TheUltraRunner
Everything posted by TheUltraRunner
  1. Nice figures. But the torque is a bit high for a manual. Did you upgrade the clutch? If not, I would suggest doing it soon.
  2. Hmm never heard of that. Will definitely try it out. Thanks.
  3. 1969 is the current version. And I doubt that the reason for not being able to login is in the SW version. Please check with official Škoda dealer if you are verified as an owner of the car.
  4. So it looks like just these metal clips hold the vent inside the dash and nothing more.
  5. A little bit better view on this pic. You just need a lot of patience and NO force to unclip 2 and 3. Nr 1 then goes out easily.
  6. I have changed the oil at 60k km (not sure if the filter was changed or not since it was not an official Skoda dealer), but the shop strongly recommended the original oil. I also did some research and mostly original oil is recommended.
  7. You are most welcome. I must say I have already removed one the plastics around rear view mirror, the front door panels and all the panels in the trunk. And didn't have any issues putting them back. Just need to be careful not to brake any clips.
  8. USB C Anschluss Innenspiegel nachrüsten.pdf I have this manual for installing the USB C port. It's in German. You can use google translate. I hope it helps.
  9. I would go over it with a fine sandpaper and then 2 or 3 layers of black matt paint.
  10. If you have Canton, there is already a mid speaker there.
  11. Since I installed a new exhaust I rarely see mpg over 30 😁
  12. Hi, You are correct. Meteor/Steel Grey was discontinued quite soon after the launch of the mk4 Octavia. End of 2021 I believe. This is why the color is quite rare. The VRS can't be speced currently because the new FL one is coming out soon.
  13. Thanks. Looks quite nice. You have an interior with a grey stitching ?
  14. Still much better than Octavia which has no sound at all.
  15. @Mario_Delgado do you have any pictures how does it look in real life?
  16. I found only these https://www.kopacek.com/skoda/octavia-iv/octavia-iv-original-skoda-autoas-interior-door-sills-with-backlight
  17. These are the Ergo premium seats. Alcantara on in the middle sections surrounded by leather.
  18. It looks like the part number is 5E3 071 303
  19. That is quite a milage for a car being under 2 years old.
  20. I have issues with mine. On the same side as you. It had water inside for the whole winter. Unfortunately mine is already out of the warranty. I already bought a new one a few months ago and was waiting for the right moment to change it. But a month ago I tried to dry it out with a hairdryer and since then it has been without any water. Need to rethink if I will change it or not.
  21. It is there now. I would says the engine runs pretty normal. As far as I know (I'm not a mechanic though) all direct injection engines are quite loud. That tapping sound are injectors doing what they supposed to do.
  22. Bumping up this thread a bit. 🙂 I have just installed new adjustable coilovers by KW. And new rims.
  23. Hi, Nothing shows on your link. I would suggest uploading the video to Youtube. Are you talking about the noise when the RPMs are dropping to the normal idel RPMs? You can hear it in my video below
