Carlston
Everything posted by Carlston
  1. Goodyear EfficientGrip 2 SUV 235/65R17 108V XL Summer tyres B A 70dB £101.79 Goodyear EfficientGrip 2 SUV 235/60R18 107V XL Summer tyres B A 70dB £128.41 Goodyear EfficientGrip 2 SUV 235/55R19 105V XL Summer tyres B A 70dB £145.14 17" rims from the Kodiaq might fit the Enyaq https://www.mytyres.co.uk/rims/rim-selector?type=steel&vehicle_ids=639488607098246256
  2. The BMM engine has the following specification as you can see in the wikipedia chart below: 2.0TDI DPF 8v SOHC PD Pumpe Duse engine with 140PS at 4,000rpm and 320Nm at 1,750rpm Diesel engines 1.6 TDI DPF 1598 cc 16v DOHC common rail (CR) 105 PS (77 kW; 104 bhp) at 4,400 250 N⋅m (184 lbf⋅ft) at 1,500–2,500 CAYC 2009– present 1.9 TDI (3) 1896 cc 8v SOHC PD (Pumpe Düse - Unit Injector) 105 PS (77 kW; 104 bhp) at 4,000 250 N⋅m (184 lbf⋅ft) at 1,900 BJB, BKC, BXE, BLS 2004– 2010 2.0 TDI DPF 1968 cc 8v SOHC PD (Pumpe Düse - Unit Injector) 140 PS (103 kW; 138 bhp) at 4,000 320 N⋅m (236 lbf⋅ft) at 1,750 BMM 2007– present 2.0 TDI (4) 1968 cc 16v DOHC PD (Pumpe Düse - Unit Injector) 136 PS (100 kW; 134 bhp) at 4,000 320 N⋅m (236 lbf⋅ft) at 1,750 AZV 2004– 2008 2.0 TDI (4) 1968 cc 16v DOHC PD (Pumpe Düse - Unit Injector) 140 PS (103 kW; 138 bhp) at 4,000 320 N⋅m (236 lbf⋅ft) at 1,750 BKD 2004– 2008 2.0 TDI DPF 1968 cc 16v DOHC common rail (CR) 140 PS (103 kW; 138 bhp) at 4,000 320 N⋅m (236 lbf⋅ft) at 1,750–2,500 CBAA, CBAB, CBDB, CFHC 2010– present 2.0 TDI DPF RS 1968 cc 16v DOHC PD (Pumpe Düse - Unit Injector) 170 PS (125 kW; 168 bhp) at 4,200 350 N⋅m (258 lbf⋅ft) at 1,750 BMN 2006– 2008 2.0 TDI DPF RS 1968 cc 16v DOHC common rail (CR) 170 PS (125 kW; 168 bhp) at 4,200 350 N⋅m (258 lbf⋅ft) at 1,750–2,500 CEGA 2008– present Notes: (3) Diesel particulate filter available as an option (4) Diesel particulate filter not available https://en.wikipedia.org/wiki/Škoda_Octavia#Second_generation_(Typ_1Z;_2004) Take a photo of the build codes that are shown on the white label under the carpet near the spare wheel well. These might give the code for your front springs.
  3. OEM Part Number: N90813202 Specification: M14x1.5x22 21 N 90813202 seal bolt with sealing ring M14X1,5X22-TC- S20 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2003/drive_standart/252/hg_ug/103/subcategory/103010/part_id/2541323/lang/e This is a very common sump plug that is used in the following Skoda models: Skoda CIT Citigo 2012 2013 2014 2015 2016 Skoda FAB Fabia 2000 2001 2002 2003 2004 Skoda FAB Fabia 2005 2006 2007 2008 Skoda FAB Fabia 2007 2008 2009 2010 Skoda FAB Fabia 2011 2012 2013 2014 2015 Skoda FAB Fabia 2015 2016 Skoda FABI Fabia 2009 2010 2011 2012 2013 2014 Skoda OCT Octavia 1997 1998 1999 2000 Skoda OCT Octavia 2001 2002 2003 2004 2005 2006 2007 2008 2009 2010 2011 Skoda OCT Octavia 2004 2005 2006 2007 2008 Skoda OCT Octavia 2009 2010 2011 2012 2013 Skoda OCT Octavia 2013 2014 2015 2016 Skoda RAP Rapid 2013 2014 2015 2016 Skoda RAPI Rapid 2012 2013 2014 2015 2016 Skoda RO Roomster 2006 2007 2008 2009 2010 Skoda RO Roomster 2011 2012 2013 2014 2015 Skoda SUP Superb 2002 2003 2004 2005 2006 2007 2008 Skoda SUP Superb 2008 2009 2010 2011 2012 2013 Skoda SUP Superb 2014 2015 2016 Skoda YET Yeti 2010 2011 2012 2013 Skoda YET Yeti 2014 2015 http://www.oemepc.com/tvn_result/search/tvn/N 90813202 autodoc.co.uk lists these sump bolts in various aftermarket brands for under £2 each. https://www.autodoc.co.uk/topran/2724721 N90813202 Topran Germany (£1.69 including postage on ebay) https://www.ebay.co.uk/itm/114843270361?hash=item1abd313cd9%3Ag%3AG0cAAOSwaE9gv4s3&LH_ItemCondition=3
