Cairus
Everything posted by Cairus
  1. I will write you in the afternoon
  2. Correct Date Set on the unit 76?
  3. Is allowed To Share tpi? TPI-2072245-5.pdf
  4. . Check this... Password send PM https://mega.nz/#P!AgBjIVaAPhBAV0eYvlLxnOxxeE38a7UgAG6X3agCdgtWJa94QjnCNJYzFc-PTaldmEEy3IBj_PmAV7FqW5xtTm8JIwlNCdBZrajLv8biP7-kX1bnse-VOg
  5. I don't need your secret, I just wanted to know if you do it yourself.
  6. If you want to do it absolutely right, or if it actually has to be done anyway, you have to code the ABS to the new Brake If The firmewre have the New Break in the rirnewre
  7. I wouldn't pay €30 for it. What file or data set do you want?
  8. Which manufacturer do the steering column switches or the winding spring come from?
  9. How do you do the Immo and CP? Read the EEPROM file, edit it? ODIS online? Is it factory new? With used Virtual Cockpits, the factory now has to manually enter the VIN into the database, which is based on the VIN read by the tester.
  10. My vcds works with win 11
  11. obd 11 can partially edit the EEProm.. vcds not
  12. Do you make the immobilizer and CP yourself?
  13. OK... With heating LIN>vi/gn>T14e Pin 5 LIN 2> vi > T14e Pin 12 Looks good. Pin 6 ist correct? Looks Like Other als 5&4
  14. Do you have an adapter for the wiring or are you changing the connector directly? The control unit without heating is wired differently than a module with heating.
  15. You Code the New one? You Change the wire by the Connect
  16. Then SD Card with correct CID or OEM Card and have To stay in the SD Slot one The Picture is Firmware
  17. So, I think the idea that OBD11 can modify the immobilizer is just a rumor. I use many systems, including VCDs and OBD11 with a free lifetime VAG Pro account. I don't see any advantage in VCDs. Yes, for newer users, the Pro account costs €80 annually. But let's be honest, this shouldn't hurt anyone financially...
  18. Via OBD11, go to the 5F and select "Adjustments," confirm the installation change, and read the value. The numerical value is calculated using the XOR calculator. http://xor.pw/# The read value is entered in input I. Input II. C9D2 is entered. Press XOR. The attached image is an example. Then enter the result in the field where the old value is. Adjustments, confirm the installation change, and then save. The error has now disappeared.
  19. On-board computer>scroll to Trip settings>hold down the right scroll
