Everything posted by bigjohn
EPC light came on and stayed on
This happened to me just after I bought my Superb 1.4tsi. Filled up in Luxembourg with lovely cheap petrol and being from Yorkshire went past more than one click. Light popped up sometime later for a while, as per OP it went off after a few starts. It was checked out by a German Skoda dealer - always stop at first click now and it's never done it since.
Might still be worth popping in as fault should be stored. if fault doesn't recur after a few starts then light goes out. just checking - had you recently filled up with petrol when the light came on?
1.4 tsi autonomy
You need to measure fuel consumption over a few fill ups rather than just range as fuel gauge calibrations can vary. My 1.4tsi Skoda Superb mk II is supposed to have a 60l tank but usually never get much more than 50l in when I fill up. However measuring fuel consumption it's actually surprisingly good - not much worse than the 1.9 diesel Superb I had previously. Be careful overbrimming with petrol - it can do damage to the charcoal cannister. When I first bought my car I brimmed (multiple clicks) my tank in Luxembourg and a while later it displayed an engine management light. As I'd just bought it and it was under warranty I pulled into a German Skoda dealer that was really helpful - they thoroughly checked my car out and despite our clear language barrier got the message from them - "Von click - halte!". I now stop at one click and have never had an issue since. On a long journey driven carefully mine can average over 50mpg (5.65 l/100km) .
Gearbox problems
Which engine fitted? Hmm, did they bleed brakes and clutch? Something disturbed - eg bleed nipple? Is the mater cylinder reservoir still full? [EDIT] If clutch ok - engine mounts?
Low oil pressure
You could investigate a used engine - potentially more money after bad as they say...
Low oil pressure
How far did you drive with low oil pressure warning? if you ever get that it means stop immediately as without oil pressure you will start getting metal on metal wear of engine components usually starting with big ends. With that amount of debris in the sump I'd say major damage done. There is a chance that this could be some turbo bearing debris from the oil return. (Edit) Also wondering if the original fault wasn't the turbo and something catastrophic had failed with your engine causing the debris and low oil pressure - this in turn caused the turbo failure. I'm afraid stripdown etc probably required
Stop-start issue
My MkII Superb 1.4tsi stop/start works very well. You don't really notice it when you stop until you drop the clutch to set off and you hear a brief whir of the starter motor. It did have a hic-up last year when stop/start stopped working however it was in need of a new battery - suspect lockdown and cold weather contributed to this! If yours is stopping and then instantly restarting then something is not right. There is a complicated algorithm controlling stop/start including voltage, temperature, motion etc. I'd get it checked out.
Twindoor fault
Wiring issue?
Briefly losing power
Any faults logged? Stage left suggestion - brake light switch. Common fail and if dicky and operating under some circumstances (ie a corner, sticking after braking etc) then the engine management will cut the power. Doesn't cost much and easy to change - so might be worth doing anyway. Does it have cruise control and is that playing up as well? This failed on my mkI a few years ago - just a thought. On the original post "I've taken it for a blast and was fine ish until I turned of main road where it did it again" - am guessing you had used the brakes turning off the main road - sticking switch?.
Subframe safety note
You also have to keep an eye on the rear suspension beam/arms - thick metal to start with but can eventually succumb. A failure of this can have similar catastrophic outcome and it's not always obvious on MOT inspection. Having restored various cars over the years I've tried and tested various rust proofing techniques. Latterly on exposed suspension, subframes brake back plates I've become a fan of Owatrol oil (spray or hand paint) - Does the job well and you can see through it so you can keep an eye on potential tin worm issues. It was a Landrover enthusiast that got me on to it. Black underseal is usually the worst thing to use - rust just seems to munch/track under it (although I had success painting on top of a clean and oiled surface). Elsewhere inside sections, subframes(after Owatrol outside), sills, door bottoms, front of bonnet etc - Dinitrol is cracking stuff. As an example of how well it works, my wife received a hanging garden ornament which after being out for 1 night in the rain became entirely covered in rust. I simply wiped over this with Owatrol oil and numerous years later still looking free of rust, It even keeps my wife's 1.2 Fiat Panda sump free of rust - and boy do they rust!
Start/stop... Linked to steering...
Electric power steering as fitted to many recent cars is amp hungry - most car control systems disable power assistance when the engine isn't running. Power steering faults can be logged on many a car when the battery is on it's way out.
