Binx1310
Everything posted by Binx1310
  1. True on the learning. Mine has a little scuff on the near side rim and it’s very obvious.
  2. Yes low battery voltage seems to give lots of random errors as the individual control modules start to lose communication with each other. For 2023 is it still under warranty? Seems unusual for the battery to be failing already. Might be worth returning to the dealer and getting them to look.
  3. Thanks. Not done wrapping stuff before and not sure I would achieve such a new look. Looks beautiful.
  4. Go for the dark wheels. You know it’s right choice…
  5. Think the dealers do now more diagnosis than normal garages and then start replacing parts. From the limited dealings I’ve had with them, a good independent specialist is far superior to OEM.
  6. I have a white estate too and would love to black out all the chrome. Did you wrap or paint them? or buy OEM parts?
  7. SOLVED It was battery voltage all along. I’ve seen so many posts on this forum of Christmas tree dashboards and people being told it’s low voltage but for some reason it didn’t register with me at the time. Took the car for 10 Minute blast up the A14 and then turned everything electronic off and plugged in. Cleared all fault codes without issue. Scanned again and just 2 codes that I know about still showing. Phew. Kept it plugged in for 5 min drive home and showing 14.3 volts so I’m happy it’s charging ok.
  8. I think it’s the right profile but I think maybe battery voltage was low. The car had been sat for an hour or so with internal lights on and then headlights on when the ignition was turned on to connect to obd. I read on an Alpha forum of someone having similar issues with Bluetooth obd. Will take the car for a 10 min drive and try again.
  9. For full info here is the output from the full scan: Car Scanner ELM OBD2 Version: 2.1.6/2.1.6/iOS DTC report Connection profile: Skoda MQB, PQ26: TSI/TFSI EA211 1.0L/1.2L/1.4L/1.5LDate: 3/8/2026 6:29:09 PM VIN: REDACTED ============================ OBD-IIOBD-II DTCs: 2 ---------------------------- U0416 [0xC416] Invalid data received - vehicle dynamics control module Status: Pending ---------------------------- U0092 [0xC092] Status: Pending ============================ 19. CAN Gateway19. CAN Gateway DTCs: 1 ---------------------------- 131702 [0x020276] Archive (inactive) U010000: Lost Communication with ECM/PCM Timeout_Node_0x76_DiagAdress_01_Motor_MLBevo U010000: Lost Communication with ECM/PCM Timeout_Node_0x76_DiagAdress_01 Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:50 Status: Confirmed ============================ 09. Onboard supply control unit09. Onboard supply control unit DTCs: 5 ---------------------------- 541973 [0x084515] Archive (inactive) U112100: Databus missing message Motor_04 Datenbus fehlende Botschaft Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:28 Status: Confirmed ---------------------------- 542229 [0x084615] Archive (inactive) U112100: Databus missing message Motor_14 Datenbus fehlende Botschaft Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:28 Status: Confirmed ---------------------------- 542485 [0x084715] Archive (inactive) U112100: Databus missing message Motor_18 Datenbus fehlende Botschaft Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:28 Status: Confirmed ---------------------------- 555541 [0x087A15] Archive (inactive) U112100: Databus missing message Motor_12_alt aktiv Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:28 Status: Confirmed ---------------------------- 559125 [0x088815] Archive (inactive) U112100: Databus missing message Motor_07 Datenbus fehlende Botschaft Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:28 Status: Confirmed ============================ 03. ABS control unit03. ABS control unit DTCs: 11 ---------------------------- 08246 [0x002036] Archive (inactive) Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:09 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 08250 [0x00203A] Archive (inactive) Status bits: 1 Priority: 3 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:09 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 08252 [0x00203C] Archive (inactive) Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:03 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 08254 [0x00203E] Archive (inactive) Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:03 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 08256 [0x002040] Archive (inactive) Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:03 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 08258 [0x002042] Archive (inactive) Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:03 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 08264 [0x002048] Archive (inactive) Status bits: 