Everything posted by Binx1310
I had the aerial one and it went away again. If DAB works then it can be ignored. Looks like you’ve missed the confirmation of update step. Instructions can be found here: https://www.briskoda.net/forums/topic/514645-how-to-guide-for-mib-firmware-update/#comment-6003673h Did you get the Ali express camera? Some I got in install at this post. https://www.briskoda.net/forums/topic/454623-what-have-you-done-to-your-superb-iii-today/page/195/#findComment-5986858 Just make sure you’re careful routing wires around airbags. Worst bit is through the boot and the rubber gaiter. A spray of wd40 inside the rubber helps.
Nah not for me. I like the look on yours though.
Superb Mk3 Estate 190PS TDI DSG MY2015 SE L Executive - Moon White
Penultimate Sportline-a-like upgrade. 8mm black trim strip added to the the lower door trim. https://a.aliexpress.com/_EISPHpy OEM has a recess so would have had to change entire colour matched lower trim piece to get a completely stocked look. Yet again @JR RS leads the way with adding an external trim strip to achieve the same effect. Just the roof rails to change now for the full black out of chrome.
Penultimate Sportline-a-like upgrade. 8mm black trim strip added to the the lower door trim. OEM has a recess so would have had to change entire colour matched lower trim piece. Yet again @JR RS leads the way with adding an external trim strip to achieve the same look. Just the roof rails to change now for the full black out of chrome.
No Blower Fan
Thanks @Cairus for the correction. The wiring diagram is confusing as it shows the BCM on the same page so I assumed there was some connection to it. apologies for any confusion. Yes this fuse box is the one accessed by pulling down the glovebox door on a RHD
No Blower Fan
The air blower is supplied by a 30A fuse in slot 14. If this is ok then its power comes from the BCM. The BCM’s job is to monitor voltages and cut power if there is any problem. But this should give a fault code if its active.
Under Passenger Seat Loom Help
I think it’s to do with the canton amp for the big purple plug. Seems to be a frame on the floor for holding some kind of unit. If you don’t have a unit you need one! Can be seen in this post: https://www.briskoda.net/forums/topic/520388-superb-iii-sportline-mission-impossible-spec/
Standard or Damptronic dampers?
And yes start stop as standard. But you can code this out or get a module to plug in to the back of the button to keep it off.
2.0 Skoda 2.0 220 DSG Oil Change Missed
Only way is driving it. Checking for jerky erratic changes or over revving. I bought my one at 125,000 miles that had its first gearbox service at 110,000. I’ve done another at 129,000 to be sure. Garage said the oil was clean and the car drives fine. Might be a ticking timebomb but there’s no way of knowing. Personally I felt the risk was worth it to get the car I wanted.
No Blower Fan
Has it been scanned for codes? Worth going to a VAG specialist to scan if you don’t have the kit yourself.
Retrofit Reverse Camera
I got mine from AliExpress. OEM fitment in the boot handle and connects to the back of the unit in glovebox. Approx 2 hours to fit. Worst bit was running the cables. There’s plenty of guides on here. Have a search. About £40 all in.
Replacing drivers door inner rubber seal
Hi. I have this issue too. I have ordered a replacement seal from a wreckers. Is the seal shaped and fits a certain way or can you fit it any way?
Yeah. Got there in the end. I had the paddle extensions already so had to find a wheel to fit them onto eventually!
Haha. Bitten by the bug! You need to match your button type and spec (heated / not heated) and if you get it right it’s a 10 minute job to swap once you have the right one.
