is before I came into this. Think the moderator also knows about mib1 high units on how they got map updates into them... that might have been the cconversation that I had. So it's a combined release for mib1 and mib2 high but you just got to get it into the unit. You have got that reading in since its showing you the contents or that's what you have it on now thanks to a retrofitter say. You might find the manual on internet. Well I reckon the secret rests in the world of writable two layer DVDs but I could be wrong. If you got the unit from a retrofitter he might have circumvented the DVD by having it on a workbench using a laptop or the backend menu to do the job....
  4. The moan was that VW hadn't changed or not updated the files from last time but without the original I can't use the trusted scientific method of comparison 🙄. Using a current popular expression in the UK. "It is what it is". Normally said by the guy you get in and means it can't be improved.
  5. The question is, is whether the ones Martini B had marked up on the thread for outside Europe were those or whether VW has a processing error now. I don't have a copy of those files from the time when they were "found" (outside of the region I use). It could be that VW never did update the files. We are expecting mib2 files to be updated to circa 2025, the normal +5 years from the end of production of each RNS / Mib version. May be VW have stopped early. Have to wait to see what happens in the November release this year. Not long.
  6. The code is 1910 or there abouts for the latest release (June 2022). I gave up talking about calendar years when they changed the way they referenced them. Still October you might get the November release. You never know. I see all of the ones direct from the VW site are marked up as 1910 so on face value they are the June release. Like hot cakes best to get your map updates when they come out of the oven fresh 😉. (It's all of the non European ones that the link has changed on)
  7. If you did take the format route previously and you do it again make sure it's Fat32 and the cluster size is 4096. The unit runs QNX and they don't take too kindly to NTFS or other cluster sizes. Attached is the VAG gospel on the mib2 standard "how to", which is what the Amundsen is. Same instructions on file preperation across the brand covering fat32, 4096 cluster size, 7 zip and Keka / CleanMyDrive for Mac users. Discover_Media_MIB_Gen.2_June_2020_EN.pdf
  8. Are you using a Mac ?. If so you are suppose to use Keka for the unzip and run CleanMyDrive on the SD after. Just in case its a Mac issue. You are suppose to do that if using a Mac. Mib2 high it will stop the map import in its tracks but for a Mib2 Standard which an Amundsen is it will try to run with the gibberish associated with Mac characters that the unit may not like. That may well cause it to fail. You don't alter the cluster size. Those that have done on some of the cards have wrecked the card. Just a straight delete if using a PC and copy the unzipped contents onto it using 7zip. Mac the above. As said with an old fashioned format people have wrecked some of these cards. Windows 11 formats to a bigger cluster size by default it should be 4096 (correct number) and that can wreck the card if bigger. People play with the cluster size, it should be 4096 and Fat32. Those are the mistakes when people do a format rather than just right click and deletes what's on the SD.
  9. On timeliness there are production delays in QA and I'm sure they are similar with all mapping systems. Six months or so, then you enter the production part online real time distribution whether via a six monthly cycle as these or over the air quarterly say. People think Google are quicker. A lot of the data is crowd sourced by a user community of mapping individuals, it isn't picked up by cars going around and it then goes into a process of production delay via QA. Digital map companues also digitally analyse each other's maps which is how mistakes get propagated between mapping systems. Tracer GPS tracks are used to identify new routes and bypasses. Again an area for mistakes to be introduced without good QA Areas where mistakes get seeded between mapping systems. Builders roads on new estates are another one, they are not the final roads but are the truck roads when the estate is built. You often find them years are an estate has been built on digital maps that should have never have been entered, mud roads. Bollards to stop rat runs get missed but in overhead images people miss them. UK OS published planning maps as opposed to other OS maps are the defacto on the ground small scale maps but digital map producers dont check against these for mistakes. Suspect in other countries local planning maps also get ignored by the international mapping companies with one solution fits all in their validation process. It's like painting the Forth Bridge constant painting. The language deletion trick allowed the all Europe map to be put on a 16gb SD card, was a fudge. This year that one stopped working since the maps out grew the fix. I have read somewhere of other aggressive hacks of deleting parts of the directory deemed to be not required which work with this release. I did not note that down since they are only short term fixes to the issue of not buying a new VAG 32gb map card (don't change the cluster size it can wreck some of the cards). Only if driving the length of Europe do you require the all European maps, the zoned areas are adequate for the majority of people. You have a mib2 high with the all Europe map in a car that you'd wish to drive across Europe in whilst the run around would stay in the garage. That's what happens here.
