Everything posted by Trickiejohn
New Superb wipers leaving a hazy/milky film after rain – anyone else?
My Superb is now 7 months old. Initially I had this issue. Washed the screen (outside) 6/7 times over 10 minutes, cleaned the blades with the same cleaner a few times - issue has never reoccured. Bosch Blades are better, I have a set waiting for the day there are needed
Has anyone else found the new Driver Monitoring System on the Mk4 Superb to be overly sensitive?
I occasionally get that message, however, on straight sections of the motorway I get repeated messages to “take control of the street wheel, this is despite having both hands firmly on the wheel, it just no input needed, I Mike micro adjustments to resolve this. It drives me potty
Skoda Octavia mk.2 2.0 tdi Elegance, ENGINE & DPF light on
I’ve owned VAG group Diesels for 33 years or so, never needed to add a DPF cleaner, I do use a fuel additive. However, my cars have always been driven enough miles in a week to allow the DPF to regulate itself with no outside help needed. A run of 20 ish miles at 2,000 revs is enough to keep the engine/DPF running well. Does your car run a regen at all (increased oil temp and revs at tick over). If it is but not running long enough to regen? If so the issue is your mileage/driving style. Running at least once a week for 20 miles preferably on A roads/dual carriageways. Will return your car to normal operation. A DPF cleaner “should” resolve the problem, but only for a short period before it starts again. Modern diesels are not designed for short stop start journeys long term. I have always exceeded 6k miles per year. This is what I use: Millers Oils Diesel Power Ecomax Fuel Additive Treatment
@jimmyw147 How is the car driven now. In the past it was good enough to regenerate the dpf. Short or long runs? If it’s only short runs, your issue is most likely there. The dpf needs to get hot for longish periods of time, 20 minutes is reasonable. A decent A road, dual carriageway or motorway would get the engine/dpf up to temp and give the dpf time to regenerate. Engine speed when warm at idle give an indication. If the engine is ticking over at 800 rpm, all is fine. At 1,000 rpm it needs a regen and the longer run normally returns idle back to 800.
Flat Battery in Key Fob - Warning
Just how fast is the battery draining for you? My mk4 is also the 5th car I have owned that uses this system - the first with “KESSEY” or whatever it’s called. I’m in month 7and only about 6.5K (miles) on the clock and all seems OL. All 3 keys are stored in blocking pouches ( I have checked that all three won’t unlock the car when stood next to the drivers door) Will using these affect the battery life?
Surprising mpg Octavia Estate
It’s great that your consumption figures are so good. However, how are you actually measuring the fuel used? Filling to “first click”, may be more accurate than the supplied data, however it’s not “accurate”. I can’t imagine a manufacture would knowingly underscore their mpg figures by over 10%, any more that they would over score the figures in any way. I could believe that they underscored buy 2/3 %. They do have a legal obligation to tell the truth (diesel and immersions scandals are hopefully a thing of the past) 🤞🤦♂️. Of course, if your driving economically is warm weather on decent roads with minimal traffic. The figures will be great. Friday evening, I returned home from Shepton Mallet via the A39/37 21 miles. Normal consumption 53-58mpg, depending on traffic temperature and time of day. The car recorded 52.4mpg on the way (hotter temps but the end of the busy period), and 62.1 on the return. There are hills, villages with 20 mph limits, traffic lights, and it’s a bus route. Not what you’d use to prove your consumption figures. My point is your figures are great 🤩, but possibly only as accurate as the cars data. As were mine 🤦♂️
Exactly, you need a proper diagnosis. It may be simple, but I doubt it, the car will auto reg en during a 2 hour drive without the higher revs. If the car ticks over at the normal 800ish rpm you may be lucky. If it’s still at 1k rpm. I personally would get a known DPF Competent shot to diagnose the issue. Most garages either don’t have the required equipment to correctly diagnose the issue. Don’t take the “delete dpf” offer as if the garage is one of the majority it won’t help in the long term. Someone like Baz is what you need
OEM brakes vs Zimmermann – rear pad availability?