1 Priority: 3 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:03 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 08351 [0x00209F] Archive (inactive) Status bits: 1 Priority: 3 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:03 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 16409 [0x004019] Archive (inactive) Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:15 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 16410 [0x00401A] Archive (inactive) Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:15 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ---------------------------- 16416 [0x004020] Archive (inactive) Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:15 Paramteric values: 00 02 00 18 52 00 00 00 A4 00 05 00 01 FF 00 00 02 53 80 01 01 00 10 Status: Confirmed ============================ 01. Engine control unit01. Engine control unit DTCs: 4 ---------------------------- 34257 [0x0085D1] U112300: Databus error value received Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 40 Odometer: 68038 km Date, time: 2026.03.08 18:23:57 Engine RPM: 0 rpm Calculated engine load value: 0.00 % Vehicle speed: 0 mph Engine coolant temperature: 68 ℃ Intake air temperature: 45 ℃ Barometric pressure: 14.793849276714 psi Klemme 30 voltage: 11 Paramteric values: 20 96 28 12 B0 00 00 16 41 07 16 D8 00 08 16 28 00 10 26 00 00 16 2B 31 01 Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear ---------------------------- 34193 [0x008591] U041600: Invalid Data Received From Vehicle Dynamics Control Module Status bits: 1 Priority: 6 Frequency: 2 Unlearning index: 40 Odometer: 68038 km Date, time: 2026.03.08 18:23:56 Engine RPM: 0 rpm Calculated engine load value: 0.00 % Vehicle speed: 0 mph Engine coolant temperature: 68 ℃ Intake air temperature: 45 ℃ Barometric pressure: 14.793849276714 psi Klemme 30 voltage: 11 Paramteric values: 20 96 28 16 41 06 16 2C 00 00 2A D5 00 00 00 00 2A D4 01 80 80 00 52 D9 00 04 Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear ---------------------------- 42726 [0x00A6E6] U009200: Vehicle Communication Bus H Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 40 Odometer: 68038 km Date, time: 2026.03.08 18:23:59 Engine RPM: 0 rpm Calculated engine load value: 0.00 % Vehicle speed: 0 mph Engine coolant temperature: 68 ℃ Intake air temperature: 45 ℃ Barometric pressure: 14.793849276714 psi Klemme 30 voltage: 11 Paramteric values: 20 96 28 F4 46 33 F4 0B 65 10 10 00 00 24 FC 01 E0 11 99 10 00 08 2B 00 43 21 00 Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear ---------------------------- 31508 [0x007B14] U041600: Invalid Data Received From Vehicle Dynamics Control Module Status bits: 1 Priority: 2 Frequency: 2 Unlearning index: 40 Odometer: 68038 km Date, time: 2026.03.08 18:23:56 Engine RPM: 0 rpm Calculated engine load value: 0.00 % Vehicle speed: 0 mph Engine coolant temperature: 68 ℃ Intake air temperature: 45 ℃ Barometric pressure: 14.793849276714 psi Klemme 30 voltage: 11 Paramteric values: 20 96 28 F4 46 33 F4 0B 65 10 10 00 00 24 FC 01 E0 11 99 10 00 08 2B 00 43 21 00 Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear ============================ 04. Power steering04. Power steering DTCs: 6 ---------------------------- 22784 [0x005900] Archive (inactive) U112100: Databus missing message MOTOR_14-Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:02 Paramteric values: 2E 2E 63 59 00 00 25 72 78 00 00 02 F2 01 D7 00 00 00 Status: Confirmed ---------------------------- 23040 [0x005A00] Archive (inactive) U112100: Databus missing message MOTOR_20 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:02 Paramteric values: 2E 2E 63 5A 00 00 25 72 78 00 00 02 E8 01 D1 00 00 00 Status: Confirmed ---------------------------- 22272 [0x005700] Archive (inactive) U112100: Databus missing message KFC_MOTOR_11 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:03 Paramteric values: 2E 2E 63 57 00 00 25 72 78 00 00 02 E8 01 D1 00 00 00 Status: Confirmed ---------------------------- 22528 [0x005800] Archive (inactive) U112100: Databus missing message MOTOR_12 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:03 Paramteric values: 2E 2E 63 58 00 00 25 72 78 00 00 02 F2 01 D7 00 00 00 Status: Confirmed ---------------------------- 28672 [0x007000] Archive (inactive) U112100: Databus missing message MOTOR_07 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:06 Paramteric values: 2E 2E 63 70 00 00 25 72 78 00 00 02 F0 01 D6 00 00 00 Status: Confirmed ---------------------------- 23296 [0x005B00] Archive (inactive) U112100: Databus missing message MOTOR_CODE_01 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:06 Paramteric values: 2E 2E 63 5B 00 00 25 72 78 00 00 02 F2 01 D7 00 00 00 Status: Confirmed ============================ 