Cairus
Everything posted by Cairus
  1. Password PM https://mega.nz/#P!AgDjMxAFEAGhWs64o5ZRcqnuxTD1v2lCQu-qAT16CsBhxQtsxJLcx0nwVt5M83plDtSJGxaSSCbT-4g-8AwEcIus7EU7Myzn8O4MV9pn6tB2YbkdyZ3xaQ
  2. Is the vehicle affected by the field measure where I think the gateway was the one that deeply discharged the 12V battery because it did not go to sleep
  3. Any vehicle HV battery is useless with a dead 12V battery because the vehicle's electronics won't boot up.
  4. Every vehicle with a defective battery didn't even display the immobilizer LED... if the battery is defective while stationary, the vehicle won't give any notification at all... the HV interlock release is located in the engine compartment. The pyrotechnic explosion affects the HV battery.
  5. If the 12V battery has a short circuit, it will be empty in a short time... How do you test the battery? With a load test? Everything else is worthless.
  6. Yes, technically possible. New steering wheel with buttons. New connection cable for coil spring airbag with/for MFL. Maybe Pull LIN cable. Code everything.
  7. Reinforcement plate(s) - subframe to body, step 1 20 Nm Replace screw(s). to body, step 2 90° Front axle stabilizer mount to subframe Step 1 20 Nm Use new bolt(s). Step 2 180°
  8. There are users who have installed it in the Yeti Facelift or Octavia 2 Facelift
  9. A complete scan with full SFD 2 protection is possible with gen 2, I have done it myself with a Skoda Karoq 2025
  10. Thank you, I'm familiar with the subject... you should therefore know that even with the SFD 2 contract with VW, which is currently being negotiated, it would never be possible to process SFD 2 with gen 2. The hardware basis for SFD 2 was implemented with gen 3.
  11. the saying was meant rather sarcastically
  12. For the first problem, update the radio system. For the PDC problem, it sounds like water is getting in.
  13. I know of cases where nothing worked despite preparation.
  14. SFD 2 or SFD 1?
  15. If you live in Europe, be sure to get a factory-fitted tow bar for a new vehicle. This will save you any SFD 2 discussion when retrofitting.
  16. Which year is the Car?
  17. If we'd like to add the coding for the steering wheel heating: Control unit 08---> Coding ---> Heated_steering_wheel_and_Heated_steering_wheel_automatic_mode Set To Active
  18. Make Full Backup with OBD11 and Post txt File here