My friendly AI, offered this information on non OEM pads. No Zimmerman of course, however a few decent alternatives in there 🤞 Yes, there are excellent non-OEM alternatives for your Skoda brake pads (part 3WA 698 451). Many premium aftermarket brands manufacture pads that are equivalent to or even outperform the OEM parts. Top-Tier Aftermarket Brands · BOSCH: Reference 0986460074. · BREMBO: References P85182, P85184, or P85184N. · PAGID: References T2903 or T2903N. · ATE: References 13046073552 or 13047073552 (Ceramic option available). · FERODO: Reference FDB5357. Other Reputable Brands · TRW: GDB2373 · TEXTAR: 2616901, 2620601 · MINTEX: MDB3469 · DELPHI: LP3663 or LP3669 · VALEO: 302784, 610521, or 672001 💡 Recommendation: If you're focused on minimizing brake dust and keeping your wheels clean, ATE Ceramic pads come highly recommended by Skoda owners. However, note that some owners have observed that these ceramics can be more aggressive on brake discs over time. For a balanced performance, Brembo, Pagid, and Bosch are consistently praised as reliable upgrades over standard OEM fitment. When purchasing, double-check that the pads match your front or rear axle and match your specific disc size (e.g., 312mm, 340mm). If you share your Skoda model and engine, I can check for potential fitment differences.
That was the same in my previous VAG motors, both A3 and Passat. However it’s a simple job, I change mine when I renew the road fund licence.
Spurious Emergency Stops
Mine is a June 2025 build date. It does have all the latest EU mandated safety features a UK requirement as well. I switch off lane assist on most journeys over 5 miles. This stops the car letting you know you’re changing lanes without indicating. In real life it just means that if you move out a bit to pass a parked car and cross a white line there is no feedback from the car. The motorway issues can be reduced but not normally removed. If you use cruise control, shorten the distance setting between you and the car in front gives you less time to react, but critically also reduces these occurrences where your not in danger and are moving to a safer possible overtaking position. The cruise control will also follow between the white lines. It will, let you know if it thinks you are not: Looking alert through the windscreen Firmly holding the steering wheel and adding inputs (turning the wheel to keep in the middle of your lane. If it thinks you’ve been taken ill OEM unconscious, it will make a noise in the car, then brake, apply the hazard lights and pull in and stop.
Error codes
Regen every 100 miles isn’t normal, unless your trips are all short. Do you do longer journeys say an hour on the motorway? If not try this first. DTC clear isn’t helpful as it can hide/delete some of the required info. I’d recommend visiting a garage where they fully understand the DPF and all its related system and faults. Most garages definitely don’t. Baz Merideth and O’rileys autos are 2 YouTube channels worth looking at. One of these may be local to you
Kodiaq petrol.... Cambelts
Cam belt wear depends a lot on the vehicle usage and quality of the fitted product. My view is that changing early is a form of insurance. The cost of a catastrophic failure far exceeds the cost of an extra cam belt change. If you change your cam belt every 50k that’s 1 extra over 140k miles. How many keep their car that long for so many miles?
Whilst I agree with your comment on what’s officially advised. I would NEVER leave my cam belt that long, be it a belt or chain 😱
Random choice of MP3 track
No problem with Spotify premium, it continues where I leave off and runs/plays flawlessly. I dropp Apple Music a few years ago
Playing Shuffle tracks from bluetooth iPhone
That’s strange, I use Spotify premium (courtesy of my eldest) and it plays random as it should . I stopped using Apple Music a few years ago.
Which engine?
Ghost speed limits
I see the same problems around East Bristol. Road works related speed reductions don’t take more than couple of days to show on my 2025 Superb. They can take a couple of months to revert to standard after the works are complete. I haven’t yet seen the issue with truck speed limits (where different) showing on my screen. I do however see some unrestricted country roads showing a 30 limit. I’m happy with that, the lunatics who fly round single track roads, continue to do so of course.
Map software update
Hi All, This evening, I saw the red blob on the top left (ish) of the infotainment screen. On checking it said that I had a software update, gave a code that didn’t show on the System Information screen. However during my journey home it updated👍 The only entry on the system info page updated was: Navigation Data base from 26.4 to………… 26.5 - This wasn’t the info shown on the “available update screen” I hope this is helpful. Does anyone have an idea of the update content? IE traffic signage, speed camera updates, you get the general idea😁
Adaptive Cruise Control (ACC)
On my 2025 Superb, it required an abnormal amount of input regardless of having my eyes yon the road, side mirrors and rear view mirror, talking to my Passanger and having full control of the wheel. If the motor was empty, straight as a die, I still had issues with it telling me to take control of the wheel, gripping harder didn’t have any effect, I needed to move the wheel a few mm left/right to stop this. Following between the lines was ridicules, it would over steer for even the most minor adjustment moving from one side of the carriage way to the opposite. However, I think there has been at least 1 minor update. Yesterday I drove from East Bristol to West Swindon, set the speed to 66mph. For the first time ever no ridiculous warnings to open my eyes or take control. No more steering flaws. It worked as flawless as the older version in my ex Passat. Finally, I’m happy to use it. I’m all for safety systems, however, don’t release the software until it works properly every time you use it. Switching these services off is safer than using unpredictable systems. Driving around some of Bristols narrow roads with a solid line of cars on one slide of the road, almost always results in the bright red imminent crash warning light and horn sounding. This is an every day occurrence for me!
