Everything posted by Octy-PHEV
Incorrectly Identified NSL Speed Limits
Most people seem to have unlinked the ACC from their traffic sign recognition and map display. Doing that means you have to set the ACC speed manually, but avoids it changing to an inaccurate one all by itself.
Turn off electric range in Navigation
Yes, I've had to turn mine off a couple of times. I'll have to check on the car, but I think it was on the navigation settings, accessed from the 3-dots button. I'll look tomorrow if that doesn't work.
High Beam Control (Light Assist)
Yes, it works fine. The manual isn't totally clear. What I've found is that you need to activate it once by pushing the stalk away from you (as if you were selecting high beam on a car without the assist feature). The 'A' symbol then comes up: white when it's on dipped and blue when it's switched to full beam. It you want to override it when it's selected dipped, you can push the stalk away from you a second time, and it will then stay on full indefinitely. You can also pull it towards you for a quick flash of full, as usual. I haven't tried this, but I presume you can override auto full beam by pulling the stalk, as that's what the manual implies.
High beam assist seems to be on special offer at the moment. I've just purchased it for £125 instead of the usual £180. I have the option appearing correctly on the menu, but I haven't driven in the dark yet to try it out.
Advanced Road Sign Display?
On my Octavia I couldn't see any difference between a speed limit that had been picked up by the camera and one that came from the map data. On my Honda Jazz I get different displays for the two sources and it's illuminating comparing the two. The one from the camera goes blank about a mile after the last sign it spotted.
Something strange with Aaptive Cruise Control
On my 2023 Octavia, you can disconnect the link between the ACC and the traffic sign recognition, so I presume you can too. The setting is called "speed limit preview" or something similar. It drove me nuts too until I found how to avoid the ACC target speed changing automatically.
Park assist
I'm curious to know how big a gap there was between the cars when yours came to its sudden stop, @croquemonsieur Was it a very near thing, or was there sufficient gap to give you confidence it would always be safe?
Road Sign Display on Columbus Navigation
Yes, the setting for showing the speed limit has gone for me too (on v 1989). It must be always on now. It also shows a warning triangle if I've just passed such a sign, but with the speed limit roundel directly on top, so that only the corners are visible. Having a PHEV, the thing I do have to change after every update is to switch off the electric range indication (under the ... menu on the map). Otherwise it looks like I'm driving in a spot of wonderful sunshine, with murky grey clouds everywhere else!
I think the setting is off the three dots (...) on the map itself. I had trouble finding it last time. If that doesn't work, I'll have a look tomorrow.
Bottom of rear bumper popped out (fixed)
Would you believe I've done this again! Am I really the only person who has ever done this? Assuming I'm not, here are some photos this time, as suggested by @CKO The first shows the problem (not as bad as last time, when a longer portion became detached with a larger gap). The second photo shows the wood strut firmly supporting the black part, and the L-shaped tool used to push against the inside of the body-coloured part of the bumper above (a canal windlass!), and the lower part snapped back in.
Ghost speed limits
There are a number of threads where people are complaining that it picks up long removed temporary speed limits. There are no signs at all to see now, but on the M1 and M4 it comes up with 50 mph at places where there were roadworks many moons ago.
Sudden Stop.
I've had it when reversing slowly if there's just a single blade of grass in the way. It's particularly annoying when reversing into a passing place on a single track road, as the driver waiting to pass must think I'm a total idiot.
vRS 4.5 annoyances (and birds!)
I've found this to be a particular problem on single track rural roads. If I meet someone and need to reverse smartly into a passing place, there's nearly always a blade of grass there that causes the brakes to slam on (if I haven't remembered to disable that 'feature'). The other driver waiting to pass must think I'm a total wally!
The link between the ACC speed target and what TSR thinks the limit is, is controlled by a setting called "speed limit preview". See https://www.briskoda.net/forums/topic/538558-hows-this-for-good-range-but/?do=findComment&comment=6009108
You can disengage ACC from changing the target speed based on what TSR is reporting (at least you can on my 2023 PHEV). The setting is not well described. It's something like "speed limit prediction". I wasn't so bothered about it reducing to 50 when passing the site of long completed motorway roadworks ( with no signs now present). It was the automatic speeding up to 70 when it had passed the site that I found alarming. I set my ACC to 60 or 65. I think it is dangerous for this to ever get automatically raised to higher than you've chosen manually.
Oil change service
This works for an Octavia, so probably will also for a Superb: https://www.briskoda.net/forums/topic/538755-reset-oil-change/
Reset oil change
Try this ( links to a YouTube video, which worked for me): https://www.briskoda.net/forums/topic/499496-oil-and-service-inspection-reset/
I've found that, even in places where there are no traffic signs, the speed limit indication is markedly different if you have traffic sign recognition enabled. I know this, because I had a month's free trial of TSR, but was glad when it ended. With TSR it seems to be accessing a second on-line data set, different from the sat nav one. I was getting all sorts of phantom limits showing for which there were absolutely no signs for the camera to spot - mainly 50 mph on motorways for sections where there had presumably been roadworks in the past. If you do have TSR, it may be this second data set that's causing the problems, which would explain why an update to the sat nav data doesn't help. When my TSR trial ended, I found the normal sat nav data to be much more reliable.
Park assist
I find Park Assist on my 2023 Octavia useful. When parallel parking, I think it can sense the kerb line (if distinct enough), not just vehicles either side. It seems to always put the tyres a neat 10 cm from the kerb. For 90° parking it's got me safely into really tight spaces I wouldn't have risked trying myself, with as many as 10 forward and back movements before it's happy! There does have to be a car either side for this - it can't interpret the white line around the bay. The problem then is how to open the driver's door sufficiently to get out!
Roadside recognition
I found during my one month free trial of Traffic Sign Recognition that the most noticeable effect was to pickup some remote data source different from the normal satnav. I also had phantom 50s where there had previously been roadworks, but now there was not a sign in sight ( on the M4 in my case). It also routinely gave me 70 mph when I was on a 30 mph road passing over a 70 one, and some other repeatable errors. It did also actually read some signs and was about 80% accurate in reading overhead variable limits on the motorway, and picked up a limited range of warning signs to show for just 7 seconds after passing them. Overall, I was relieved to go back to just the (pretty reliable) satnav indication of permanent limits.
Another update!
I didn't need my email address or PIN, but it did revert my chosen measurement units. Is US gallons really the default for working out mpg?
What year did the software issues stop ?
I think that's a mild hybrid MHEV. You can't plug it in but it recuperates energy when decelerating into a smallish (48V?) battery.
Same for me. It was on version 1940 when I collected it in November 2023 and it's been perfectly behaved ever since, including getting 2 over the air updates.
Front assist alarm - MOT FAIL?
Lots of cars of various makes have had the front radar sensor stolen, and they can still pass the MoT. Seems to be a particular problem with VW Golfs, and it costs £1000s to replace, so some people don't bother (particularly if they park in an area where such theft is prevalent).
- Bottom of rear bumper popped out (fixed)
