Everything posted by zacko_O
VCDS options on Superb III.FL
Did you install any module for steering wheel?
Canton Subwoofer Amplifier Issue
Need to replace lead wires to longer https://www.drive2.ru/l/659269097233580313/
- Reverse camera not activating after collecting from panel beater
Coding of Steering Wheel controls
This is Arduino module that works with CAN bus(not LIN) and does not work correctly. The Travel Assist button for some reason triggers View. Double-clicking OK also triggers View. From the factory, this is how it works on the FL: Bottom left arrow - Menu Right arrow - View So, if you’re gonna retrofit TravelAssist, then it’s not possible with Arduino CAN module. E.g. for mid FL Superb(07.2019 - 07.2020) Travel Assist can be easily activated, just coding More details:
Rear brake pads
Carscanner probably the cheapest solution Guide for Kodiaq, but 99% same:
- Reverse camera - does a kit exist?
Option to enable/disable dynamic LED rear indicators.
Try 09 BCM - Adaptations and deactivate: [VO]_Aussenlicht_Blinker: [LO]_Richtungs_blinken_rechts: [VN]_active [LO]_Richtungs_blinken_links: [VN]_active
Mib2-2.5 have old steering wheel Mib3 - new steering wheel and new VC At least for Superb 3, I guess same for Karoq
I did same for FL, no worries The difference is: preFL only DSG mode returns to Normal FL mode entirely returns to Normal For FL need a little bit more edits as described above
https://www.drive2.ru/l/677950899301124971/
- MIB2 high 8inch to 9.2 inch retrofit
- Retrofit heated steering wheel
I have returned to a Superb 3 and I have a couple of questions
99% - yes
- enable Traffic Sign Recognition with VCDS
Glow plugs, which ones do I need?
Before buying a new one, check resistance, it might be glow spark control unit problem as well. Glow plugs catalogue - https://www.beruparts.de/content/dam/marketing/emea/beru/catalogue/ignition-parts-pocket-catalogue.pdf PSG007 what you need
Steel Pedal Covers for DSG
I start having issues with boot closing right during my move to another city. Every 2/3 times it won't close, when I click close, it makes a sound and thats it, errors in 6D - В11D913: Motor 1 für Heckklappe Unterbrechung, В120A02 Usually it means wiring issue, but when I disassembled two drives, there wasn't any issues with it. But I noticed that mounts are very dirty, so cleaned everything and mounted everything back. After 2 weeks - all good.
