Benja77
Everything posted by Benja77
  1. Hi there! on my 22 FL I retrofitted the park assist buying the whole kit except the control unit (seller for other parts hadn't it available) which I got somewhere else. I also fit the rear camera with dynamic guidance lines. When engaging the reverse or activating the front sensors the car doesn't appear on the screen automatically (as before the retrofit) but it does if I press the top left corner of the screen. Mechanic told me it may depend by the control unit which was initially codififed for an Audi A3 even if the part code is always the same. So I went to Skoda dealer who made work the Park Assist (resetting the control unit) but the car doesn't appear automatically: is it matter of coding or what else? I'm also going to retrofit as well, in the next weekds, the area view 360 and blind spot mirrors, replacing again the rear camera: can anybody help me with coding?
  2. Hi there! I'm planning to retrofit on my 22 FL the power outlet (for home plugs), usb C and 12V for the rear seats replacing the 12V installed by default. I bought from a damaged car on the front the whole set of plugs including the inverter (the whole kit has part code 5Q0907155H) and ordered in Skoda the connectors (mainly for the outlet and usb, these on both sides) and cover panel. I also bought the USB inverter, 5G0035953D, which has an extra connector (the black one) to power the rear USB. Dunno why but according to mechanic only the 12V can be powered but not the outlet or the USB: does anyone know why? He also opened the inverter of the the 5Q0907155H and there's no short circuit on it. Dunno if the usb must be powered with a cable similar to LVDS or not (the connector is round). Please help me!
  3. Very easy to fit; just a pity you cannot fit front ones with the side steps (OEM as aftermarket)!
  4. Fitted similar cable on my 22 FL and works fine! S&S can be enabled too and cable keep memory of last activation/deactivation
  5. So it's impossible to swap just the 8 inch Amundsen screen with the 9 Columbus one without coding? or do I need any coding? Otherwise, do I need to replace the unit in the glove box too?
  6. Could You print and ship a longer one (I’ll pay You for it? Starting from OEM consider 1cm longer (or even 2), so I can screw the cover! I’d say I’ll buy 2 of which one is 1cm longer and other 2cm). i mean long 19 and 20cm instead of 18 as the standard one Let me know!
  7. What's the part number for left hand drive cars for the right dipping mirror?
  8. Does this work on FL too?
  9. Hello from Italy, My name is Ben and I'm a happy owner of a 2022 Karoq 1.5 Petrol Style in Graphite Grey