05. Authorization system for access and starting the engine05. Authorization system for access and starting the engine DTCs: 4 ---------------------------- 12716804 [0xC20B04] Archive (inactive) U112100: Databus missing message Ausfall Motor_14 - Botschaft - kein Signal/Kommunikation Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:15 Status: Confirmed ---------------------------- 12718343 [0xC21107] Archive (inactive) U112100: Databus missing message Message Motor_07 missing Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:15 Status: Confirmed ---------------------------- 12718344 [0xC21108] Archive (inactive) U112100: Databus missing message Message Motor_09 missing Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:15 Status: Confirmed ---------------------------- 12718345 [0xC21109] Archive (inactive) U112100: Databus missing message Message Motor_code_01 missing Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:15 Status: Confirmed ============================ 08. Heater and climate08. Heater and climate DTCs: 1 ---------------------------- 459023 [0x07010F] Archive (inactive) U112100: Databus missing message Motorsteuergerät - kein Signal/Kommunikation Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:20 Status: Confirmed ============================ 10. Parking Assistant 210. Parking Assistant 2 DTCs: 4 ---------------------------- 13637426 [0xD01732] Archive (inactive) U112300: Databus error value received ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:22 Status: Confirmed ---------------------------- 12648465 [0xC10011] Archive (inactive) U112100: Databus missing message Motorsteuergerät - Motor_12 - kein Signal/keine Kommunikation Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:22 Status: Confirmed ---------------------------- 12648466 [0xC10012] Archive (inactive) U112100: Databus missing message Motorsteuergerät - Motor_14 - kein Signal/keine Kommunikation Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:22 Status: Confirmed ---------------------------- 12648468 [0xC10014] Archive (inactive) U112100: Databus missing message Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:22 Status: Confirmed ============================ 13. Active cruise control13. Active cruise control DTCs: 5 ---------------------------- 01064 [0x000428] Archive (inactive) U112100: Databus missing message FAULT_TIMEOUT_MOTOR_14 U112300: Databus error value received FAULT_CIS_BPRESSURE_FAIL Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:36 Paramteric values: 02 85 76 02 8D 68 10 11 00 00 10 12 00 00 10 2E 06 Status: Confirmed ---------------------------- 01065 [0x000429] Archive (inactive) U112100: Databus missing message FAULT_TIMEOUT_MOTOR_16 U112300: Databus error value received FAULT_CIS_BPRESSURE_INVALID Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:36 Paramteric values: 02 85 76 02 8D 68 10 11 00 00 10 12 00 00 10 2E 06 Status: Confirmed ---------------------------- 01067 [0x00042B] Archive (inactive) U112100: Databus missing message FAULT_TIMEOUT_MOTOR_20 C10DF00: Brake temperature FAULT_CIS_BRKOVHT_FAIL Status bits: 1 Priority: 4 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:35 Paramteric values: 02 85 76 02 8D 68 10 11 00 00 10 12 00 00 10 2E 06 Status: Confirmed ---------------------------- 01133 [0x00046D] Archive (inactive) U112100: Databus missing message FAULT_TIMEOUT_MOTOR_CODE_01 Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:36 Paramteric values: 02 85 76 02 8D 68 10 11 00 00 10 12 00 00 10 2E 06 Status: Confirmed ---------------------------- 02101 [0x000835] Archive (inactive) U112300: Databus error value received FAULT_ESP_STATUS_SYSTEM Status bits: 1 Priority: 4 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:35 Paramteric values: 02 85 76 02 8D 68 10 11 00 00 10 12 00 00 10 2E 06 Status: Confirmed ============================ 15. SRS15. SRS DTCs: 3 ---------------------------- 1053952 [0x101500] Archive (inactive) U112100: Databus missing message NWD: 0x121 Motor_20 Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:40 Paramteric values: 00 52 BE 8D 00 00 00 Status: Confirmed ---------------------------- 1056000 [0x101D00] Archive (inactive) U112100: Databus missing message NWD: 0x3BE Motor_14 Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:40 Paramteric values: 00 52 BE 8D 00 00 00 Status: Confirmed ---------------------------- 1057792 [0x102400] Archive (inactive) U112100: Databus missing message NWD: 0x0A8 Motor_12 Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:40 Paramteric values: 00 52 BE 8D 00 00 00 Status: Confirmed ============================ 17. Dashboard17. Dashboard DTCs: 3 ---------------------------- 1048578 [0x100002] B201000: No basic setting Steuergerät keine oder falsche Grundeinstellung