Carlston
Everything posted by Carlston
  1. You can fit a 225/40R18 tyre to a rim width of between 7.5" and 9". However, Skoda normally fit a 225/40R18 tyre to the minimum 7.5" rim width. Fitting a 225/40R18 to a 9J rim will make the sidewalls very stretched which will leave the rims very exposed to kerbing damage and give a very hard ride. Because the sidewalls would be so stretched, the 225mm nominal width tyre will be closer to an actual width of 245mm. Being so wide, this could cause rubbing. As the 225/40 has very low sidewalls, the rims will be prone to getting damaged by potholes. 205/50R17 or 225/45R17 would give more comfort and protect the rims better than 225/40R18 tyres. 18" rims will make the 312mm diameter front brake discs on the VRS look small. 225/40R18 can be fitted to a rim width of 7.5-8-9.0 https://www.toyo.co.uk/tirefinder/index/width/225/aspect/40/rim/18 205/55R16 on perhaps 6.5Jx16 ET42 5/100 57.1 rims would be a lot more sensible and give a much better ride, far less prone to pothole damage, less drag, cheaper tyres, less prone to kerbing damage, and less tyre noise. Using standard tyre and rim sizes will also keep your insurance company happy. If you have a centre bore bigger than 57.1mm you would need to use spigot rings so that the rims are centred on the hubs. Not using them would cause wheel vibration as the rims wouldn't be centred.
  2. As you can see in the chart below, the Octavia MK2 came with either 6Jx15 ET47 or 6.5Jx16 ET50 steel rims. The 6Jx15 ET47 uses 195/65R15 tyres, and the 6.5Jx16 ET50 uses 205/55R16 tyres. Octavia MK2 Steel Rims 1 1K0601027K steel rim 6.5Jx16 ET50 1K0601027K 03C black 5/112 57.1 3 1K0601027C steel rim 6JX15 ET47 1K0601027C 03C black 5/112 57.1 https://skoda.7zap.com/en/cz/octavia/oct/2011-663/6/601-601010/ Alcar 9165 6Jx15 ET47 5/112 57.1 Steel Rim https://www.mytyres.co.uk/rims/details?vehicleId=183006013861926000&rimCode=ALCAR9165 Alcar 9915 6.5Jx16 ET50 5/112 57.1 Steel Rim https://www.mytyres.co.uk/rims/details?vehicleId=183006013861926000&rimCode=ALCAR9915
  3. 145/85R18 111M space saver tyre fitted to 4Jx18 ET28 steel rim https://eshop.skoda-auto.cz/cs_CZ/kompletni-rezervni-kolo-18/p/565601011C
  4. The Fabia MK1 1.9TDI 100HP car has standard ride height suspension. The Fabia MK1 1.9TDI 130HP car has lowered/sports suspension. By using the front springs from the 100HP standard ride height car and the rear springs from the lowered/sports suspension 130HP car, the car may end up looking like a speedboat, ie. the front end will look high compared to the rear end.
  5. Do you have 312mm or 340mm diameter front brake discs? Front brake pads for 312mm discs 1ZB 5Q0698151B (TRW brake system) 10 5Q0 698 151 B 1 set: brake pads with wear indicator for disc brake front 1 PR-1ZB https://skoda.7zap.com/en/cz/octavia/oct/2016-753/6/615-615030/ https://www.autodoc.co.uk/car-parts/oem/5q0698151b?search=OEN+5Q0698151B&supplier[0]=833&supplier[1]=3&supplier[2]=833&supplier[3]=3 https://www.ebay.co.uk/itm/165084816537?epid=249340333&hash=item266fd26499%3Ag%3A6fsAAOSwEVpbkQl2&LH_ItemCondition=1000 Front brake pads for 340mm discs 1LG 8V0698151C (TRW brake system) 10 8V0 698 151 C 1 set: brake pads with wear indicator for disc brake 340X30MM 1 https://skoda.7zap.com/en/cz/octavia/oct/2016-753/6/615-615040/#10 https://www.autodoc.co.uk/car-parts/oem/8v0698151c?search=OEN+8V0698151C&supplier[0]=833&supplier[1]=3 https://www.ebay.co.uk/itm/154614530144?epid=248947371&hash=item23ffbe8060:g:iYcAAOSwjkxbkQmB https://www.amazon.co.uk/TRW-GDB2114Â-Brake-Pad-disc-brake/dp/B06XYN4994/ref=sr_1_1?crid=3L3Z30IFIDDEE&keywords=trw+gdb2114&qid=1647046336&sprefix=trw+gdb2114%2Caps%2C57&sr=8-1
  6. Skoda dealers can't help you modify your car. All they can do is recommend what Skoda has approved. Slightly oversize tyres such as 225/55R17 fitted to standard 7Jx17 ET40 rims and 245/45R18 fitted to 8Jx18 ET44 rims will be fine. Many Superb MK3 owners are already using these sizes without problems.
