Everything posted by Cairus
- Body Control Module BCM replacement and coding.
How To: Retrofit a heated steering wheel to a mk3 Octavia
Of course you can do it, but the question is whether it's worth the effort. I don't know of any Volkswagen Group vehicle that came with a factory-installed heater, given the technological standards of the time. So, it would probably involve a lot of modifications.
Oh yes, the only exception is if you already have the facelifted interior.
The problem is that the pre-facelift Octavia 2 operates on CAN 1.6, while the facelift model and the Octavia 3 operate on CAN 2.0.
Software Update available for Bolero?
Furthermore, it is secured via the metadata. Variant not in the metadata, no update, provided the device has not been tampered with and is OEM.
Forget it
Not my Car, the owner have No Reklamation
I have done 1805
No warrenty, all you do is your own risk Link is 24h activ Firmware 1800: 302.53 MB file on MEGA Firmware 1805: https://mega.nz/file/VqVFTSBQ#gV9E4NKAqS4Sjs55n-vlenJpJqZ0MFGsWGsywEBb8oo
I will send It later
Tested and working coding Octavia mk4
You can Turn Off ISA With 5W Camera. By Modell year 26 is a big Change, Kamera With 3W is installed. By 3W ISA can not Turn off
Car Not Activated
OK, try fuse Trick
Car Not Activated
Wich Software Version is installed on the Radio?
Car Not Activated
Pull fuse 15 wait 30min Which SW have mib3?
Columbus Firmware
Try this: https://mibsolution.one/index.php/f/174276
Upgrading MK3 Octavia audio
I agree, the Focal INSIDE VW system is a good value solution. I would Retrofit mib2 then code the MIB2 to the virtual sound system and adjust the audio data sets. You will be much happier. Alternatively, you could retrofit the Helix sound system. It includes a subwoofer with integrated DSP for the spare tire well. Alternatively, you could install the Focal Inside VW speakers, add some sound deadening, and you should be more than satisfied.
2017 superb se to hid sportline headlight conversion possible??
I Retrofit LED OEM Lights in our Octavia 3. If you have no experience, no tool for flashing control units or writing data sets, forget the project. The mechanical conversion isn't the problem, and you can manage the missing wiring, but the programming is a whole other big issue. https://www.briskoda.net/forums/topic/533353-retrofit-oem-led-lights-octavia-5e-facelift/
Columbus update stuck
OCU is for OTA Update
Online Control Unit Emergency in the roof
MY17 Superb Retrofitted with Direct TPMS
For examble https://ovoko.de/gebrauchte-ersatzteile/tan254339-5q0907273b-volkswagen-t-cross-steuergerat-reifendruckkontrolle-rdk
Car not recognising key
Broken keyless Antenne?
Once I've installed it in the trunk, I can do one.
TPI-Nr 2065474/4 -44 Maybe a reason
Pull the fuse from the MIB and the OCU for 30 minutes.
