Everything posted by SkOmk4
Dash cam power
That's new... I remember reading around here - some were complaining about the mirror usb-c that turns off when the ignition is off, and they wanted to use parking mode for their dash-cams. L.E.: found the other topic:
Dsg box
The DSG software on Octavia MK4 does indeed put the gearbox into "P" when you press the button to stop the engine. It has become a habit for me to no longer press the gearbox-"P" for the park position, because the car does that automatically. BTW - for 2 years I used to drive another dual-clutch transmission (Megane-GT) that was not drive-by-wire and that needed manual input of the gearbox-lever into "P" position. In most of the situations I do not apply the parking brake (that is the other "P" in the car, not the one of the gearbox selector) - NOTE for the initiator of this topic: that's the electronic hand-brake operated by some electric motors on the back wheels, not manually as you used to do using a hand-brake lever. I'm generally not using it simply because I'm parking on horizontal areas most of the time; when the sloped terrain is asking for it, I'm also using the parking-brake. The shifter in the Octavia MK4 doesn't have a dedicated "M" (for manual) position. However, the driver may access the Manual-mode at any time (while the gearbox is in D/S position) by using any of the two shifter-paddles behind the steering wheel. The gearbox indicator on the digital dashboard will change from "D" or "S" to "M" followed by the number of the gear that is engaged. The gearbox will remain in Manual mode until the driver will put it back into Automatic mode, but will still change gears if the driver doesn't: it will downshift to avoid engine-stall, and it will up-shift to avoid over-revs while accelerating. To go back into Automatic mode from Manual-drive, the driver has two options: pull back (short-pull is enough) on the gearbox selector, or pull back the "+" paddle behind the steering wheel for about two seconds. As @toot mentioned, reverse is for going backwards - so that's for you to decide... Neutral - you'll probably never need that position in normal usage conditions; it is mainly needed when you need to push the car for a couple of meters, or for towing the car when there's no other option. D/S is for going forward, only the gearbox behavior (software)) is different. In "D" the gearbox is shifting gears at quite low revs and it will not show the gear-number on the dashboard of the car. In "S" only the gearbox is in Sport-mode (not to be confused with the "Sport-mode" of the Engine&&DSG), so it will change the gears at slightly higher revs, and you'll also see the engaged gear-number on the dash (see second picture - lower-left corner). I always use the "S"-mode of the DSG, because I hate not knowing the engaged gear, and because "D" is keeping the revs too low for my taste.
OTA Update Issues
Is that the software version that came from the Factory? Or is it the consequence of your visit to the dealer, or received OTA? (You mentioned on the other topic you went to see them yesterday or today) I seem to have the same hardware as you do (my car was built end of August '22), not sure if the last letter in "Device part number" makes a huge difference. I wonder if we should also expect to receive the 1900 OTA... The Navi database version in my case is different, 'cause I don't have the navigation. I imagine that it might change if I would buy the package from the Skoda Shop. But for me Waze is way better.
Delivery times?
Welcome to the club! It's now a good time install the Skoda app on your phone and try to add your car - if you haven't done so already. If it's indeed completed, it will be shown by the App and you'll be even more excited.
OTA Update Issues
My key is always away from my phone, either in a different pocket, or in a dedicated pocket inside my backpack. And prior to this update I don't remember seeing this behavior, even though I was using the car with the same frequency (weekend) for most of the time. This morning I had to pick up something from the car, so I had the chance to check: the keyless worked flawlessly. So it would seem that Sunday to Wednesday is too soon to go into what I'm assuming is that deep-standby.
Front washer jets removal/replacement
Can you be more specific? Are you referring to the headlights washer jets, or the windscreen washers?
OTA Update Issues
I received the notification for this OAA2 update (138 MB) during a longer weekend trip 10 days ago. I started downloading while driving and I initiated the installation during a gas-station stop. The system restarted a couple of times, all seemed to be in order and I continued my trip once the update was finished. Over the first few km I realized that the radio stations (Favorites) were no longer stored, and I assumed it somehow lost my settings during the update. Because of this assumption I also checked the ambient lights - they were not the colors I previously set. So I thought: Nevermind, I'll set everything back when I'll have the time... After the next stop the same day, when I returned to the car I noticed I was greeted with the message "Hello Guest" - so the car didn't know I was the Main User. So I went into Settings->User and chose Main User. After that all my settings were restored. So that was strike one: - mistook Main User and Guest after the update; (I only had one key with me - the one I always used for the Main User...) strike two: - the car somehow deactivates the keyless entry after several days. I only use the Octavia over the weekend, and I can only assume it goes into some sort of deep standby, because the keyless won't work after 5 days, but it works perfectly after one day (Saturday to Sunday). When it deactivated I tried every door and the trunk - with the same result: I had to use the key "unlock" button. strike three: - when I lock the car (keyless) the dashboard remains ON (showing the usual farewell screen: car picture + trip info) for few tens of seconds - it didn't seem to be the same timeout every time... The HUD is instantly OFF, but the digital cockpit stays ON. This never happened before this last update; I was paying attention because it was mentioned a couple of times on this forum.