  7. Over 60,000 miles or 100,000 kilometers and you are doing well. Less than 30,000 miles or 50,000 kilometers and you are not doing well. A lot depends on your driving style. Good drivers who plan well ahead, drive in an economical fashion, and maximise their use of engine braking to slow down, will have brakes that last a long time. It helps to have a diesel engine, because diesel engines produce more engine braking than petrol engines.
  8. I purchased four new Pirelli tyres many years ago. The beads split on all four tyres when fitting and removing them from the rims. Pirelli didn't want to know.
  9. 235/45R18 doesn't fit the ID.3...but 18" rims from the ID.3 do fit the Superb MK3. However, the ID.3's ET50 offset does move the centre of the tyre 6mm inwards compared to the Superb MK3's 8Jx18 ET44, or 4mm inwards compared to the Superb MK3's 7Jx18 ET46. The below alloy rim is almost three times the price of the steel 7.5x18 ET50 ID.3 steel rim...although many will look for cheaper secondhand options. Superb MK3 7.5Jx18 ET46 Alloy Rim https://eshop.skoda-auto.cz/cs_CZ/kolo-z-lehke-slitiny-trinity-18-pro-superb-ii-octavia-iii/p/3T0071498J+8Z8 It's nice to see a non-directional tread pattern on the Nokian WR A4. Most winter tyres these days seem to have a directional tread pattern.
  10. According to Jurid on autodoc, you have: Front Brake Discs 1ZA (ATE brake system) 312mm diameter Rear Brake Discs 1KJ (TRW brake system) 282mm diameter The 282mm rear discs appear to be the same as the 286mm rear discs. 312mm front brake pads 1ZA 3C0698151C 15 3C0 698 151 C 1 set: brake pads with wear indicator for disc brake front 1 PR-1ZA 312mm front brake discs 1ZA 1K0615301AA 8 1K0 615 301 AA brake disc (vented) 312X25 5/112 2 https://skoda.7zap.com/en/cz/superb/sup/2013-632/6/615-615030/ 282mm/286mm rear brake pads 1KJ 1K0698451G 10 1K0 698 451 G 1 set of brake pads for disk brake rear 286X12MM 1 282mm/286mm rear brake discs 1KJ 1K0615601AD (7) 1K0 615 601 AD brake disc 286X12MM 5/112 2 https://skoda.7zap.com/en/cz/superb/sup/2013-632/6/615-615065/
  11. I doubt you would even get a reply from Pirelli. They are Italian after all, so expect the usual non-existent customer service. Pirelli have a long history of selling shoddy tyres, so are best avoided.
  12. Some of the build codes are on the white sticker/label in the boot. Most are not. There might be around 180 build codes that are associated with your car's VIN number. Skoda would have known what all your car's build codes were going to be, even before it went down the production line to be assembled. However, now you know all the possible variations...it should be a simple job to measure the outside diameters of the brake discs to find out what you have. Possible front brake disc diameters for the Superb MK2 288mm, 312mm, 340mm, 345mm Possible rear brake disc diameters for the Superb MK2 260mm, 272mm 286mm, 310mm It's unlikely you will have the 340mm or 345mm diameter front brake discs, or the 310mm diameter rear brake discs...unless you have one of the most powerful cars.