B201100: Incorrect basic setting ECU no or wrong basic setting Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 88 Odometer: 68038 km Date, time: 2026.03.08 18:25:46 Status: Test failed, Confirmed ---------------------------- 16776971 [0xFFFF0B] Archive (inactive) U112100: Databus missing message Motor_04 keine Kommunikation U112100: Databus missing message Motor_04 communication error can_error_timeout U112100: Databus missing message Motor keine Kommunikation Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:45 Status: Confirmed ---------------------------- 16776988 [0xFFFF1C] Archive (inactive) U112100: Databus missing message TSK_07 keine Kommunikation Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:45 Status: Confirmed ============================ 2B. Steering column lock (UDS)2B. Steering column lock (UDS) DTCs: 1 ---------------------------- 12666369 [0xC14601] Archive (inactive) U112100: Databus missing message Timeout Message Motor_14 Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:24:54 Engine RPM: 772 rpm Calculated engine load value: 0.00 % Vehicle speed: 0 mph Engine coolant temperature: 40 ℃ Intake air temperature: -33 ℃ Barometric pressure: 0.870226428042 psi Klemme 30 voltage: 0 Status: Confirmed ============================ 42. Driver door electronic equipment42. Driver door electronic equipment DTCs: 1 ---------------------------- 524339 [0x080033] Archive (inactive) U112100: Databus missing message Message Motor_14 missing Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:03 Status: Confirmed ============================ 44. Power steering44. Power steering DTCs: 6 ---------------------------- 22784 [0x005900] Archive (inactive) U112100: Databus missing message MOTOR_14-Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:02 Paramteric values: 2E 2E 63 59 00 00 25 72 78 00 00 02 F2 01 D7 00 00 00 Status: Confirmed ---------------------------- 23040 [0x005A00] Archive (inactive) U112100: Databus missing message MOTOR_20 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:02 Paramteric values: 2E 2E 63 5A 00 00 25 72 78 00 00 02 E8 01 D1 00 00 00 Status: Confirmed ---------------------------- 22272 [0x005700] Archive (inactive) U112100: Databus missing message KFC_MOTOR_11 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:03 Paramteric values: 2E 2E 63 57 00 00 25 72 78 00 00 02 E8 01 D1 00 00 00 Status: Confirmed ---------------------------- 22528 [0x005800] Archive (inactive) U112100: Databus missing message MOTOR_12 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:03 Paramteric values: 2E 2E 63 58 00 00 25 72 78 00 00 02 F2 01 D7 00 00 00 Status: Confirmed ---------------------------- 28672 [0x007000] Archive (inactive) U112100: Databus missing message MOTOR_07 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:06 Paramteric values: 2E 2E 63 70 00 00 25 72 78 00 00 02 F0 01 D6 00 00 00 Status: Confirmed ---------------------------- 23296 [0x005B00] Archive (inactive) U112100: Databus missing message MOTOR_CODE_01 Botschaft - CAN-Timeout Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:06 Paramteric values: 2E 2E 63 5B 00 00 25 72 78 00 00 02 F2 01 D7 00 00 00 Status: Confirmed ============================ 52. Front passenger door electronics52. Front passenger door electronics DTCs: 1 ---------------------------- 524339 [0x080033] Archive (inactive) U112100: Databus missing message Message Motor_14 missing Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:13 Status: Confirmed ============================ 5F. Electronic Information System 15F. Electronic Information System 1 DTCs: 1 ---------------------------- 06708 [0x001A34] Archive (inactive) U112100: Databus missing message Engine, no communication Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 40 Odometer: 68038 km Date, time: 2026.03.08 18:25:18 Status: Confirmed ============================ 75. Emergency Call and Communication Module75. Emergency Call and Communication Module DTCs: 1 ---------------------------- 00041 [0x000029] Archive (inactive) U112300: Databus error value received CAN TO Motor ECU Status bits: 1 Priority: 6 Frequency: 2 Unlearning index: 40 Odometer: 68038 km Date, time: 2026.03.08 18:19:36 Status: Confirmed ============================ 76. Parking assistant76. Parking assistant DTCs: 4 ---------------------------- 13637426 [0xD01732] Archive (inactive) U112300: Databus error value received ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:22 Status: Confirmed ---------------------------- 12648465 [0xC10011] Archive (inactive) U112100: Databus missing message Motorsteuergerät - Motor_12 - kein Signal/keine Kommunikation Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:22 Status: Confirmed ---------------------------- 12648466 [0xC10012] Archive (inactive) U112100: Databus missing message Motorsteuergerät - Motor_14 - kein Signal/keine Kommunikation Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:22 Status: Confirmed ---------------------------- 12648468 [0xC10014] Archive (inactive) U112100: Databus missing message Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 128 Odometer: 68038 km Date, time: 2026.03.08 18:25:22 Status: Confirmed