Delivery times?
I noticed on that red sign next to your car, that someone is kindly asking you not to feed the horses... is it referring to all 245, or only part of them?
70 Plate Octavia How can I switch from MPH to KMPH
That's a really ****ty way to treat customers... And I think you should follow this up with some customer protection authority. That's obviously a faulty product, Skoda is also admitting that - according to what you guys are posting here. Hence once a solution/fix will be released it should be applied to ALL affected vehicles. AFAIK, when car manufacturers launch a recall for a specific issue, they apply that solution to all the affected cars, not only to those that are still under warranty.
vRS Engine Cover Recall
You also seem to have a non-stock air-filter-box cover. Was it part of the same 70 Eur deal?
Disable wireless charger?
Are U guys talking about the factory fitted wireless charger, or the aftermarket one that is connected to the USB-C of the car? On the stock (factory) charger there's no problem with the size of the S22 Ultra. I used one for a while but reverted to an S21 Ultra (I couldn't stand the sharp corners of the S22 and S23 design). Anyway, they both comfortably fit inside the charging space with some room to spare - the phone will even move from side to side if one goes a bit faster on a curvy road. FYI, for longer trips I'm only using the cable charging - this way the phone stays cold; with the wireless charging it gets really hot, plus the fact that it's starting and stopping charging depending on how it moves inside that space, and you get those messages that @lost_npc mentioned... 2xUSB-C ports in front, 2xUSB-C ports for the rear passengers... In case you need a 12V for other purposes (as I did) you might also use an adapter connected tot the 12V socket in the trunk of the car. Not ideal, but that's in case you don't want to connect directly into the fuse box inside the car.
Octavia VRS
This one is not about how it sounds, but about how it looks... 🥰
Any way to carry items in Octavia Estate without warning lights and beeps?
According to what @Jorgeminator described in the first few posts of the topic below, it doesn't look like the lower part of the back seats was designed with the purpose of being easily removed or forward-folded. He mentioned extra-care is needed with the front-clips that might brake, and also with the cable for the weight detectors that needs to be disconnected:
Is there such a thing as...
So you're looking for something like this? https://www.aliexpress.com/item/33029550503.html I bet if you dig a bit deeper, you might find those already in a color matching your Velvet Red Later Edit: there you go: https://www.aliexpress.com/item/4000807731980.html?spm=a2g0o.detail.1000014.24.5b901f02GBgRDz&gps-id=pcDetailBottomMoreOtherSeller&scm=1007.40050.281175.0&scm_id=1007.40050.281175.0&scm-url=1007.40050.281175.0&pvid=3e496ba2-1dc9-4423-b183-df79c5714a97&_t=gps-id:pcDetailBottomMoreOtherSeller,scm-url:1007.40050.281175.0,pvid:3e496ba2-1dc9-4423-b183-df79c5714a97,tpp_buckets:668%232846%238116%232002&isseo=y&pdp_ext_f={"sku_id"%3A"12000031605655130"%2C"sceneId"%3A"30050"}&pdp_npi=2%40dis!EUR!5.89!5.89!!!!!%402101f6ba16754072814515187e696f!12000031605655130!rec
Dash cam
No, the kit provided by Viofo has 3 wires: 1 ground, 1 permanent +12V (only useful if you use parking mode) and 1 wire for non-permanent +12 V (contact/engine ON). This kit only powers the front camera. The back one connects directly to the front one for power supply and for data transfer to the SD-card.
Dash cam
I would have gladly used the mirror USB-C supply, but in my case it seems there's a "protocol" (or communication) issue. I have a new Viofo dash-cam that uses the ancient mini-USB input. I connect it to the mirror USB-C and it looks like it doesn't get any power. The mirror connector is fine, it powers my phone via usb-c to usb-c cable, but it won't power the camera via an aftermarket usb-c to mini-usb cable... Fortunately, I also have the fuse-box adapter-kit from Viofo, even though I didn't plan to use the parking mode. I'll now have to find the will and time to identify two available fuses (one permanent and one accessory) and then to play a bit with hiding the cables... (it's a dual cam, so there's one also going to the back of the car)
Headlight condinsation - anyone else getting it?
Sorry, when parked outside overnight in "suitable" condensation conditions, there's NO difference between halogen, xenon or LED... (Agreed, halogen is still dominant here also) And indeed, it happened over the years: I occasionally saw a Merc, BMW and/or other fancy(er) brands with condensation in the early morning, but that doesn't set the norm for those brands...
Noise during opening and closing doors - any solution
+1 Obvious for me since day 1 with Octavia, Never heard it so obvious in any other car I ever drove. But I didn't see it as a fault, just strange implementation... I'm guessing Octavia has some hard flap hitting against a hard material, while other cars probably have some softer material, at least on the interface/contact area.