  13. It depends on the build codes. For the Superb MK2, the build codes for the brakes are as follows: 1ZE 288mm front discs 1LJ or 1ZA 312mm front discs 1LA 340mm front discs 1LK 345mm front discs 1KF 260mm rear discs 1KS 272mm rear discs 1kJ 286mm rear discs 2EA 310mm rear discs https://skoda.7zap.com/en/cz/superb/sup/2013-632/6/
  14. Spacers change the offset. There's eight different offsets available for 6.5Jx16 5/112 57.1 steel rims. 6.5Jx16 ET33 Alcar 9922 https://www.mytyres.co.uk/rims/details?vehicleId=67955865910514800&rimCode=ALCAR9922 6.5Jx16 ET41 Alcar 8426 https://www.mytyres.co.uk/rims/details?vehicleId=1037328747869009008&rimCode=ALCAR8426 6.5Jx16 ET42 Alcar 8425 6.5Jx16 ET43 Alcar 9187 https://www.mytyres.co.uk/rims/details?vehicleId=1275188297127171184&rimCode=ALCAR9187 6.5Jx16 ET44 Alcar 9173 https://www.mytyres.co.uk/rims/details?vehicleId=80484800909022320&rimCode=ALCAR9173 6.5Jx16 ET46 Alcar 8667 https://www.mytyres.co.uk/rims/details?vehicleId=185949956245296240&rimCode=ALCAR8667 6.5Jx16 ET48 Alcar 7025 https://www.mytyres.co.uk/rims/details?vehicleId=83104387362198640&rimCode=ALCAR7025 6.5Jx16 ET50 Alcar 9915 https://www.mytyres.co.uk/rims/details?vehicleId=182274288873641072&rimCode=ALCAR9915 https://www.oponeo.pl/wybierz-felgi-stalowe#&&/wEXCwUTcGNrX1RyTFNCb2x0UGF0dGVybgUFNXgxMTIFC3Bja19UckxTQ2FyBQEwBQxwY2tfVHJMU0RpYW0FAjE2BQdwY2tfQ1BnBQExBQdwY2tfSVBQBQIxMgUTcGNrX1RyTFNDZW50cmFsQm9yZQUFNTcsMTAFFXBja19Mc3RTU29ydFBhcmFtZXRlcgUFNjU1MzYFFXBja19UckxTU29ydERpcmVjdGlvbgUBMgUNcGNrX1RyTFNXaWR0aAUFNiw1MEoFCHBja19JT0ZQBQIzMAUMcGNrX1RyTFNQSWRzBQIyMPVOgQhPzaF3ZLnbfTWPdylafDe3
  15. mytyres are listing 7.5Jx18 ET50 steel rims from the VW ID.3 that might be ideal for winter tyres. Not quite the same as the standard Superb MK3 rim specification, but close enough. 7.5Jx18 ET50 5/112 57.1 Steel Rims https://www.mytyres.co.uk/rims/details?vehicleId=1258516952071017584&rimCode=ALCAR9373
  16. It's a new engine, so the piston rings and cylinder bore are still bedding in. Just top up with quality engine oil to the maximum mark. Be careful not to go over the maximum mark...or at least not by more than a couple of millimetres. You will probably go more than 5300 miles before you need to top up again.
  17. I use one of these for my AGM battery. It's really simple to use, plus Bosch is a good make. In the UK you do need a Euro mains plug adaptor if you get the German version. Bosch C1 Battery Charger https://www.amazon.de/-/en/189-999-01M-battery-charger/dp/B00RP3DEW6/ref=sr_1_1?crid=TYL3MHAGUSON&keywords=bosch+c1&qid=1646504361&sprefix=bosch+c1%2Caps%2C76&sr=8-1 The 3.5Amps charge rate is ideal for almost any car battery. I certainly wouldn't want to charge a 12V 60Ah car battery at more than 4Amps. Gentle charge rates means that the battery lasts longer.
  18. Carlston replied to wd20's topic in Parts For Sale
    Good point about collection only, as clearly it would only suit someone local. However, it wouldn't be too difficult to wrap them in cardboard (perhaps old cornflakes packets) and post them economically by myHermes. About £5.80 up to 5kg for shipping by myHermes https://www.myhermes.co.uk/send-a-parcel#/ Then you could maybe charge £80 including postage, and still get a quick sale...perhaps on ebay. I would state clearly than these are 55mm struts and not the smaller 50mm struts...as that's an easy mistake for many folks to make. People would probably be searching for new "Bilstein 22-131614" and the cheapest price on ebay. Most sellers on ebay are asking over £120 for two.