  4. Skoda Superb MK3 Alloy Rims https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?sort=priceAsc&q=%3AscoreDesc%3AcarType%3ASuperb%2BIII%2B%282015%2B%29&show=Page# Trinity Silver 7.5Jx18 ET46 Trinity Anthracite 7.5Jx18 ET46
  5. The quality of Bilstein B4 should be as good as OEM as they are fitted as standard to some cars. However, an aftermarket Bilstein B4 is made to replace many models so may not be exactly the same specification as the original one. I suspect some other makes would also be OEM quality, such as KYB, Optimal, Sachs. KYB, Optimal, Sachs https://www.autodoc.co.uk/car-parts/oem/5q0413023fh?search=OEN+5Q0413023FH&tduid=5aaf8162f465c2bb2a0fcbb5cced2565&supplier[0]=32&supplier[1]=85&supplier[2]=129
  6. These three Bilstein shock absorbers (two B4 and one B6) are sold to replace 5Q0413023FH but not 5Q0413023FM or 5Q0413023FN. https://www.autodoc.co.uk/car-parts/oem/5q0413023fh?search=OEN+5Q0413023FH&supplier[0]=16 However, KYB like the Sachs does sell a shock absorber that they sell to replace all three of those OEM part numbers and many other numbers too. KYB Front Shock Absorber https://www.autodoc.co.uk/kyb/14763810 It might be possible for the 5Q0413023FM and 5Q0413023FN to physically bolt on, but whether they would have the ideal damping characteristics or even the right compressed and uncompressed lengths...I don't know. I would want to know what springs these shock absorbers are made for. Are they sports/lowered ride height springs, standard springs, off-road/increased ride height springs? Maybe there's a reason Bilstein isn't selling a shock absorber to replace all three of those OEM part numbers, or it could just be an oversight on Bilstein's part.
  7. I think you mean 225/45R18. wheel-size.com and "skoda eshop cz" are showing 7.5Jx18 ET48 https://www.wheel-size.com/size/skoda/octavia/2021/ https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?sort=priceAsc&q=%3AscoreDesc%3AcarType%3AOctavia%2BIV%2B%282019%2B%29# However, you can get 7.5Jx18 ET50 steel rims from the VW ID.3 that would fit as the offset is only 2mm different. Might be ideal for winter tyres.
  8. SACHS 315 910 is sold to replace all of these OEM part numbers: Note that 5Q0413023FM and 5Q0413023FN are Seat OEM part numbers, not Skoda OEM part numbers. Entering these two OEM part numbers into the "VW online parts catalogue" will also confirm that they are only listed against Seat models and not Skoda models. SACHS 315 910 Front Shock Absorber OEM reference number(s) comparable with the original spare part number OEN 5Q0 413 023 CP — AUDI OEN 5Q0 413 023 DA — AUDI OEN 5Q0 413 023 DB — AUDI OEN 5Q0 413 023 DQ — AUDI OEN 5Q0 413 023 DR — AUDI OEN 5Q0 413 023 EB — AUDI OEN 5Q0 413 023 FQ — AUDI OEN 5Q0 413 023 FR — AUDI OEN 5Q0 413 023 GG — AUDI OEN 8V0 413 023 C — AUDI OEN 8V0 413 023 D — AUDI OEN 8V0 413 023 E — AUDI OEN 8V0 413 023 F — AUDI OEN 8V0 413 023 N — AUDI OEN 5Q0 413 023 FM — SEAT OEN 5Q0 413 023 FN — SEAT OEN 5Q0 413 023 FP — SEAT OEN 5Q0 413 023 EB — SKODA OEN 5Q0 413 023 EN — SKODA OEN 5Q0 413 023 EP — SKODA OEN 5Q0 413 023 EQ — SKODA OEN 5Q0 413 023 ER — SKODA OEN 5Q0 413 023 ES — SKODA OEN 5Q0 413 023 ET — SKODA OEN 5Q0 413 023 FH — SKODA OEN 5Q0 413 023 FJ — SKODA OEN 5Q0 413 023 FK — SKODA OEN 5Q0 413 023 FL — SKODA OEN 5Q0 413 023 FR — SKODA OEN 5Q0 413 023 GJ — SKODA OEN 5Q0 413 023 CK — VW OEN 5Q0 413 023 CL — VW OEN 5Q0 413 023 CM — VW OEN 5Q0 413 023 EN — VW OEN 5Q0 413 023 EP — VW OEN 5Q0 413 023 EQ — VW OEN 5Q0 413 023 ER — VW OEN 5Q0 413 023 FA — VW OEN 5Q0 413 023 FB — VW OEN 5Q0 413 023 FC — VW OEN 5Q0 413 023 FD — VW OEN 5Q0 413 023 FE — VW OEN 5Q0 413 023 FF — VW OEN 5Q0 413 023 FH — VW OEN 5Q0 413 023 FJ — VW OEN 5Q0 413 023 FK — VW OEN 5Q0 413 023 FL — VW OEN 5Q0 413 023 GP — VW OEN 5Q0 413 023 GQ — VW OEN 5Q0 413 023 GR — VW OEN 5Q0 413 023 GS — VW OEN 5QM 413 023 AB — VW OEN 5QM 413 023 AC — VW OEN 5QM 413 023 AD — VW OEN 5QM 413 023 AE — VW OEN 5QM 413 023 AF — VW OEN 5QM 413 023 AJ — VW OEN 5QM 413 023 AK — VW OEN 5QM 413 023 AL — VW OEN 5QM 413 023 AN — VW OEN 5QM 413 023 K — VW OEN 5QM 413 023 P — VW OEN 5QD 413 023 K — VW (FAW)