  10. It's Ryan of North East VAG Adaptions in Durham is the associate that East Yorkshire Retrofit use. That guy is used by Seat mib2 high people after they mess up their units on DIY firmware updates or another retrofitter has messed it up or fancy a firmware update want someone to do it. They cover VAG stuff. Durham may be closer or easier to get to. They use traditional on the bench retrofitter methods rather than the end user Mib Tool approach. For that you need a bit of hand holding when your FeCs get messed up. That's how I got the Skoda navigation FeC on my Seat when Seat dropped support for one release only. For DIY you need a Mib Tool Skoda expert who can do a bit of surgery on your FeCs or the module if it's currently not supported by Mib tool. One of these guys did it for free on a Seat for me. Another case where a retrofitter in France had messed their FeCs. If you don't fancy DIY and / or are not plugged into the Skoda network of enthusiast on firmware then it's a retrofitter. Ryan is actually East Yorkshires technical expert sub contractor. If you told them the FeC you wanted and the duplicate ones etc they could sort it out I'm sure for a cost obviously. Seems a bit of a mess that your dealer messed it up. Ryan does do a postal service so your dealer could send it to them but you'd have to be clear on the missing app FeC you need and the duplicate. The Mib Tool people miss out that app FeC from their app like Skoda do but it can be put back in by the user. Retrofitters uses "Whatthefec" for their work, Ethernet / USB port boxes to the laptop and password crackers on the unit.
  11. 6 monthly June and November else we would be taking from there if monthly. 😉 Mib3 are more frequent over the air, they are Here Maps cartography. Mib2 standard (Amundsen on Skoda brand) is TomTom cartography. Mib2 high (Skoda Columbus brand) is Here Maps. Mib3 its all Here Maps cartography, TomTom cartography got sidelined by VAG when Mib3 was launched but still update for Mib2.
  12. If you happen to live in Yorkshire, East Yorkshire Retrofit could probably sort it out by putting it on a bench using traditional retrofitter methods. They are reliable. The place that Seat people go to if they don't feel comfortable with DIY or mess up their units. They do all VAG. They use another associate in that location who is their expert.
  13. You might want to look at Mib Tool which you can install in the green menu but you need a module for your firmware release, failing that the enthusiasts that support the tool have to write you one for free. Once the module is installed it gives you control over the FeCs. So you could add your missing FeC code, it also has the ability to remove duplicate FeCs. It's been used on Seats to remove duplicate FeCs where a retrofitter made a pigs ear of some work and screwed up the navigation FeCs. There might be Briskoda experts on the board on another thread on this, but it's all the same tool across VAG developed by European Mib2 enthusiasts. It can be found in Https://mibsolution.one Login guest Password guest It's sits in M.I.B where they don't know about your firmware you upload the backup it generates into M.I.B_Backup I believe they have slightly changed the way it's packaged since I used it. It's one of these thing you use once. Then I had one of the Seat experts to write me the module for my firmware. He also sorted out the guy with the duplicate FeCs. How the group works is they have experts in the brand so I expect you need to make contact with one if your firmware isn't within the tool. They do look in the return directory. 3.1.7 is what I used, they are on 3.2.0 now. I didn't find a match on the board for Skoda experts in this. Those Audi people of recent asking map questions will have passed through the link on firmware using an AIO version I suspect which combines the firmware with mib tools to add FeCs in an easy update. Due to you using online probably not a good idea to go for a complete firmware update but a FeC tinkering tool. In mib tool it does list the firmware it works with across the brand once you have it on an SD card. You can nose around seeing whether they have a patch written. Addfec.txt is then edited in notepad to add anything unlisted. I see they have your media one dropped. You should just be able to edit it in. The Seat one is dropped on the same basis. After tinkering, you reboot the unit, long press and go to the FeC listing screen. Mibwiki supports the link. Google on that as well. Being computer programmers they can be exacting 😉. I can look at back posts to see how duplicate FeCs are removed. It can be done in the tool or a module run. Where it came to pass that the Seat guy didn't need the extra programming help it was in the tool. Basically the tool packages retrofitters techniques but in the car in a user friendly way as possible.
  14. Problem with Google Maps is a lot they don't have on it and a lot wrong. Now mib has taken a turn for the worse with mib3 it leaves many people thinking built in car navigation systems aren't worth it. A certain beauty of using an integrated system.
  15. At some point with lots of hacking it probably won't fit again 😉. Easy enough to buy a new Skoda 32gb card off your e seller. They are not that expensive. Only if you are driving across the breath of Europe do you require the all Europe map. The card is not fixed to the unit in Skodas and VW cars, you buy the card, delete what is on it if it's not up-to-date, copy on the new release and you are in business. For the Seat unit you deploy the "workaround" which is the normal method for the standard unit. Quite a few Seats have Skoda cards in them now although there is a Seat 32gb card. All VAG cards are interchangeable in the unit. I keep giving TomTom new roads in the UK as estates get built and new developments via Tom Tom Mapshare as other contributors do. These get put on, so it will continue to grow.
  16. No I don't. The dual layer meant the laser had to hit two surfaces to pack more on. Still sell them https://www.google.com/search?q=dvd panasonic dual layer writer&ie=utf-8&oe=utf-8&client=firefox-b-m I once bought industrial DVDs with no printed label on them. Fine if your nail didn't scratch the surface which should have had the label on, then they fell apart. Will be onto old 78s next 😂. Btw I thought I'd identified the guy that was creating RNS maps from material, Kong ?, on a the Seat board but it wasn't him. Here's a link to chew on https://getnavigationdvd.com/rns510-navigation-map-dvd/ I was trying to get the famous Chillout interested in turning mib3 maps into mib2 high for the day when mib2 high maps won't be released. He said that would be a cool project. Let's hope the mib enthuasts take it up since some of us don't want to change our cars till 2030. Life in them yet till EV. Reckon there will be 5 years without map updates.