  19. According to the Kilen online spring catalogue, these front and rear springs will fit all Skoda Rapid and Skoda Rapid Spaceback 1.2TSI models with a manual gearbox from 2012 to 2019...so includes the 86PS and 105PS 8-valve engines and the 90PS and 110PS 16-valve engines. https://www.kilensprings.com/ Skoda Rapid 1.2TSI Engines 1.2 TSI 63 kW 2012–2015 CBZA (EA111) 1197 ccm, I4, 8V SOHC, TSI, turbocharged 63 kW (86 PS; 85 hp) at 4800 rpm 160 Nm. (118 lb•ft) at 1500–3500 rpm 5-speed manual (MQ200), FWD 183 km/h (114 mph) 11.8 5.1 55.4 / 46.1 (4.9 / 57.6 / 48.0)* 119 (114*) 1.2 TSI 66 kW 2015– CJZC (EA211) 1197 ccm, I4, 16V DOHC, TSI, turbocharged 66 kW (90 PS; 89 hp) at 4400 rpm 160 Nm. (118 lb•ft) at 1400–3500 rpm 5-speed manual (MQ200), FWD 186 km/h (116 mph) 11.2 4.7 60.1 / 50.1 107 1.2 TSI 77 kW 2012–2015 CBZB (EA111) 1197 ccm, I4, 8V SOHC, TSI, turbocharged 77 kW (105 PS; 103 hp) at 5000 rpm 175 Nm. (129 lb•ft) at 1550–4100 6-speed manual (MQ200), FWD 195 km/h (121 mph) 10.3 5.4 / 52.3 / 43.6 (5.0 / 56.5 / 47.0)* 125 (116*) 1.2 TSI 81 kW 2015– CJZD (EA211) 1197 ccm, I4, 16V DOHC, TSI, turbocharged 81 kW (110 PS; 108 hp) at 4600 rpm 175 Nm. (129 lb•ft) at 1400–4000 6-speed manual (MQ200), FWD 200 km/h (124 mph) 9.8 4.9 / 57.7 / 48 110 https://en.wikipedia.org/wiki/Škoda_Rapid_(2012)
  20. Carlston replied to wd20's topic in Parts For Sale
    That may be a manufacturer's code of some sort, but it doesn't look like an OEM part number.
  21. Carlston replied to wd20's topic in Parts For Sale
    autodoc lists the Bilstein 22-131614 as suitable to replace the following OEM part numbers. autodoc are selling a new pair for about £140, so you could probably ask quite a bit more than your £40 asking price. Bilstein 22-131614 1T0413031 CJ CP DA DB DH EJ FF GG GH GN GP GQ HD HQ JK KA KB 5C0413031 AH AK BA BB BC DJ DP 1TD413031 D 1T0413031CJ 1T0413031CP 1T0413031DA 1T0413031DB 1T0413031DH 1T0413031EJ 1T0413031FF 1T0413031GG 1T0413031GH 1T0413031GN 1T0413031GP 1T0413031GQ 1T0413031HD 1T0413031HQ 1T0413031JK 1T0413031KA 1T0413031KB 5C0413031AH 5C0413031AK 5C0413031BA 5C0413031BB 5C0413031BC 5C0413031DJ 5C0413031DP 1TD413031D https://www.autodoc.co.uk/bilstein/633356?search=BILSTEIN Shock Absorber (22-131614)
  22. I don't know where Jurid gets their information, although I have noticed that they do often seem to know what size brake discs are fitted to various models...whereas most other brands will often list all the possibilities. I did check that the OEM part numbers for the 288mm front brakes discs and corresponding brake pads didn't change between when the Octavia MK3 was introduced and 2016 (the last year shown on the 7Zap Skoda online parts catalogue). There might be about 180 build codes or somewhere around that figure for each car, so most of the car's build codes aren't shown on that white sticker/label.
  23. What diameter front brakes discs do you have? 276mm, 288mm, or 312mm? Jurid on autodoc lists your car as having 288mm front brake discs, and I suspect this is what you have. This would mean that one of your car's build codes is 1ZE Front Brake Disc Pads 8V0698151 10 8V0 698 151 1 set: brake pads with wear indicator for disc brake 1 PR-1ZE TRW https://www.autodoc.co.uk/trw/7489103 ATE https://www.autodoc.co.uk/ate/7896677 Front Brakes Discs 1K0615301T 12 1K0 615 301 T brake disc (vented) 288X25 5/112 2 Bosch https://www.autodoc.co.uk/bosch/1165939 ATE https://www.autodoc.co.uk/ate/957612 https://skoda.7zap.com/en/cz/octavia/oct/2016-753/6/615-615020/#12
  24. If you saw a car fitted with a space saver tyre trying to avoid an unpredictable moose (ie. the moose test) you would see how wrong you are. It's like saying a drunk driver who doesn't drive over 50mph is perfectly safe as long as the pub isn't more than a couple of hours drive away.🤣😁
