Everything posted by bigjohn
Skoda superb mk2 estate 2010 rear wheel arch rust - no repair part available?
Has the car had some previous accident damage? - I ask as the shut line between rear door and rear wing panel doesn't look quite right - or is it me? I suspect it's a fabrication job re wheel arch. Might be better anyway as sometimes rot on galvanised panels can be very localised indeed although post welding it'll need very thorough rust proofing. I kept a close eye on my mkII 2014 facelift hatch and to be honest there was zero rust on body panels but I regularly rustproofed, suspension parts were a different matter! I used to restore cars back in the day so I'm well experienced at welding in repair panels or fabrication. Those days are over for me though!!
Swapping Hitch
No. Every tow bar assembly after 1989 must be type-approved.
1.8tsi vs 3.6v6 advice
The 1.8 can have major problems re oil consumption & pistons. Saying that I have a friend who had the 1.8tsi in a Yeti that didn't suffer this. The v6 sounds fun! [EDIT] https://www.briskoda.net/forums/topic/261643-18-tsi-excessive-oil-consumption/page/2/
- Front Subframe bolts
Superb Mk2 Estate boot doesn't open fully
That's all my facelift 2014 twindoor ever did from when I bought it nearly new. I think that's normal - it's not a powered boot, the gas struts just help it stay put when raised. During my decade of ownership I usually opened as a hatch after reading about wiring issues within the twin door assembly. I only really used as a boot on a restricted height ferry or multistory car park.
Gearbox noise
Engine mount?
Speed limit warning.
Different car but the speed limit change subtle beep has probably already saved me from a speed awareness course. It beeped and I thought ????, I'd passed through an obscured speed limit sign, however almost immediately around a corner just after the change a speed van was in wait! Fortunately the car had already made me aware - phew.
Struggling to pull away.
Are you sure you are engaging 1st gear, it sounds like you are setting off in 3rd gear? Possible gear linkage mis alignment when the clutch was changed. Just a thought, I did a similar thing changing a clutch many moons ago. Could also be an engine / gearbox mount issue causing the same.
Skoda Rapid 1.2 Tsi 2015 hot engine start problem after a road trip
I think this engine has the same wasted spark coilpack module that my old 1.4 16v mpi Octavia mkI had that used to fail every 60k miles or so and was always sensitive to hot / and or cold when starting to fail - especially after a long run. Could be hard to start and / or stuttery when you floored the throttle as it tended to drop to two cylinders. Easy/cheap to replace. It didn't throw codes initially until really bad. One unit that was failing actually ended up with a big hole in it - that one fully dropped to two cylinders! IAs they were relatively cheap and I'd had a few fail in the cars life (19 years owned by the family - until my son broke it!) I even bought a spare. https://www.eurocarparts.com/p/starline-ignition-coil-41344029s As mentioned above double check you don't have a vacuum in the fuel tank after a run - it'll hiss as you undue if it has. When not starting it's worth dropping to first principals - after turning over for a while does it smell of petrol at the exhaust tailpipe, connect one of the leads to a spare spark plug and position against the engine metal - does it spark on turning over.
Crank, no start; very jerky crank though...
Missed the "Fixed" bit - nice one.
Great news re compression!
Even if it's the worst case scenario of the cam chain / low compression on a cylinder or two I can't imagine it jumping around on its mounts?? Mounts ok?
Had to revert to first principals recently to help out a friend with an old classic early 70's Daimler fitted with the fab xk engine. It had ground to a halt and he had been recovered , but since then he'd been "fettling" unfortunately. Live battery feeds disturbed and left loose, centre carbon missing in new distributor cap and he's scrambled the lead firing order (oh is that important!). Reverted to plugs out to feel the hiss of compression for each cylinder and note rotor arm position. Fit old but ok distributor cap, re fit points, replace condenser (knackered) and fix live battery lead trying to avoid welding socket set. Smell exhaust for petrol(it did!) etc........ It was like therapy , old style! After 30 mins ish it fired into life, probably the original fault was the condenser.
Probably not the issue and a bit like asking Grandma to suck eggs but - but is petrol being injected? Plug should smell of petrol, or even the exhaust tailpipe after a few attempted starts.
