Everything posted by Edela
Octavia iV Granny charging - How to get full charge
To add to what was said above, car is not perfect in measuring state of charge of its battery either. It may show 100% while battery is not completely full, or 0% when there is still some charge. Often on cold days you could see how it shows one %, but you start driving and it may add another 4-7% to what it showing just a few seconds before. Not even talking that VC, infotainment screen and an app often show different SOC, though the difference is usually within 1%. Anyway, for 0-100% my charger typically shows 10.5 to 11 consumed. I'd say 10% loss is a bit too much for a PHEV and its charging power, but there is some loss definitely.
Octavia iV (PHEV) disappointingly low range on electric???
I tried Tesla type 2 chargers. Some of them worked, some didn't. I couldn't figure out what was the difference, but perhaps owner of such charger may decide if it is available to other cars?
They made Kodiaq the same way as Superb, so I'd expect they will try to upgrade Octavia, too. I'm only worried about the weight of new battery. Weight balance of PHEV Octavia is quite awful and I'd hope they will find out the way to improve it.
Issues with Early Build (2020) SEL 1st Ed Models
Looks like people focus on software a lot, since all the issues listed above are software related. Id' like to point out that hardware may very well fail, too. On my 11.2020 iV I have squeaking brake pads, both front left and back left shock absorbers died at around 40,000km, some guides in the trunk door were changed to resolve rattle issue. Issues with brakes with unidentified cause, but may be well related to ABS sensors. Electric motor whistles a lot sometimes, though Skoda doesn't want to admit it is an issue. Something rattles when the engine is cold and idling. Perhaps something else I already forgot about... anyway, my point is, better to have ok warranty if taking one of those early cars, and definitely it is a must to verify if all service campaigns were done and all firmwares were updated, too. Otherwise, you may get a bunch of other issues, like comms module failing, 12V battery draining during the night and stuff like that.
Flashing Fuel and Temp Gauges
In TPIs you will find how much time (time units) fixing should take. Based on this number Skoda compensates the work of workshops. Now imagine how much money they save when they don't force updates and there are many people like me, who had issue only once and couldn't get bothered. I'm not a fan of such approach when it is something concerning bigger issues, like we all had with faulty infotainment software or comms modules, and I'd rather make it illegal for them to keep fixes for themselves unless car owner complains. But I'm sure they'll find the way how to make workshop a scapegoat and not bear any responsibility as a brand. In the end, they issue service campaigns to fix stuff, including software, and dealers don't bother contacting car owners and booking appointments for that either.
Had this once on a long trip. Never repeated again so I didn't bother reporting it. As Steve mentioned, there is TPI for that issue, however I remember reading this TPI, it was saying that issue should be reproducible and customer should be able to show it. I guess this is somewhat standard for TPIs so will depend a lot on a workshop if they'll accept it and just make an update or will say they couldn't reproduce and thus will leave it as it is.
vibrations getting worse - 106,000km
I had something like that, together with brake assist and hill climb assist errors. On top of that on a few occasions while maneuvering, car was stopping very abruptly and was wobbling after the stop. My suspicion was something was wrong with ABS sensors. However, in workshop they found nothing and issue was gone by itself. So go figure what was that. Maybe indeed that was an ABS sensor and it was just dirty, so issue resolved after a few washes...
VRS IV Battery Health
Well no, 30 km is the absolute minimum I ever made. Usually my range is around 50 km.
Many short trips with big intervals. Every time car heats itself up, that drains battery a lot. Just for curiosity you could try to fully charge and make a few longer trips to see what consumption would be. Preheating car via app or departure schedules would win some miles, too.
New Car Questions
Depends on speeds. My experience is that on freeway speeds having full battery does not help much. I don't bother charging it on long trips. Though on slower trips (below 100km/h) the difference is huge and I typically have 3,5 - 4 L/100km (70-80mpg).
New Car Questions
Infotainment's button, below the screen. It is just that if infotainment is stuck on constant loading, rebooting it is often the solution, as to many other issues.
