Everything posted by tombee
The Bilt Hamber stuff is very good in general with their wheel cleaner being amazing for really dirty wheels
VAG DSG gear knob swap
Are you wanting a leather gaiter? I got the Alcantara one from Kolour Koncepts A friend of mine has a TCR so he measured the gaiter of his, the Superb is smaller so have taken a chance on it all. The gaiter that came off this Mk7 gear know was brand new if you are interested
Some of the parts have arrived, gotten a new MK7 shifter knob and leather gaiter, so have removed them from each other now. Just waiting on the gaiter and gear know insert, but now I am wondering about changing the sides of the gear knob like you have done @JR RS but for the Mk7 shifter knob
Adding USB ports in armrest?
Yes does seem to, only for charging anyway
I haven't bought a 2m USB C cable for this, just using the shorter one that I use at the front ash tray. You open the ash tray as normal and then at the top push in (does take a little force) and it drops down and some out from the bottom, the right side pops upwards at the bottom with the left side retains so when putting back put the left side in first.
Only removed the ash tray and then used a brake cable outer off a bike to help route it, a little fiddly but got there.
Thanks, so you don't have that area at all in yours then?
Been able to this today, thanks to @Binx1310 about the wiring etc. Able to use the tail from the socket I picked up off ebay and use the step down to connect to this and then the other end to USB socket that I had installed last year. Just had to route it in the car but wasn't too bad using a bit of cable to route from the back of the ash tray up to the inner of the arm rest.
Thanks, ordered
Thanks, yes of course. Would this work, can get it tomorrow - https://amzn.eu/d/07yYcGrw
Vertical Line through Infotainment screen
I have mine booked in for it to be looked at and then see if they can do a warranty claim, my dealer seems to be a little wet behind the ears and any warranty work is really seemly to be a little hard with hoops need to be jumped through, but we shall see. They are polite at least and as they are in the Audi dealer currently also, means I can look at shocking paint work of brand new cars with swirl marks and scratches on them. Noticed it over the weekend and it will bug the hell out of me for sure, mine is a 2018 with the newer style screen, but seeing as above has extended warranty and was replaced I am hopeful.
Thanks @JR RS parts are ordered now Just got to wait and then find time to fit
I was going to take a feed off the USB socket I have in the rear cig lighter that I replaced using the car's fuse etc
Thanks for that, right out comes the soldering iron then
Does anyone know if the Red and Black cables in the round cable above is all you need for just powering/charging USB. It has Green and Blue as well but only wanting to charge, the Amazon usb in line adaptor USB QC arrived to do but the end's not the same and so doesn't connect
Can’t seem to find the thread on this from @JR RS , could you post a link here Thanks for the reply Just wanting to know if I need to pop the top of the gear know to disconnect a link inside it
Thanks, only saw the Kodiaq gear knob but don’t like them. Wanting to fit a Alcantara gator at the same time so thought why not do the gear knob too
Just wondering if it’s possible to swap the current Skoda DSG gear know with a Mk7 and equivalent DSG gear know which is slimmer and seem to be in the other VAG cars and not Skoda 6 speed version to 6 speed
Steel Pedal Covers for DSG
Yes I came to realise that when looking into it, funny when searching on eBay it was sometimes cheaper to be the whole pedal assembly than just the cover
The single USB socket plate and USB has arrived today, its a Skoda unit so is a Skoda direct replacement for the blanking plate but only the a single USB port. The unit came with a tail from the round 4 pin connector, but I have removed the USB unit from the mounting plate, will then mount in the Single usb with in line power adaptor and should be golden. Will post pictures when the rest comes etc
Bouncy and Unsettling ride
The B6's have arrived today, waiting for the new mounts to come in and the car is booked in for the end of Feb to be done, can't wait now!
Ok will just order the standard ones from Skoda and not the bilstein ones, which are not in stock anyway. Will also new bolts etc for the front top mounts and lower arms front and rear
Replacing DSG selector leather boot
I would love to replace my leather one with alcantara to match my steering wheel
