Everything posted by Cairus
MY17 Superb Retrofitted with Direct TPMS
Basically, it doesn't matter at all if it works?
- Octavia 3 Extra USB in blank switch
My AliExpress was OEM
Infotainment retrofitting
Only 8"
Blank infotainment screen
This is only the Screen. Unit is in the Glovebox and To 80% the Problem
Octavia 2 2010 vrs petrol instrument cluster failure
The radio is completely irrelevant. It is not a component of the immobilizer system.
I've converted the speedometer from mini DOT display to maxi DOT display three times. I never had to code the BCM. Speedometer installed, immobilizer adapted with both keys, speedometer coded, done. An active immobilizer doesn't interfere with any other functions.
How-to Guide to Upgrade MIB2 to MIB2.5
Take Out the SD and Check, Navigationssystem is working
MIB Standard (Low) Navigationssystem need SD Card With Maps MIB High, Navigationssystem Maps is on the intern memory.
Correct
Camera Problem
Rear View Camera?
- Skoda Octavia Mk III VCDS help
Update?
Tyre pressure warning keeps reoccurring - not due to tyre pressure or faulty wheel sensor
Check it with a good VW Diagnostic Tool
Error Log is empty?
I wrote "direct clone," meaning reading the OEM dump and writing it unchanged to the new speedometer with a different hardware identifier. That would be news to me; that works.
Unlocking the door has nothing to do with the speedometer. This function is controlled by the BCM (Body Control Module). Of course, the immobilizer can be adjusted without a second key.
The immobilizer has nothing to do with the battery in the key.
Each new hardware index in the Octavia 2's instrument cluster had a new EEPROM. Therefore, a direct clone is not possible.
Change km IS a Work Form 1 Minute and dont need Clone
Start Engine and Stop After 2 Second IS the Immo
Skoda Octavia MK3 Smartlink Issue
Activate Car Play with only 1 SD Slot via direkt Connect eMMC
I would now also avoid going online with ODIS with connection to the factory server. Could trigger security alarm due to theft or manipulation