New Car Questions
Depends on the error message, I think. AFAIK, if radar or camera are dirty, it should say that Front Assist is temporarily limited or something like that. At least I had such messages when driving in snow and radar was covered in snow. If just unavailable - that might be the old known issue which should have been fixed on newer cars, older cars had to go through service campaign 4S58 to address that.
New Car Questions
15 seconds press on on/off button to reboot infotainment. In any case, when battery is depleted car will switch to ICE, so nothing to worry about. Also, moving gear selector beyond D will put car in sport mode, you will see D changing for S on your dashboard. This will put the car in hybrid mode, too. Just a bit harsher press on accelerator and ICE will kick in. Auxiliary heating or cooling is on. It should turn off some time after you lock the car.
Defaulting to "hybrid mode" on startup
It's not really to argue, but Isn't it a bit illogical? If some conditions are not met, then why would they become "met" right after switching ignition off and on again? Though the first kilometers ICE is the least efficient and will eat the most fuel. Anyway, I read somewhere that it is all about catalytic converter. Like, car wants to do some idle regen once in a while. I have doubts that's true but who knows... Definitely this is not the issue of low 12V battery, because there is a warning messages for low charge of 12V and if either of these messages pop up, it does not trigger ICE to start, and it doesn't need ICE to charge anyway. Not low temp, at least in my experience. I was parking car outside overnight in -12 and went electric no problem.
SOS Module Error
Since your car is brand new and already comes with 1940, yes, it will get SW updates OTA. However, there was a speculation previously that 1940 and 1941 are the same SW, just one is installed when car is made (1940) and the other is to update older versions (1941) on older cars. As far as I read online, nobody could confirm it, but it might be true. SOS module as all other modules have their own software, and as far as my experience with Skoda goes, they try to solve the problem locally with particular module before applying SW update or doing something else.
Infotainment System Restarting endlessly
I had on-off loops and restarts for 2 days in a row in October. Appeared for no reason, resolved by itself - very typical for this car.
Goodbye Octavia
If your car was 3 years old, I bet you had the same old H56 hardware anyway. It's not like they will swap H56 to H61 or something else, they will keep replacing the same H56, no matter how many times it fails.
Lane assist - does anyone actually like it?
FYI, this annoys af those behind you.
I never had a chance to drive in UK so I may only guess why, but I see online that only (or mostly) people from there are complaining about lane assist. In EU I never had issues with lane assist except when had to drive on roads covered in snow, where the track cars made did not alight with road markings.
Octavia iv real elec range
I'm not referring to WLTP at all. I mean, I've seen average of 30 or 40 for a trip, so it doesn't seem like car tries to make numbers nicer and closer to WLTP. I just think that for some reason car can't evaluate consumption well. Which is a big surprise to me, since I thought unlike air flow in ICEs, electrical current flow is something we learned to measure very precisely. But not in an EV for some reason. I suspect that what car regenerates is not what it actually charges in its battery and this is where the difference coming from.
Consumption values are some random values tbh. Here is a recent example: I drove 50 km and arrived home with 5% left, infotainment shows my consumption was 15 kWh/100km. How does this make sense if battery is 11 kWh? Even if useful capacity is more like 10 kWh, with such low consumption I should have made over 60 km. So watching such numbers I surprisingly learned that actually ICE cars estimate consumption much better than EVs...
Skoda connect app down,,,?
Aren't all brands use the same VW server? I've seen somewhere before that Skoda was excusing themselves for terrible connectivity saying they are fully dependent on VW infrastructure and can't change anything. Sounds legit to me.
Right, 3.6 is a peak power it can take. But even small battery has some charging curve, so last quarter or so is charged with less power than when the battery is empty. My charger shows me consumption per hour and I always see that first hour car takes exactly 3.6 and next two hours a bit less.
Almost never worked for me. With only a few exceptions, app was always saying there is no power connected to the car and it won't launch charging. I figured it will start charging only if I push the button before care goes to sleep though. Octavia won't take more than 3.6 anyway.
Sounds like you have charging schedule set. % of minimum charge is how much car will charge regardless schedule, but it will stop at this state of charge and will wait for scheduled departure time or off-peak time to continue charging till full.