  9. That guide doesn't seem right. Maybe use Skoda's recommended tyre pressures instead.
  10. Have you got 288mm or 312mm diameter front brake discs? The 312mm diameter brake discs on the Octavia MK3 is a TRW system not an ATE system. On the 312mm system, the OEM part number of the brake pads is 8V0698151B and the OEM part number of the front discs is 1K0615301AA Skoda Octavia 2016, floating caliper brake front PR-1ZA http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/615/subcategory/615025/part_id/2550123/lang/e
  11. There's many variables involved. The steering is going to feel less sharp with winter tyres on narrower 6.5Jx17 ET41 rims than UHP (Ultra High Performance) summer tyres such as Michelin Pilot Sport 4 215/55R17 98Y XL on wider 7Jx17 ET40 rims. Not only that, but the 215/55R17 will be more comfortable and more resistant to pothole damage. https://www.mytyres.co.uk/rshop/tyre/Michelin/Pilot-Sport-4/215-55-ZR17--98Y--XL/R-367126 Skoda Superb MK3 2.0TDI 190PS – Generation: III B8 (3V) Facelift [2020 .. 2022] – Power: 188 hp | 140 kW | 190 PS – Engine: 2.0L, I4, Diesel – Options: SE L, Style, SportLine, SportLine Plus, L&K – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: unknown – Thread Size: M14 x 1.5 – Trim Production: [2020 .. 2021] Tire Rim 215/55R17 94V 6.5Jx17 ET41 2.3 / 2.1 215/55R17 94V 7Jx17 ET40 2.3 / 2.1 235/45R18 94W 8Jx18 ET44 2.4 / 2.2 235/50R17 96W 7.5Jx17 ET40 2.3 / 2.1 235/40R19 96W 8Jx19 ET44 2.4 / 2.2 235/35ZR20 92Y 8Jx20 ET40 2.6 / 2.4 https://www.wheel-size.com/size/skoda/superb/2020/#trim-20tdi-eudm-188
  12. The standard ride height rear springs on the Octavia MK3 2.0TDI estate will be OEM part number 5Q0511121AF or something similar. You could change these for OEM part number 5Q0511121BF such as Eibach R10793 https://www.autodoc.co.uk/eibach/16620562 5Q0511121BF have an uncompressed length about 15mm longer than 5Q0511121AF and the wire thickness is 0.5mm more. (1) 5Q0511121AF coil spring Model data: PR-1JA+0YF (1) 5Q0511121BF coil spring Model data: PR-UC7+0YF Notice that both 5Q0511121AF and 5Q0511121BF are weight range 6 springs. 0YF means weight range 6 1JA means standard ride height springs UC7 means increased ride height springs VW Codes Decoder http://igorweb.org/equidec.aspx rear axle | Skoda Octavia 2016, suspension gas shock absorber PR-0N1 http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/511/subcategory/511000/part_id/2562804/lang/e front axle, steering | Skoda Octavia 2016, coil spring http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/411/subcategory/411030/part_id/2543614/lang/e A similar thing can be done on the front, by replacing the standard 5Q0411105GK or similar with either 5Q0411105HR or 5Q0411105HR Sachs 5Q0411105HR https://www.autodoc.co.uk/sachs/15244153 Sachs 5Q0411105HS https://www.autodoc.co.uk/sachs/15244154 The increased length and stiffness of the front and rear springs should result in an increased ride height of about 25mm. If you need even more ride height, changing 195/65R15 or 205/55R16 tyres to 205/70R15 or 215/60R16 should gain a further 15mm. The 205/70R15 size is particularly useful if All-Terrain tyres (good in mud) are needed, such as Bridgestone A/T. Bridgestone Dueler A/T 001 205/70 R15 96T https://www.mytyres.co.uk/rshop/tyre/Bridgestone/Dueler-A_T-001/205-70-R15-96T/R-341387