  17. You need a dual layer writer as I recall. My old Panasonic DVD TV recorder did that. I don't reckon your average DVD writer does do dual, just single layer.
  18. Or is that the one before, RNS ?. I only graduated to mib2 😂. Definitely the file covers mib1 but how it's introduced I pass. We need someone with mib1 high. 2011 would put it at mib1 high in the life cycle of mib. An old mib1 manual should say. Dual layer... fun.
  19. That's an interesting one. The update is multi purpose for mib1 / mib2 high why the directories have the two inside the download since it dances between the two. The question is whether mib1 high users are still using MartiniB's links. I only came into mib on a mib2 high. From what you said sounds like the ssd or whatever they put in mib1 high's crashed. You might be tripping over getting the card formatted and copied correctly, the Mac issue or some other finer detail.
  20. I dish out the Mac advise although I don't have one... wash my mouth out with salt water... but it fixes them all. Mac's stick an extra carriage return on the line or whatever. The map file is protected with a sla1 signature which means a secure signature is placed on the metainfo2.txt file. Private / User key. https://en.m.wikipedia.org/wiki/SHA-1 Vag signs the map file with their private key, the unit knows the public key and says, yes, this checks out and allows import. 1 character out and it rejects it. You can't manufacture the private key from the public key unless you have a security service type of computer like a Cray 😍. Then you could manufacture an import file via the secure methods. Ways around avoiding the signature have been found with the mib2 unit... they didn't close down feeding other code into the unit after the signature which is the exploit that developers of mib tool boxes use and specialist modified firmware which also carries the FeCs through another developers exploit. Saying that cross checks are not made on the integrity of what gets imported if you avoid the signature check so CleanMyDrive is even more important on a Mac if you are importing firmware of this nature. All clever stuff. CleanMyDrive removes all the bloat Mac characters so it looks like the PC download.
  21. Assuming it's mib2 high and patched with the life long navigation FeC for Audi the conversation above as I recall, if not on the previous release, then it's going to be you are using a Mac and you need to use CleanMyDrive on the SD card after unzipping it. That's the common Mac error after unzipping. Failing that it's the format issue where I say stick to SD card 32gb, fat32 else you enter the territory of formats, covered above. That's about it. The life time navigation Audi FeC was published above or on the other thread. Look at yours and compare. Some retrofitters scam by just giving you a short term FeC to induce extra work. Why you need to check what you have against the life long FeC. That's set at the high point in the table where VAG will stop issuing releases before you hit that. Edit. Was this thread. Audi 23000ee the one Boo boo had.... we went round the houses before pinning the issue down, check yours and check unzip, Mac issues and format plus attached VAG (Discover Pro pdf above) notes I posted on the process above. Some Skoda drivers go off piste by using USB sticks then you enter the format debate. Stick to SD cards class 10 32gb and we dont need to cover that... the Vag guidance.
  22. & mine on a mib2 high. Was a technical failure in the company that runs TMC in the UK. Similar to the one a couple of weeks back. Nothing to do with the map update.
  23. I checked my Mib2 high in the afternoon and TMC had a cross thru it so it's taking a break 🤫.
  24. I will have a look to see what's happening today on it. As I said TMC took a break a few weeks back for a day or so then reappeared again. Was reported on a Seat board. Have access to the standard mib2 unit and mib2 high, was off both which concurred with the Seat poster. So nothing to do with the standard map update, just coincidence. Decides it was a technical network glitch. TMC is broadcast via Classic FM but receivers can get mixed up in some parts of the country between the free service and the paid service. The free service is paid by the manufacturers e.g.. VAG in this case pay for the free service for the customer. Traffic Master is the paid service. Weird and wonderful world of TMC https://tisa.org/technologies/coverage/ Have a wiki https://en.m.wikipedia.org/wiki/Traffic_message_channel See under UK. Think their servers have a wobbly at times... not good if there is traffic. 😨 Probably held together by sticky plaster that falls off at times.
  25. Invest in a 32gb Skoda card from an e seller, normally ends with a bay at the end. That's what people have been doing with their Seats in readiness for the day when it out grew even with the language fix. You have to look at the review index and determine whether they are genuine Skoda ones or the "gold card" ones. I bought mine when members of a German boards were buying them about three years ago, that was a genuine Skoda card. Seat 32gb card would do, or VW, they are all interchangeable. The CID is recognised as Vag so it works. Why I experimented with the 32gb Skoda card but it's come to pass mib1 units work with the mib2 card although you have to have mib1 stuff on it obviously. Don't be duped by people that say reformat the 16gb card with a 2k cluster size, its been known to screw up the card e.g. kill it. Skoda 32gb have been killed this way. Apparently the newer manufactured cards don't take kindly to reformatting, always delete what's on them than hit reformat.