New car - questions
and illegal in some countries - eg France
Octavia Mk4 aftermarket towbar
I've seen this before on some other models. The cooling system may not be sufficient as standard with some engine sizes as they will have been fitted with smaller radiators/fans etc for the smaller engines. The tow bar prep option could include changes in this specification as well as some electrical mods. Note to self - specify tow bar prep option if possible with any future car - oh and the USB C connector behind the mirror (for dashcam)
Kamiq Towbar or not to Towbar
"Tow bar preparation. Please note, it is not possible to retrospectively fit a tow bar if the car is not fitted with tow bar preparation at Factory." From the Kamiq Pricing and Specification https://az749841.vo.msecnd.net/sitesengb/alv1/3790b4a5-0e33-4cf5-948e-9510c594d58f/SKODA_KAMIQ-Pricing-and-Spec_OCTOBER19.93a6142e51b692f2639649458fbc9a4f.pdf
ABS control module repair
Common issue?
Any 6 ft 6 tall people suffering from leg/hip pain?
I'm just a mere 6ft 4" but I had a similar problem with my Superb II to start with. Resolved by carefully bending the thick "outwires" under the side bolsters downwards and outwards. Now sorted, my future issue may be how on earth will I find something as comfortable when I change cars. One car I'm eyeing is the Audi A4 which has cracking seats for taller drivers. I feel for the OP and others over 6ft 4" - I always have trouble finding cars I'm truly comfortable in, especially as I get older. I'm finding the position and size of B pillars a problem as well - In many cars my right elbow ends up jabbing against it.
Superb 2010 trailer wiring
Check earthing on the trailer - can cause all sorts of weird issues. Earthing problems very common - especially if trailer has been stored outside.
RECALL
Re body control module - I've not had a recall letter and mine is a facelift - it's not listed as needing a recall on the gov.uk site either. I wonder if it is because mine is the poverty spec and has filament front indicators (LED rear). Re emissions - Do you still get a 2 year warranty on emissions related components - eg EGR valve - after the diesel emissions update? Just mentioning as some early adopters of this recall made good use of the extra warranty. Clearly this one not relevant for mine as it drinks from the other pump.
Roomster 1.4 petrol poor fuel economy
I had what I think was the same engine in my old Octavia NA 1.416v which was reasonably economical. Usually well over 40mpg on a run.
Battery drain cured
If bought a week ago - can't you take it back to be sorted?
INTERMITTENT flat battery
10.41volts after repeated attempts sounds like a dead cell on the battery - New battery time me thinks.
Skoda Superb Elegance TSI 1.8 2010 Oil Usage!!!!!
Indeed the higher power EA111 1.4 was a twin charger (turbo + supercharger) - this version was awful on many fronts. In the Skoda range of cars this was only fitted to the mkII Fabia VRS - I think? Lower power EA111 versions were much better but earlier versions could have cam chain/tensioner issues. The 125ps turbo (only!) is the version fitted to the 1.4 mkII Superb. The 1.4 Superb mkIII has the totally different cam belt EA211 engine.
2014 Auto Estate Flat Battery
Not AGM - EFB was/is fitted on my stop start. Original was a Moll and the replacement is YUASA 7000 EFB range. Saying that mine is also a tiddly 1.4tsi so probably has a smaller battery. Came with a 4 year guarantee - all in £99.84. Car has not bleated since even if left for many days and love it or hate it stop/start works a treat. Myself I don't mind it as except for a whir of a starter motor you don't really notice it.
DM Keith - Importance of air con service vs brake fluid change
I used DM Keith in Hull for my first few years of my car's life for servicing and found them very good and transparent. The brake fluid change is due after the first three years so surely the first MOT is the best time to do this as it will always be at three years old? After three years old for a few years I negotiated a cheaper service plan which was a lower cost for cars older than three years old and included MOT's, brake fluid changes and air conditioning servicing. They always did a good job and there was always evidence of more than an oil change and clean going on - when I was swapping to/from winter wheels you could see evidence of copper slip where brakes had been serviced etc. OK more expensive than my local independent, but I still found the costs pretty ok. Now my Superb II has got to the age(2014 - 91k miles) that things may need replacing more often I've moved my servicing back to my local Indy. Saying that it's not needed that much thus far.
Do you mean some 1.8 / 2.0 tsi engines have problems? My 1.4tsi Superb uses hardly any oil at 91k miles. Don't really need to top up between services. My son has a 1.2tsi Octavia that burns no oil at all. The 1.8 is well known for this - some do some don't. A friend of mine has a 1.8 tsi Yeti that's OK. I'm afraid this is a potentially expensive repair as it's a major engine rebuild.