  13. The front springs on a 2014 Octavia MK3 Estate will vary depending on what engine and gearbox is fitted. For example, a 2.0TDI with DSG will have stiffer front springs than a 1.4TSI with manual gearbox as the weight of the former is quite a bit heavier than the weight of the latter.
  14. According to wheel-size.com 195/55R15 is a standard tyre size on the Fabia MK2 1.2TSI wheel-size.com often make mistakes, so see what the label says on the inside of your petrol flap. Maybe even take a photo of it. The label will tell you what the standard tyre sizes are and what the associated tyre pressures should be. Skoda Fabia 2014 1.2TSI – Generation: Mk2 (5J) [2007 .. 2014] – Power: 84 hp | 63 kW | 86 PS – Engine: 1.2L, CBZA, I3, Petrol – Center Bore: 57.1 mm – PCD: 5x100 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: unknown – Thread Size: M14 x 1.5 – Trim Production: [2010 .. 2014] Tire Rim 185/60R14 82H 6Jx14 ET37 2.2 / 2.1 195/55R15 85H 6Jx15 ET43 2.1 Skoda Fabia 2014 1.2TSI – Generation: Mk2 (5J) [2007 .. 2014] – Power: 103 hp | 77 kW | 105 PS – Engine: 1.2L, CBZB, I3, Petrol – Center Bore: 57.1 mm – PCD: 5x100 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: unknown – Thread Size: M14 x 1.5 – Trim Production: [2010 .. 2014] Tire Rim 185/60R14 82H 6Jx14 ET37 2.2 / 2.1 195/55R15 85H 6Jx15 ET43 2.1 https://www.wheel-size.com/size/skoda/fabia/2014/#trim-12tsi-eudm-103
  15. The below link shows three different spare wheel replacement kits for the Octavia MK3: Scout, RS, standard. It includes everything except the spare wheel (205/55R16 fitted to a 6.5Jx16 ET46 steel rim). https://eshop.skoda-auto.cz/cs_CZ/sady-pro-vymenu-kol/c/setsToChangeWheels?q=%3AscoreDesc%3AcarType%3AOctavia%2BIII%2B%282017%2B%29%3AcarType%3AOctavia%2BIII%2B%282012-2017%29 Spare wheel replacement kit 1025CZK (about £34.43) OEM part number: 5E0093860B With the OEM part number, you should be able to order from a local Skoda dealer. Complete spare wheel 16" https://eshop.skoda-auto.cz/cs_CZ/kompletni-rezervni-kolo-16/p/5E0601011J
  16. Varta is one of the top brands. It's a false economy to go with one that won't last so long. Varta https://www.varta-automotive.com/en-gb/battery-finder?number_plate_1=lm03ypc&number_plate_2=&find=find Varta D15 https://www.ebay.co.uk/sch/i.html?_from=R40&_nkw=varta+d15&_sacat=0&LH_TitleDesc=0&_sop=15&rt=nc&Brand=Varta&_dcat=61504 Width: 175mm Height: 190mm Length: 242mm
  17. 16" wheels will fit if the front discs have a diameter of 312mm or less. This would allow much cheaper tyre sizes such as 215/60R16. On narrow 6Jx16 ET40 rims (from the Superb MK1) the spare wheel might fit flush in the spare wheel well. Vredestein Quatrac 6 215/60R16 99V XL https://www.camskill.co.uk/m139b0s8007p202130/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_-_215_60_R16_99V_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_2_Noise%3A_71dB 6Jx16 ET40 5/112 57.1 Steel Rim (from the Superb MK1) https://www.mytyres.co.uk/rims/details?vehicleId=180495828815717488&rimCode=ALCAR9490 2020 Auto Bild All Season Tyre Test 1st Goodyear G3 2nd Vredestein Quatrac 6 3rd Continental AllSeasonContact 4th Michelin CrossClimate+ https://www.tyrereviews.com/Article/2020-Auto-Bild-All-Season-Tyre-Test.htm However, the test appears to be biased towards the Goodyear as it was a Goodyear test track and the Vredestein won more tests than the