Everything posted by UndertheRadar
Tonneau cover
I haven’t priced around yet and likely won’t until after the holidays, but a genuine one looks like it’s the guts of £400, so best get it replaced while you can.
Tonneau cover
Has anyone else had any issues with the estate tonneau cover failing. My first one failed under warranty and was replaced at just under 3yrs and no more. The replacement has failed again today, so has lasted about 3.5yrs. Both failed in the same way. If you don’t take the tension when opening, it goes off like an IED and tries to take the rear seats with it. 🤣
- Limp Mode and Persistent Error Code - P06DA00 Engine Oil Pressure Control Circuit/Open - Repair or Reject?
Rough idle in eco mode
As above. Nothing wrong with genuine plugs and coils. Several aftermarket coils and plugs available. No real point until you reach around stage 3 onwards though IMO. Running perfectly when warm and lumpy when cold points more towards carbon build up. Could be contributed to by cheaper fuel, driving style or possibly the map is over fuelling at times leading to excess carbon.
Increasing the visibility of the main beam warning light
I haven’t looked at settings in a bit but there might be a speed adjustment for the lights reaction time. I can’t remember.
- Rough idle in eco mode
I just put my headlights in auto and leave the system to do its thing. Brilliant system and one of the most useful features in the car in my opinion. I have it in constant use in the evenings at this time of year and find it helps fatigue on dark roads no end. Maybe try trusting it to do its job for a night or two and see how it goes. From auto, push the stalk forward to go into manual high beam, and then pull back to turn system off completely.
A lot of poorly set maps cause over fueling. Carbon issues, oil dilution, turbo failure and engine failure etc etc. Just walk away. They are clearly not going to allow any workshop time allowance towards the car or they already would have before sale. Aftermarket warranty will refuse cover as the vehicle is modified. The dealer will fob you off and then disappear as you knew it had faults before purchase. The equivalent 5 series is a 540i. The B58 unit is solid and easily tuned as well. Both will be solid vehicles as long as you choose the right one.
If the software is causing a rough idle or misfire I’d avoid the car completely. No idea how long it’s been driven like that. Also, if caused by the Mapping, it’s a shockingly poor calibration. And again vehicle should be avoided. If the dealer can’t solve a misfire before selling the vehicle, I’d avoid them as well.
Engine oil for Superb III 2.0 TSI DNUA
Oil change even at the lower mileage always makes a noticeable difference. DSG oil was changed at something like 26-27k the first time and then yesterday again at 52k. DSG oil was slightly brown but not bad. Oil change has made a very noticeable difference in smoothness and changes even at the low service interval. It’s due plugs again next year and I think I’ll replace all the coils as a precautionary measure to avoid even a slight miss, at the same time. Can’t do any harm, except to my wallet.
Revo advice for mine at stage 2 was genuine plugs and OEM oil. With the only restriction being that they are both changed more frequently. I normally run Castrol LL at 5w-30. None available when I needed it, so have as of yesterday, changed the oil with Castrol LL 0w-30. This leaves my personal intervals at 6 months instead of 12, and about 5k miles between changes. DSG also running Revo software, and I had already dropped the factory interval for oil change down to every 3 yrs instead of 80k. DSG serviced yesterday as well for the second time at 52k with genuine bungs, filters and oil from TPS.
Castrol Edge VW 504 00/507 00 Black Friday deal
Halfords have an offer on it at the minute as well, along with the 0w-30 5ltr as well.
Sportline suspension upgrade
Failure points that are very common are seal failure and corrosion. I’ve seen the earlier ones gone after 2-3yrs. Not sure when the revised shock was released to apparently counter these issues. But if you drive anywhere with salt during the winter, I’d still be very cautious, as that has to date been its biggest killer.
I’m surprised at the retailer telling you the failure is unusual. It is actually a very common fault with the SA shocks.
The 280PS Thread
I have the H&R front and rear bar. No issues. Works very well. No noise problems with the supplied H&R bushings. If you fit the rear bar as well you will need to upgrade the drop links as the factory units will snap.
Knocking from Rear... Shocks or wishbone?
The bush on the rear trailing arm is a known point for knocking. I’d have the shocks checked first though. Seen a few cases where the special actives fail early.
Groaning sound whilst steering at low speeds
B6 damptronics along with Eibach pro springs. Bilstein top mount and OEM bearings. Has been fitted for several years now without issue. No noise at all. Front Lower arm rear bush fitted with the TTS solid bush. Fixed the creak noise during slow manoeuvring or stop and go traffic. Lower arm front bush now noisey over speed bumps when it gets dry. If sprayed with silicone lube, it’s as quiet as a mouse. Still undecided as to what I’m going to press in yet to try and rectify.
Spray the lower arm bushes with silicon and see if the noise goes away for a bit.
Extended Warranty do I this year ?
Yes, that’s the best thing to do. I would absolutely do as everyone else has suggested.
2 ltr TSI 190, any problems
272 with 50k. No oil top ups or chain issues. Water pump leaking would be the main one. The older gti and vrs units would have seen the most issues with chains.
Rear brake pad change disaster
Did you bleed all 4 lines or just the rear that popped out? I’d be inclined to try bleeding the entire system first at all four corners and then check for leaks while the pressure is still on the system. Then see how the pedal feels.
The vehicle is maintained properly and running well because of it. Peace of mind and contentment is all the silver lining needed. IMO anyway!!
- Superb Estate Luggage Cover - Cleaning
Vibration when braking with new brakes.
Is it a caliper issue that takes a while to stick again after opening the piston to fit the new pads? Is one wheel warmer than the other after a drive? Try taking the pads out again and pushing the piston back and pumping it out again, a few times and then retest for the vibration again.
Superb 280 which oil
I was told by several different VAG techs that I know, that it was 0w-30 from the gen3 GPF unit. It came out of the factory with this grade to comply with the WLTP standards and would then be changed back to 5w-30 at the first service.
