skoda1982
Everything posted by skoda1982
  1. they do under seat storage but they a smaller than the glove box they are a pull down drawer
  2. skoda1982 replied to a post in a topic in Škoda Kamiq
    lane assist teaches you to use your indicators especially on motorways
  3. Its normal and not a problem all depend if you park up hill or down open doors drain out. Drains during normal driving. There is no drain hole at the front only middle and rear. My Last Kamiq done it and this one
  4. There are huge delays as there are no micro chips from China factory had slight shut down. I think skoda dealers have priority before third party's
  5. Look here the last one where it says have fun. They are not fixed on the front only underneath
  6. You do it at night when dark so you can set to your preference no good doing it in daylight
  7. PAGE 54 owners manual Set the brightness of the instrument cluster lighting The brightness of the instrument lighting is automatically adjusted depending on the given lighting conditions. When low beam is switched on, the brightness of the instruments lighting can be adjusted in the following menu in the Infotainment system Press Car cogs light buld
  8. You have to have an update at your dealer it didn’t have a protection program deleted at the end of production so stops you being a primary user and having Skoda connect. Could take up to 5 hours for the fix. Resetting will not work
  9. This happened in all athe skoda cars I've had when the rear windows open
  10. Do not disconnect the battery its coded. Use a piggy back fuse in fuse box
  11. Have to factory order for seat
  12. It is whatever comes first so in your case 1 year did so mileage does not come into it. But as you are set to variable 18500 miles or 2 years but you don't do enough miles for variable
  13. Sorry on informant screen press car under nav then Selection, Driving data, instrument cluster scroll to bottom you can reset since start, long term, trip recorder. To view average mileage go to CAR then settings Virtual cockpit view 1 then select what you want to see. Then on your steering wheel press the bottom right button select driving data then press the scroll wheel to select long term since start or since refilling hope it makes sense hard to explain when writing
  14. Press car then 2nd one down scroll to bottom. You can reset them all if you want. I do this before I get out of the car before refilling
  15. It will say inspection aswell. As inspection is every 2 years. With oil change . So on fixed service its 9500 miles 1 year oil change then the 2nd year service is inspection service with oil change so variable service is 18500 miles or 2 years hope that makes sense ask dealer to set to Fixed. When you get to 1 year or 9500 miles take for a 1st year service then ask to set to Fixed then second year will be a inspection service
  16. Has your service indication come on. Look in settings car look for service it will tell you there how long left in days and miles if it is set to variable that's 18500miles 2 years if fixed thats 9500 miles or 12 months the first is for people who do more than 10000 a year. If variable ask to have it set to Fixed
  17. skoda1982 replied to a post in a topic in Škoda Kamiq
    That is front assist you can set the sensitivity in settings set it to late. Lane assist does not yank the steering wheel it gradually turns and you can stop it by holding it
  18. skoda1982 replied to a post in a topic in Škoda Kamiq
    If a day comes along and you rear end someone or worse hit a person then think I should have left front assist on
  19. If front assist is to sensitive set it in settings to Late
  20. Clean with vinegar it's the wax of car wash shampoo
  21. The scala did replace the Rapid. like the karoq replaced the Yeti
  22. You have to take the plastic trim off not the carpet
  23. Wire's there but no plug
  24. Skoda lock these settings now so you cannot activate like you used to it's so you cannot get them free in vcds settings
