RoddersUK
Everything posted by RoddersUK
  1. Hopefully they clean it off soon! Also, the door, the yellow lines reflection bend, I'd have thought they should stay straight. Has it had a knock when opening?
  2. Never had these on my car, not sure the tool is in the back. Don't know why that would be gone. Guess at some point a garage never bothered puttin them on, for the previous owner. Might buy some, would look better.
  3. The blue does look very nice! Is that paint damage under the lower grill at the front? Decent tyres all round and not cheap crap?
  4. If some oil has helped, perhaps it went down so low it sucked a bit of air in. A bleed will probably be the best thing to do first, as you've read it's common too.
  5. Ok, that's all done, there was 'N' on some things, I didn't change anything. I just let it do what the default was. Was about 20mins if that.
  6. Wow, up to 1hr to do......lucky it's not really hot
  7. Cheers, PM received. Will play later!
  8. Ok, thinking about it I do have some glitches, so any update for this?
  9. Well mines not broke, so maybe I shouldn't touch it, lol
  10. As far as you might be right, my car just passed it's MOT, so there's no wobbly bits and I'm no going to spend hundreds of pounds changing bits, if I can squirt a bit of grease on it.
  11. This is a well talked about problem on the front, but not sure about the rear. I sprayed up all my joints front and rear the other weekend, I did have front end noises prior to this. Now I have nothing! There are threads in here about it.
  12. My screen gets quite warm too and it all works fine.
  13. Finally have updated the maps lol
  14. I shall be attacking this at the weekend, cheers
  15. Do you have any photos or diagrams?
  16. Apart from the map update, which it won't do, I agree there's not much more useful stuff. Maybe the traffic for navigation, but that's all.
  17. Well that's 100% failure. Dloading the maps, just sat at the end (green bar full) and doing nothing. Left for 15 odd minutes. Was trying the smartlink+ functions, but none of that works either. Can't mirror link........just imagine if I paid £44.....
  18. Have a 1 month trial. It's not the slickest of software, always throwing up some sort of error/issue
  19. Credits are only for the built coding apps.withun the softwar, which as I understand mostly don't work. So don't waste money on them. Code manually.
  20. I've never bought it, but it's £44 for me. Might give this a bash, as it's not been connected since 2018
  21. Which parts are you greasing, are you disassembling and greasing, or just pushing it in somewhere?
  22. Air filter doesn't look too bad, given it a blow out with compressor, not much came out really. Didn't look at plugs. I'll just change them if I go to the effort of pulling them out 😁