Dash cam and permanently live cigarette lighter
In my previous Superb mkII I used a Volton Split Charge Relay ZR1220 where I wired a 12v cig plug to connect to the car and also wired 2 12v inline sockets as the output. One powered my dash cam and the other powered a 12v coolbox when needed. Basically it detects when the car is charging and then switches the power through - works as default but there is a small potentiometer that you could adjust the trigger voltage if required, but take a note/photo of the start position. No longer required in my new car as the 12v sockets are only energised when car powered up. [EDIT]Photo shows when first installed with one socket for a cool box, second was added later:-
It's neither a goodbye nor a hello!
We've not quite achieved being a one car family yet as well - it appears my rust proofing and fettling of Mrs BJ's 2006 Fiat Panda has worked too well. It's worthless to sell but it's still in pretty good condition.
Blimey how hard did you drive your mkI Superb diesel? Mine seemed to always average about 50mpg unless just driven for a short local journey - it was only a poverty spec 1.9pd 100 though. Overall mpg of my following mkII Superb 1.4tsi was circa 46mpg but was much more variable compared to the mkI 1.9 pd. Fully laden would affect the mpg more in the petrol. I Suppose I've gone the opposite way from einrac changing from a Superb to a Swace (Corolla TS in drag) but I needed to downsize a bit as me and Mrs BJ are now retired and we don't need two cars but she found the Superb too big to drive locally etc. We contemplated an Octavia but the touch screen re basic function (eg heating) was a problem as Mrs BJ is a fully paid up member of the Luddite Society. I didn't get on with the Scala/Kamiq when I tried them - more to do with me as I'm 6ft4" and the lane assist stuff was bonkers.
1.5 SE TSI Idle
I think this is true on many recent petrol cars in varying implementations - it's to light up the catalyst. The colder it is the longer it is required for. Whilst the catalyst isn't up to temperature your car emits way more harmful emissions. Even my previous 2014 mkII Superb with the old EA111 1.4tsi petrol revved up to 1100 rpm for a while when cold. The evo 2 version of the 1.0 and 1.5 tsi has been used for a couple of years in the Kamiq/ Scala etc - this was first rolled out in the VW T-Roc. "This is an advanced efficiency engine and one of the improvements was a new catalytic converter that reaches its operating temperature more quickly."
Fabia mk.4 SE L 1L is there any adjustment on the brake pedal to make it a little lower?
Tell me about it, I sometimes drive Mrs BJ's Panda that has teeny pedals. The BIG problem is I have size 13/extra wide shoes!
skoda wont start after back wiper motor burned
Cars a very sensitive to low voltage these days - I'd start with a new battery unless it's very nearly new!
Such as?
What codes are stored - playing part replacement wont help other than making things worse? Check battery voltage as if on its way out can cause random problems,
Large oil consumption. 1,5L 1000km. 10W-40 ?
This is not a new problem but possibly made worse with long oil changes and low friction piston rings - all makes. Back in the day I used to try squirting in copious plus gas into each bore and leaving overnight before oil change. I used to then squirt in a touch of oil into each plug hole , turn engine over a then a thimble of petrol into each bore before starting. This same procedure was good for waking up gummed up or long dormant engines,
Superb/Octavia spare wheel kit
Bigger car means bigger pockets
the truth about electric cars
Even my hybrid seems to use regenerative braking most of the time. I've been advised by a friend who has run a few Toyota hybrids(does high mileage) to occasionally really use the brakes to clear disk surface but in doing so brake pads and disks will last for years and over 100k miles. Mine has only done 6k miles thus far so disks etc still look new. However you don't really notice what it's doing re braking/ regen, it's interesting if travelling down a hill with adaptive cruise engaged - if starting to increase speed you can tell that it tries regenerative braking first (and see on engine monitor) to steady the ship, then if needed it introduces engine braking (rev counter moves ) and if that's not enough the brakes are gently applied (I know as you can see the brake lights reflecting off things at night). Presumably electric cars are similar(but no engine!) but use more regenerative (bigger generator?) before requiring the brakes.
