Everything posted by Redboy
Getting rid of the Superb, what next...
Does an ideal affordable car exist? A better if you could afford it and have enough room on your drive, would be a more exciting weekend car and a larger daily load carrier.
1.8 tsi petrol has issue
You have a timing chain not a belt. The misfiring is probably due to the cam tensioner failing, causing the timing to be out and possible top end damage. This depressing thread linked above will explain all, if your car has the same problem. Fingers crossed it’s a simple ignition fault.
Has the cam chain tensioner gone and caused it to jump a tooth? There's an extensive thread on this. Might be worth not using it until it's been checked unless you are mechanically competent and can do it yourself.
Heated steering
Skoda won’t replace corroded crappy wheel centre inserts, so I think the contract small print get out clauses reserving the right to change, might not let the omission of what will now be an optional extra. The early MkIII VRS had Front Assist as standard and then suddenly didn’t.
Remap vrs diesel octavia 2017
That’s about the same summer mpg for a 300hp TSI...
Decisions, decisions....and so it starts
Rather than raising the springs, I expect the new Koni active dampers prioide a more controlled ride over poor surfaces and speed bumps.
Error - start-stop system superb mk3 2019
Perhaps the battery needed a boost after being stood for some time and by driving it, the battery gained sufficient power to allow Stop/Start and the fault self-cleared. If it happens again despite regular use and your battery is healthy, Aldi are currently selling a basic OBDII device for £16.99, which could help you self diagnose any EML or simple faults. My 19 reg Superb battery needs to be topped up regularly with an Optimate trickle charger as its use is limited by lockdown.
Octavia Vrs 2.0Tsi whte smoke when accelerating?
I'd be more worried if I saw clouds of black smoke under heavy acceleration...unless it was a diesel.
Is a Superb 272 calling me?
TSR is just another toy. In 2022 all new cars sold in the UK and EU will have speed limiters, you might as well wait until then.
ABS/ESP error (with tyre pressure warning too)
Thanks for the feedback. It was an annoying and quite an expensive repair.
Where are all the used vRS 245s?
Why is it a loss if you pay £16800 for it? You will still have a car you like, the huge plus is that you know the history of the car. WBAC is a business and simply trying to make a profit , i.e try to retail it for around £16K, as that's the going rate for avg mileage 3 year old VRS. A concern is that a new manual MkIV VRS can be bought for £26K and may drive down used MkIII values.
Toyota dealership rip off on GR Yaris already ( don't blame it on Covid-19 or Brexit)
Good old capitalism, supply and demand. Joe Schmo can buy one, rag it then profit...but not the dealership which will be doing any warranty work.
As it will be imported in limited numbers, I wonder whether 'preloved' (barf) prices will be higher due to speculators.
Is mine the only VRS with Pictorius alloys ?
There were some VRS which I think were sold by Motorpoint, from the EU, possibly, Cyprus, which had that or a similar non- Gemini style of wheel Ps. Nice change from Race Blue or grey
SE variant DSG doesnt have Drive mode selection, so no option to select "ECO" or allow Coasting?
I would leave it in Drive as you have no way of taking effective avoiding action if you need to. As for the benefit of ECO mode, I rarely use it, after driving 280 miles driving like a saint, coasting a lot in ECO, anticipating stoppages and lifting off early. It gave a computer reading of 40 Mpg. It was boring. On the return journey I drove as normal, and lost 1 maybe 2 Mpg. Also if you lift off in Normal mode, the engine doesn't demand fuel. Savings can be made by intelligent driving and, if you can spare the time, by doing long journeys at non-peak times. Life really is too short too worry.
2018 Superb. How does Adaptive cruise, front assist, emergency brake, and blind spot work in real life?
BLIS is excellent on dull motorway journeys to get your attention when being overtaken. ACC is very relaxing, the only 'irritation' when it decides to play safe as cars turn right for left and it slows when it's obviously safe to proceed. Additionally, if you approach a junction/roundabout with ACC activated and nothing in front of you, the ACC system will carry you right through the junction. Emergency auto braking whilst reversing slowly does work well, if you are inattentive. I haven't tried it out whilst going forwards but assume it will save an expensive and embarrassing dent.
New VRS collected with a few questions dealer have been unable to answer as yet
It's the fake 'rorty' exhaust/engine sound, which came as standard in the Mk3 Octavia when put into Sport mode, which many owners disliked and switched off. It impresses people ... some people and then becomes a bit annoying. I had it on mine and a Golf GTI, which actually had a real burbling exhaust.
2021 F1 Discussion
They’ll have a better chance of winning?
Octavia Mk3 Turbo Failure?
Good job you are persistent and have mechanical knowledge.... and presumably deep pockets. You must have wondered a times if the outlay in cash and effort was worth it.
Auto headlights.
Before you complain, rather than HBA, you probably have intelligent headlights, take it for a drive in the dark, and watch the beams reshape as oncoming traffic approaches. I keep mine on at all times and never have an issue
Acceleration issues after remap.
I assume your VCDS scan hasn't thrown up codes related to throttle input to the ECU? Perhaps the simplest option would be, reset your car to original, to see if it runs as it did prior to the remap and then go to another mapper. I am on my fourth 2.0 TFSI / TSI. One of the main attractions for me, is the way that these engines pull smoothly and strongly right up into the redline without hesitation.
New car battery time
Great result in warranty replacement and very interesting. My L&K is now 16 months old, I always disable stop -start shortly after I leave the driveway as I use it for rural 10 mile commutes and a weekly 20-40 mile trip. Short runs to the shops are done in the wife's 13 year old Sirion. I have never killed a battery and began to look after the Superb's battery by using an Optimizer trickle charger during the the 1st lockdown in March, 6 weeks after purchase. I was surprised to find the battery state in the red and needing to be'saved' rather than simply charged. I also do occasional checks and top ups in colder weather. I use the heated seats, screen and steering wheel but only with the engine running. Yet every time I hook up the Optimizer it has to save the battery usually 60% or under. My last VRS also had heated seats, front screen, stop start and was used for the exact same commute, yet the battery was never in the red. I can only think that the 1st driver at Skoda Mgmt, who ran it for 2500 miles and 6 months, did a lot of short stop start driving and possibly damaged the storage capacity. I don't think it was a pool car as it had child seat indentations on the rear seat base, which have now almost disappeared. Nothing was bought to my attention at its recent 1st service. Or I wonder if owners of other newish cars have found the same thing with their batteries.
Changing to 18" wheels on 1.4TSI Sportline.
Perhaps you should price up all your tyre and damper options then contact your insurers, to check for any possible premium change or even policy cancellation. My last VRS was mapped but only after I had changed insurers, as my old insurers policy had a automatic cancellation clause for mapping. As for tyre noise, comfort and handling, after 12 years of VRS and admittedly brief, GTI ownership , all with 40 profile 18 & 19 wheels, I can say that 18" 235 45 tyres combined with Superb in DCC comfort or normal mode gives a more relaxing ride, DCC sport mode stiffens up the handling enough for positive handling on twisting roads at sensible (legal) speeds. The tyres are also quieter but that could be due more soundproofing in the Superb, the GTI tyre roar on 19s was louder than the VRS.
Coolant loss on new Octavia VRS 245
A brand new car should be a pleasure, not a headache. There is a definite fault. Take it back and say fix it or exchange.
Remap Kodiaq Stage 1 - not detectable by dealer?
I imagine it's almost impossible to successfully claim for a clutch on a warranty after 6 months mapped or stock, the old wear and tear / corrosion clause is the usual get out of jail free for the company