Octavia 2 egr valve problems
To be honest, “getting rid of it” won’t necessarily leave your engine trouble free. The main issue is finding someone who fully understands the issue. It’s possible just a blocked pipe, or yet again much worse. I’d find someone who defiantly has the knowledge and ability to resolve it properly. Just removing the DPF May not resolve the issue at all. Occasionally if you’re very lucky a 1 hour run out at 2,000 revs constant can resolve the issue. I would try this first. This issue is normally down to lots of short runs and no long running combined with poor maintenance. Have a look at baz merideth, on Utube
Platinum Skoda - Bath.
Pete, I found your post not to reflect my experience or expectations. To this I emailed Skoda Bath, included you comments but no personal data. As you can Imagine I received a prompt reply. I have included it below in full apart from my details. Hopefully you’re not put out by my actions. My only hope is that it’s the last time this occurs. Enjoy your Toyota, decent motors 👍🏻 Regards John Good afternoon John, Thank you kindly for bringing this to our attention. I’m thrilled to hear you continue to be pleased with your new Skoda Superb and the service from us. Sadly the below comments fall well below the level of service we look to provide and are disappointing to see. Whilst I understand we were short staffed last week and Sara was already engaged with another customer (out on test drive) during the enquiry I will investigate this further. I’m sure this could of explained professionally and an alternative approach offered. Thanks again. Kind Regards, Keith Atkins Sales Manager Platinum Škoda Bath Lower Bristol Road Bath BA2 3DN 01225 485400
The EU updated their rules (that we comply with) making a few more safety items to be active every time you switch on. That they can’t be. Permanently switched off. Go figure….
Griding and screeching noises.
I have only once in my life used Mr Clutch, (thats because I have only ever needed 1 replaced). Admittedly it was a few years ago with a Passat Estate 2.0tdi 140 mapped to about 186. The car had done about 86k iirc before I noticed a slip whilst towing. The were quick, did a good job, also told me that on my last cam belt change the Garage had failed to torque the fan belt pulley correctly, but they had done that as well. 30K later when I swapped for its younger brother all was still well.
the truth about electric cars
I’m not anti EV, I run a 75 plate Superb 2.0 TDI by choice. Many of the journeys I do would be close to the maximum of an EV, I don’t have Solar or heat pumps and my home is a recent build 2017. However the pain that could be involved queuing for a public charger and the lack of many local to me has kept me on an oil burner. If/when the UK mandates EV only, how is the country going to produce enough electricity on a cold winter, minimal from solar, no Wind, no help there, to keep the homes of everyone warn and dry as well as charge all the Vehicles and batteries overnight. Don’t forget that they are also trying to phase out gas heating and cooking. Of course things over time will get resolved. The most cost efficient method runs around continuing to extract from the North Sea, develop better wind solar and ground heat options. Invest in the Small nuclear reactors for each major city and industrial areas of the country before reducing the options left open to the general public. In our older towns and cities with narrow streets and insufficient parking, how are people going to charge EV’s? In around 15 years, the future will be much improved (only if the Government spend OUR money wisely of course) Then pushing the higher polluting vehicles off the road makes sense. We have the other issue of weight of vehicles and corresponding increase of damage to our roads. Local councils don’t have the monies to pay for the ever reducing time between major repairs, they have never in recent decades managed to keep up with minor repairs either. Goverment policy needs to be changed to prioritise what’s needed for the majority of the nation/s population. Not the current Huge amounts of spending that’s wasted, monopolising Government spending. Will this be the end for historic vehicles in the UK?
Another Oil Consumption Topic
It’s very strange that owners experiences can be so far apart. I’d have expected them to be quite similar. My used car experience has mirrored the new car experience in my vehicle use. In my younger years, the cars were driven harder faster for longer, carried more weight (3 kids/holidays in Europe and trips to from Germany/UK). Nowadays I drive a bit slower, do less miles about 10/11k per year, carry less weight in the car. What does remain the same is the regular oil changes at least 1 per year, more if it’s heavy mileage 16K plus. Any and all work is done as soon as it’s noticed, some by me, other work I pay a (normally) local VAG specialist. I find quality and honesty to be much improved over the average dealership. I’d find it hard to believe that anyone who goes to the effort of signing up to a forum dedicated to their car, would willingly not look after their car. I must have been very lucky up to now with the cars I’ve bought 🤞