New (non dimming) mirror glass installed this evening. It doesn’t have the clip for the dimming wiring plug so I had to tuck it away. Initially it fouled the swivel movement so had to very carefully take the glass off again and tuck it away a bit neater. I also received the third attempt at buying a steering wheel with DSG. This time it was listed as for a karoq with part number 3V0419091AB. It is completely identical to my current wheel but with the addition of DSG paddles. It came with the usual wreckers grime but 5 minutes with some autoglym leather cleaner and a damp cloth and it looks good as new. Silky smooth with a nice matt finish. What was described as a scuff on the wheel in the eBay listing turned out to be a dirty mark which cleaned up fine so that was a bonus. The vehicle it came from had only done 38,000 miles so I’ve ended up with a steering wheel significantly newer and in better condition than my old one too! The addition of some alloy DSG extension paddles completes the look. https://a.aliexpress.com/_EvShoRU
New (non dimming) mirror glass installed this evening. It doesn’t have the clip for the dimming wiring plug so I had to tuck it away. Initially it fouled the swivel movement so had to very carefully take the glass off again and tuck it away a bit neater. I also received the third attempt at buying a steering wheel with DSG. This time it was listed as for a karoq with part number 3V0419091AB. It is completely identical to my current wheel but with the addition of DSG paddles. No idea what makes it different from 3V0419091S and 3V0419091M as they look the same too. But those ones are listed as for a superb and tend to be significantly more expensive. It came with the usual wreckers grime but 5 minutes with some autoglym leather cleaner and a damp cloth and it looks good as new. Silky smooth with a nice matt finish. What was described as a scuff on the wheel in the eBay listing turned out to be grime so that was a bonus. The vehicle it came from had only done 38,000 miles so I’ve ended up with a steering wheel significantly newer and in better condition than my old one too! The addition of some alloy DSG extension paddles completes the look. (Thanks again @JR RS for the link!) Will I use them? Probably not. Do I love them? Most definitely.
Round steering wheel with DSG paddles
The punt on a karoq wheel paid off. 3V0419091AB is identical to my standard 3V0419091L but with the addition of paddles. All installed and working with no issues. I guess most MQB wheels of the same general age/generation are interchangeable.
Recirculating Button not working
If it’s got warranty and the warranty covers it the it’s 100% back to the dealer job.
Yes will replace with cheap For now and keep An eye out for a cheaper one. Was considering adding bsd but will probably add the one in the mirror cap.
Climate control issue
Have you run a check for fault codes?
No worries. That’s the joy of a forum. Everyone gets to chip in and you learn a lot! Fingers crossed the wheel works as I hope!
The trouble with wreckers now is they all see the prices achieved on eBay so there’s no bargains anymore. Getting there finally. Got a few more fix up jobs and cosmetic thing to do. Then I’m deleting AliExpress app!
AliExpress delivery day today for a few more upgrades. First off - battery clamp that I found was missing. Nice easy fit. https://a.aliexpress.com/_EvpbmXk Black Sportline badges (not the best photo as it was getting dark) https://a.aliexpress.com/_Ey0q3ro Black mirror caps https://a.aliexpress.com/_EyOVXV4 Again a relatively easy fit. Although the glass takes quite a bit of force to remove. As @JR RS found, the Chinese copies have the middle fixing tab in the wrong place. But secure well using the two side catches. Unfortunately the passenger side didn’t go so well…. I was shocked at the price of the auto dimming glass. £300+! So I shall squint into a £25 non dimming version in future. https://www.carwingmirror.co.uk/skoda-superb-wing-mirror-glass/skoda-superb-wing-door-mirror-glass.html Also in the delivery was some spare trim screws as I seem to lose a couple every time I take out the arch liners! https://a.aliexpress.com/_EQd73PY
AliExpress delivery day today for a few more upgrades. First off - battery clamp that I found was missing. Nice easy fit. Black Sportline badges (not the best photo as it was getting dark) Black mirror caps Again a relatively easy fit. Although the glass takes quite a bit of force to remove. As @JR RS found, the Chinese copies have the middle fixing tab in the wrong place. But secure well using the two side catches. Unfortunately the passenger side didn’t go so well…. I was shocked at the price of the auto dimming glass. £300+! So I shall squint into a £25 non dimming version in future. Hopefully Thursday I will get a chance to fit the black roof rails to finish the look. I shall put the links to the parts used in my project thread.
Is it on auto? Does it do it if in manual with a certain vent selected?