  10. I’m hoping someone can advise. This evening after cleaning my wife’s kodiaq I thought I would plug in my obd module and have a scan. Not done hers before but done plenty of bits including coding on my MK3 superb. I selected what I thought was the right profile and scanned for codes no problem. A couple of historic ones for door locks came up so I tried to clear them. The dash lit up like a Christmas tree with every warning light going. And the trouble codes is now full of communication errors. My wife saw this occurrence and I reassured her I know what I’m doing but I don’t think she believed me… So I’m turning to the forum for some technical advice and hopefully to restore marital bliss! Cycling the ignition cleared the warning lights but the faults in the scan remain. Car is a 21 plate facelift 1.5tsi DPCA kodiaq mk1. I selected the profile based on the engine code but now I’m thinking it probably should have been the EVO one despite it not mentioning Kodiaq. Can anyone help? Thanks.
  11. I found bristos to be very lacking. Vindis in Bury St E are a bit better. I did notice when scanning the modules it says “last coding date” so would be relatively easy for them to scan it and see it’s been played with.
  12. Thanks. It’s in for service at the end of the month so I’ll ask them to have a look when it’s up on the ramp Ok so it’s probably not far off this. I need to log when I buy it so I can be certain of usage I think.
  13. Since getting my Superb in November I think it’s used 25L or so of Screenwash. I have changed the headlight wash to be 1 in 20 rather than 1 in 10 but it’s still using a lot. I know the roads have been mucky with salt and dirt etc so it gets used quite a bit but gut feel is it’s excessive. It’s not a faulty sensor either as when it alerts me to low level it will take 4L or so to fill it up. Is there any common places for Screenwash to leak? Does your superb use lots of Screenwash? It doesn’t let you operate the Screenwash with the bonnet open so it’s not possible to run the pumps and see if there’s any leaks.
  14. I’m 99% certain that it’s not possible at all on facelift. So definitely not worth the risk. I only half read the pinned thread on it hence why I went in head first and managed to wing it first time!
  15. Is it facelift as I don’t think the mods work for facelift models. It would be worth accessing the page and seeing which dataset you have. Theres 3 or 4 versions that I’m aware of with screen shots from this and the boot opening pinned thread that shows the parameters. If it’s not listed on one of those I wouldn’t risk it as it seems that you can’t just revert changes back like you can with other carscanner coding.
  16. Do you have source or part number for the Audi luggage flap. I’ve seen them on Audis but can’t find them anywhere to buy.
  17. Are all parts you are using OEM? Or all from AliExpress? Does the kodiaq have the warning lights on the glass or the mirror covers? I’m thinking about adding this to my Superb but was looking at the generic kits and then thought about connecting the indicator wiring to OEM lights in the mirror caps.
  18. Fitted the wheel nut caps today and looks much smarter. I feel a bit lost without pending deliveries and parts to fit. Roll on payday to order the brakes. Also need to change the rear pads on my wife’s Kodiaq.
  19. In other news I did 457 miles yesterday and averaged 43mph thanks to the A14 and M6. I did get 57mpg average though.
  20. Phew. I was panicking that I had broken your tailgate! Autohold set to early and direct accelerator algorithm is very much recommended.
  21. Oh. How strange. you have a different parameter version. But this screenshot from @igrozan may work. Click on use user defined bytes at the bottom then enter the same codes and apply.
  22. Then you should get a list of datasets
  23. My understanding is that open and close holding the button on the key works. But for the internal button all it does is release the catch. I would assume that the exterior and interior buttons on the tailgate itself work as designed. @tombee I am at home this afternoon so feel free to pop over and we can have a look if youre free.
  24. Perhaps try an alternative lift back dataset. And go through and check all the settings again. It’s as if the code for unlock only is displaced to the selection you have made.