That's exactly the reason why I was saying it's not normal... Because most similar cars don't have this effect clearly visible, while other cars have plenty of condensation - when all exposed to similar conditions. I remember @toot was mentioning recently on a different topic: you go through a large parking filled with cars that were there over night in cold, foggy or rainy weather - few cars will show plenty of condensation, but most of them will not. Which would obviously mean that condensation is not a standard feature for all cars, but it's either a design failure of a specific brand on a specific model or a defective headlight. The question I asked weeks ago still remains unanswered by "condensation experts" around here. Where do you draw the line between "normal behavior" and "warranty replacement"? There's no line on the headlight marked "above this limit we replace the headlight", there's no standardization as to what's the outside temperature and the air humidity to achieve a certain amount of "normal condensation". Obviously, the dealer response will vary from dealership to dealership, as it was the case for other obvious fails presented on this forum (e.g. software updates, steering wheel replacement etc.) It's ok, don't panic; you're not expected to understand... p.s. I'm hoping not all of your 9.2k posts are as useful to this forum community as you last posts on this topic...
Delivery times?
https://docs.google.com/spreadsheets/d/17h4myLSMpZ3dohgDJX25mkOhKLbyepEaeEeYcA3AqFY/edit#gid=0 the App will identify the VIN once the car will be completed - at least that was the case for me. You have plenty of pages to read on this topic - to get a general picture... It depends on how many options you have on your order - the more electronics you have, the luckier you'll need to be for the car to be completed on the first iteration. There are (and there were) many people around here with cars built, but incomplete...
@ @JEFF-the-Bowman No sure why they add those holes, I'm assuming it's for pressure equilibrium with the exterior. For heat dissipation LED headlights have those metal radiators on the back, that were not present on halogen lights. @Combi_NX5 Ouch! That looks nasty! Mine were only half of what you had, just the clear part (without the red section), but I only checked the next morning when it was already clear&nice weather outside...
No, it's not what I'm suggesting or saying... However, what I am saying is that a moving car and some temperature variation inside the headlight (from the lights) will enhance the air-flow in&out of the headlight and therefore a humidity increase. Ideally, if there would be no temperature and no pressure gradient between the inside and the outside of the headlight, and no air moving along the back of the headlight (where the headlight vents are positioned) - then you'd have no humidity getting inside. Therefore: - for a parked car the air exchange will be mainly due to the pressure gradient (that's mainly atmospheric pressure variations); - for a slow moving car and no headlights the contribution of the moving air will be added; - for a fast moving car with lights on there will be a higher contribution of the "wind" around the back of the headlight plus the temperature gradient. Not really. Just plain simple physics; thermodynamics to be more precise. Do you have any picture showing the rear condensation that led to the replacement?
Well, that's quite far from what I was saying... I just mentioned above that Megane users reported headlight condensation (you quoted it!), so I fail to understand your logic. Simple extrapolation: if I'd have spent more time in those humidity and temperature conditions, the amount of condensation would have been higher. Sure, one may assume that at some point an equilibrium between condensation and drying will be reached, but I'm just worried it was not the case after 30 minutes.
Unfortunately, the GT (RS chassis and 4Control) was out of production in 2018 (sept) when Euro 6b became applicable. I would have also bought the Megane if they would have still offered an engine-gearbox combination that would have interest me. However, the closest version to the O4 I ordered was still ~15% cheaper ( order: Aug.2021). As I mentioned, when the errors occurred in my case, the driving conditions were really good, and all the involved surfaces&sensors were cleaned before the trip. I developed the habit of cleaning windows, front/rear lights, sensors and number plates before longer trips when the car is dirty. There was no reason for those errors to popup mid-trip, except for poor-implementation. And we know pretty well there's a tone of post around here reporting all sorts of errors. There's more than unparalleled level of complexity and faulty sensors - it's lazy-coding and insufficient testing. Indeed, the other manual mentioned "Traces of condensation may be a natural phenomenon caused by variations in temperature and humidity". And indeed, there are users that reported condensation, but nothing close to the pictures of @Hairy_Joe (6th Dec.). I'm not worried by traces of condensation such as those I posted on 6th of Dec., but the condensation I had last weekend after 30 minutes of driving through rain, would have become similar to @Hairy_Joe and @T13 pictures after 2-3 hours of rain... So where does one draw the line? I'm sure that warranty replacement is highly dependent on dealer... (the disclaimer is right there in the Manual)
My last car was also full-LED (front and back); I drove it for more than 40k km in ~2 years, had no condensation - at least not visible - and it met all the weather requirements according to MK4 standards for normal condensation... This morning I noticed the condensation was gone from the headlights, but it was there inside the back lights. The previous car also had front radar&camera, lane assist, blind spot monitor... Only got "Front assist unavailable" a couple of times when the radar was covered by several mm of ice/snow. Today I was half-way on a 200 km drive, I received simultaneously front assist, lane assist and maneuvering braking unavailable. The weather was really nice, sunny, perfectly dry roads, about 10 deg.Celsius. The car was dirty overall from the previous two days conditions, but I specifically cleaned the "sensitive" areas before starting the trip today (front radar, front/rear sensors). I know I'm going off-topic, but the point I'm trying to make is that I'm starting to worry I received more gremlins than I paid for. (BTW: the Megane GT was significantly cheaper than the MK4)