Goodyear. I would place the Vredestein Quatrac 6 in 1st place. The Vredestein was unfairly downgraded from 1st place to 2nd place by pretending that the Vredestein is more expensive than the Goodyear, when in fact the Vredestein is usually cheaper than the Goodyear. For example, on camskill in size 215/60R16 the Vredestein is currently listed at £82.05 whereas the Goodyear is listed at a far more expensive £113.90 215/60R16 All-Season Tyres https://www.camskill.co.uk/m139b0s8007p0/All_Season_-_Four_Season_-_All_Weather_-_Car_MPV_Tyres_-_16_inch_R16_inch_-_215_60_16_215_60R16
  18. One of these "car voltmeters" will tell you if electricity is being supplied to the cigarette lighter socket. https://www.ebay.co.uk/itm/193305186853?hash=item2d01e31225:g:844AAOSwiZddLWtX
  19. The front shock absorbers come in two types depending whether your strut has an outside diameter of 50mm or 55mm. Front Shock Absorber Bilstein B8 35-229902 (Strut outside diameter 50mm) https://www.autodoc.co.uk/bilstein/7522723 Front Shock Absorber Bilstein B8 35-229919 (Strut outside diameter 55mm) https://www.autodoc.co.uk/bilstein/7522724 Rear Shock Absorber Bilstein B8 24-229937 https://www.autodoc.co.uk/bilstein/7522727 It's possible that the above information is incorrect, so check with the seller before purchasing.
  20. 195/65R15 6Jx15 ET43 from the Octavia MK3 would also work with snowchains on the Superb MK2 (provided the front brake discs don't have a diameter larger than 288mm). https://www.mytyres.co.uk/rims/details?vehicleId=502374009556440176&rimCode=ALCAR7755
  21. There can be big savings on the 195/65R15 size over the 205/55R16 size when it comes to winter tyres. Some insurance companies don't charge extra, because a narrower tyre doesn't increase performance. Continental WinterContact TS870 195/65 R15 91T £58.44 https://www.mytyres.co.uk/rshop/tyre/Continental/WinterContact-TS-870/195-65-R15-91T/R-420993 Continental WinterContact TS870 205/55 R16 91T £82.61 https://www.mytyres.co.uk/rshop/tyre/Continental/WinterContact-TS-870/205-55-R16-91T/R-420998
  22. The Skoda online parts catalogue refers to the 288mm diameter front discs on the Superb MK2 as being suitable for 15" wheels. wheels, brakes | Skoda Superb 2012, floating caliper brake brake caliper housing calliper carrier brake disc (vented) front TEVES 288X25MM 15" PR-1ZE http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2012/drive_standart/632/hg_ug/615/subcategory/615025/part_id/2550123/lang/e
  23. The front brake discs will have a diameter of either 288mm or 312mm depending on the build code. Build Code: 1ZE 288mm http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2012/drive_standart/632/hg_ug/615/subcategory/615025/part_id/2550123/lang/e Build Code: 1LJ or 1ZA 312mm http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2012/drive_standart/632/hg_ug/615/subcategory/615030/part_id/2550123/lang/e Take a photo of your white build code label/sticker (in the boot area) as that might show a 1ZE, 1LJ, or 1ZA build code. Not all build codes are shown on the white build code label in the boot so it might not show any of these build codes. Alternatively, measure the diameter of the front discs or check if a 15" wheel will fit over the front brake calipers. If a 15" wheel will fit over the front brake calipers it means that you have the 288mm diameter front brake discs as a 15" wheel won't fit over the brake calipers on the larger 312mm diameter front brake discs.
  24. Skoda Superb MK2 Brakes http://www.oemepc.com/skoda/parts_lst/markt/CZ/modell/SUP/year/2012/hg/6/catalog/sk/drive_standart/632/lang/e
