Edela
Everything posted by Edela
  1. I doubt you will resolve these by updating infotainment alone. They were known to separate issues requiring fw updates for front camera and SOS module.
  2. Sorry, but that is BS. Especially mentioning Seat here, together with Cupra they are very noisy cars. Perhaps something is broken in your Octavia so you find it more noisy, but in general it is the same as similar class VW cars. No modern car remembers settings which EU regulation mandates them to forget. But unlike others, at least in newer models Skoda offers a button to quickly return to previous settings. Not the case in Octavia yet, but show me any other car from around 2020 which is better in this regard?
  3. Connectivity issues are still there. Not always it is the car to blame, and when it is, pulling the fuse helps. But on Skoda's side it is still bad. The rest should be ok if car was taken care of.
  4. What helps is making a video where both an issue and VIN are visible. This is the kind of evidence they cannot reject. I learned it from the workshop when I had faulty infotainment, they were making such videos themselves to present to Skoda as evidence.
  5. You have two. One for ICE and second for HV. HV one is connected to AC circuit via heat exchanger and dumping heat there.
  6. Hope you enjoy your Elroq! I'm switching by the year end, too. Enyaq 85 Sportline in my case. Had Octavia for 4+ years now but eventually got tired of accumulating problems which workshops don't want or can't fix, so there it goes...
  7. I did not touch air vent, only removed speakers mesh. It simply unclips, so slide thin trim tool in the gap and pull. If I remember correctly, to remove air vent you'd need to remove this mesh first, anyway.
  8. I removed the mesh over the speaker and wrapped its clips with textile tape. That solved the problem for me. Some people were saying the speaker itself may be badly attached and rattle, but I checked mine and screws were tight as should be.
  9. The actual antenna is prone to corrosion and loosing signal over time. Mine was changed under warranty.
  10. Have this impression of Enyaq after a few test drives. Everyone seems to praise the car for its quietness, but in my impression, this is fairly noisy car, way more so than Octavia. So go figure what people compare it to, or indeed just repeating PR crap.
  11. Some were shared here on this forum. skoda.erwin-store.com is where you can get them, access is paid though.
  12. If I remember correctly, 0311 is the current version. Dealers say there are no updates because they only apply updates as part of solution to a specific problem described in TPI, otherwise they bear responsibility if anything goes wrong during the update. And they are just lazy, because myself sometimes I had to come with printed TPI to make them do the work... It may also be that you have some specific HW version which was not supported with updates later and to solve issues you would need to swap it entirely. Not uncommon with these corona cars when supply chains were disrupted as far as my workshop told me.
  13. My PHEV has the same behavior on 18 wheels. Very floaty despite having more weight and less rubber on the rims, yet small curbs or potholes hit hard. Got used to it.
  14. At least they are bringing PHEV back.
  15. @DJD66 did you figure it out in the end? I just found out that a few fixing points of plastic panels covering underneath of the car were broken or detached, and that appeared to be the source of most of the noises I thought are coming from suspension. To test the idea I stuffed the panels with some foam rubber and since then car was driving like new. Car is in the workshop now and I asked them (besides why the heck they couldn't figure this out in more than 2 years of me complaining about noises from underneath) to investigate why it was detached and banging, since as far as I know no works were done on my car which would require it to be removed.
  16. I've tried but failed miserably. Also in my case the gap is bigger and wider, though everything looks like it should fit back in its place. Thanks for the pics! Will try once again.
  17. Octavias are known for this issue. Some need OCU replacement or even simple FW update. Mine was fixed by replacing antenna on the roof. Apart of wrong GPS position it was giving SOS call errors.
  18. Screen is about the same, 1300 plus tax.
  19. I do not chase the most recent software and stay on 1941 still. So far did not regret once, reading this forum I see people have many issues on newer versions which I don't. So if everything works, I'd say stay on 1969.
  20. Sorry, I've never driven MHEV so can't comment. I only say that what you quoted from Skoda site is not applicable to hybrids. I would expect MHEV to engage regen every time brakes are pressed, along the mechanical brakes. I think that is the general logic behind hybrids, no matter the make. Maybe you have a way to see how hybrid system works in infotainment somewhere? We have it on PHEVs and it shows at which moment regen activates. Something like this:
  21. That only applies to EVs. Not even PHEV has this feature, the brakes apply as soon as the pedal is pressed.
  22. Viofo works just fine with any usb-c to usb-c cable there, I took the cheapest from aliexpress. You only need to wire it for parking mode, since power on rear mirror usb port is only available when ignition is on.
  23. It is even more important in PHEV because engine is often running on sub-optimal temperatures. Does seller explain somehow why they skipped servicing?
  24. Might help to factory reset infotainment and make a new user profile. I had this issue when car tried to sync to online profile and couldn't load settings, defaulting everything in the beginning of every trip.
  25. Mine 2020 has remote lock function, but since I had it brought to workshop with comms module related issues before, I guess they updated it back then. Never had O3A8 prompted. Running on 1941 as well and no system updates OTA, only apps updates.
